2019 Cruise Control Gas Mileage is HORRIBLE.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ariesgtturbo, Jan 2, 2020.
  1. Jan 2, 2020 at 7:34 AM
    Ariesgtturbo
    Ariesgtturbo [OP] Well-Known Member
    Northern Illinois
    2019 TRD Pro - Midnight Black
    17" Black Rhino Mint Wheels 265/70/17 Falcon WildPeak A/T3W Tires Victory 4x4 Roof Rack SoftTopper Bed Cap - Black
    I've been waiting for you.. what took you so long? hahah
    Ck1010 and AMC_Unlimited[QUOTED] like this.
  2. Jan 2, 2020 at 7:36 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Wow, guess I'm lucky. I use my adaptive cruise all the time and I dont think ive seen an average below 20 mpg ever. Usually I'm in the 21-23 range, that's v6 stock everything with a tonneau cover over the bed. The only time I think it may have been lower was driving into a strong headwind. And yes it downshifts sometimes on hills, every vehicle will do that.
    Chew likes this.
  3. Jan 2, 2020 at 7:37 AM
    Cullen@GotExhaust
    Cullen@GotExhaust Well-Known Member Vendor
    Cullen
    Virginia
    White 2019 Tacoma TRD Off-Road
    Stock
    I drive the interstate every day for about 25 miles. Cruise control likes to shift to 5th gear and sometimes 4th and hold them. I have found that I can control the throttle myself, build a little momentum before hills, and get a higher mpg than if I was running cruise.
  4. Jan 2, 2020 at 7:38 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I've seen this issue posted many times but never an issue with mine(2016) and plenty of hills/mtns here.
    Madtown[QUOTED] likes this.
  5. Jan 2, 2020 at 7:42 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The cruise on my 2019 works great! I turn down the sensitivity, from default of 3, to 1.
    As @rlx02 mentioned, cruise is always going to be worse, than an eco conscious driver.
    Also consider; we're in winter, so winter gas, tires will have reduced pressure (if you didn't top them off), and we've had lots of wind here in the midwest, yesterday in MO we had steady 20-30 mph wind all day. I drive 50 highway miles dead West to my gun club, doing from 65-75 mph in to a 15-25 headwind, I'll be in the mid teens , and I'll be about 20-21 mpg going home.
  6. Jan 2, 2020 at 7:47 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    My tacomas cruise control is the first cruise control in 20 years that I have actually liked. Every other car I have had always hung in a lower gear and felt like it was always mashing the throttle. Slight incline = full throttle!
    With the tacoma I can set the cruise to 79, then get behind a semi truck. The cruise keeps me back enough to not piss off the trucker, but close enough to ride his wake.
    I have no desire to speed, so getting behind a truck is perfect for me.
    4x4spiegel likes this.
  7. Jan 2, 2020 at 7:48 AM
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    I've done a couple hundred mile road trip and i averaged around 19 MPG with cruise control. Worked fine for me.
    BadDogMax likes this.
  8. Jan 2, 2020 at 7:57 AM
    NikonBiologist
    NikonBiologist Well-Known Member
    Boise
    2019 Silver Tacoma TRD OR 4x4 DCSB
    cruise control set at 72 from Boise to Sacramento (550 miles) and got 20mpg hauling 900lbs in the bed. I did lower the mph though when going up hill and I'm sure that makes a lot of difference. On the way back to Boise, same set speed, I got 22mpg but wasn't hauling as much.
