+2019 Factory head Unit add amp
Discussion in 'Audio & Video' started by Jst193, Jan 24, 2022.
  1. Jan 24, 2022 at 8:17 PM
    Jst193
    Jst193 [OP] New Member
    2022 Double Cab
    So I’ve been doing some reading & research on here & so far I have haven’t had any lucky finding a harness to use to keep my factory head unit and add a 5 channel amp.
    I did the $250 speakers upgrade adding kicker tweeters & door speakers and I’m waiting for a 10inch Rockford fosgate shallow sub to come in.
    I’m looking to install a 5 channel amp to power everything. I don’t need crazy power, I’m thinking between 600-1000 watts for everything. Also with dsp so i can make it nice and clear. I have some experience with wiring things like fog lights, LED’s, back up cameras and general stuff but I don’t feel comfortable building a harness without really knowing what to do. Has anyone found a plug & play harness for a 2022 head unit or should I just take it to a local shop and have them build me one. Thanks in advance!
  2. Jan 26, 2022 at 6:46 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Welcome to TW.:hattip:
    I'd suggest going to a junkyard and seeing if there are any 3rd gens. If so, remove the radio and cut the harnesses. I say plural because my '06 has 2 plugs for the speakers.
    Nice and clear..... Costs $$, as @dolbytone mentioned in another thread using the stock head unit. That money would be better invested in a new head unit imo.
    A new head unit will be free of the built in equalization, and give you one to work with, more than likely. You also get RCA outputs which is a much cleaner signal going to the amps.
    I replaced the 