  9. Jan 2, 2020 at 8:35 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    I documented this exact same thing in a post a couple of months ago, when I drove across the country from CA to NC and then back to CA. It is exactly as you said, but in my case, when driving through the states where the max speed limit was 65, my gas mileage went way up to between 28-30mpg, which I was quite happy about! If you really wanna get sick though, put the current gas mileage indicator on the dash screen, and watch it CRASHDIVE when you go uphill and the dang transmission downshifts TWO GEARS and as you said, the RPMs go from around 1700 up to about 3300! Believe me, once I got back and had to take mine in for the 10,000 mile checkup, that was one of the things I complained about to the dealer, not that they could do anything about it. I just wanted them to hear it for probably the umpteenth time, so maybe they would relay it to Toyota. Probably won't happen, but hey, if nobody says anything, then Toyota will assume they have a great transmission, which they don't. But also, I NEVER use the DRCC, but the classic cruise control, which as someone else said, is activated by holding the push button for 2-3 seconds, until you see the dash indicator change to "set", and then it is classic cruise control. To me, as I have said in the past, DRCC completely sucks, and really wish at the very least, that I could change the "default" push button setting for a quick-push, from DRCC to Classic Cruise Control, instead of the way it comes with DRCC being the default. I hate it!
  10. Jan 2, 2020 at 8:36 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Like others have said, low tire pressure, AT tires, lifts, winter gas, winter winds will all degrade your MPG
    GreyBaldTaco likes this.
  11. Jan 2, 2020 at 9:11 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    OP, how many miles are on your truck? Has the transmission learned yet?
    i have the manual tranny, even i have to downshift on hills (with much lower gearing than the auto) — the 3.5l just doesn’t have much torque at lower rpms, especially on the stock tune — so it’s going to downshift to maintain speed, especially going uphill
    davidstacoma and Meridius like this.
  12. Jan 2, 2020 at 9:28 AM
    bcgill
    bcgill Well-Known Member
    Ben
    Blacksburg, Virginia
    2019 SR 3.5L V6 4x4 Magnetic Grey
    I've noticed with driving in the mountains/hills (I live in SW Virginia), I can do better than the cruise control with the gas mileage on the highway. Though my fuel economy with cruise control has never been as bad as you reported and I'm running heavier tires than stock. With cruise control its typically 17-18 mph and I usually can get 20-21 mph if I'm controlling the gas.
  13. Jan 2, 2020 at 9:42 AM
    Ariesgtturbo
    Northern Illinois
    9k. Im sure it has learned. Local driving I am in the 17mpg.
  14. Jan 2, 2020 at 9:44 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    What mods do you have?
    Lift, tires, nard or soft bed top
  15. Jan 2, 2020 at 9:46 AM
    #35
    Ariesgtturbo
    Northern Illinois
    265/70R17 Wildpeaks with -12mm offset
    Softtopper Bed Cap.
  16. Jan 2, 2020 at 9:53 AM
    #36
    Tallgrass05
    Tallgrass05 Well-Known Member
    The transmission on my 2018 Tacoma was a little shifty until it had several thousand miles on it. And you won't get great gas mileage at 75 mph.
  17. Jan 2, 2020 at 11:07 AM
    #37
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    When cresting an incline, lightly tap the accelerator pedal and the truck will shit into a higher gear.
  18. Jan 2, 2020 at 11:44 AM
    #38
    Kinetic
    Kinetic Well-Known Member
    Kent
    Boerne, TX
    2019 Black Tacoma Off-Road
    Haven't had any issues here. Long trips and cruise control are when I get my best mileage!
  19. Jan 2, 2020 at 11:47 AM
    #39
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    I have a '17 offroad and as someone said previously, the cruise control (not adaptive, normal) does not equate to decent gas mileage. It tries really hard to get bcak up to the set speed and will reduce gas mileage relative to not using it. So I don't think it's a function of the adaptive cruise control, but just how Toyota programmed the non-adaptive responses.
    I've basically given up on using it as it's kind of annoying how it works.
    PhenixFord and Two4Runner like this.
  20. Jan 7, 2020 at 8:46 AM
    #40
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    I have the same problem, same complaint. I have a 6 mile 10 minute drive to work that is flat with 2 stops and I cant get better than 17.5 mpg no matter how hard I try. It does do better once warmed up and no cruise but I really have to drive it light. Its 2020, we have all these awesome safety features... why does cruise still suck so bad in every automatic car?
    Can anyone confirm if OVtune fixes this problem, maybe the gear lock feature?
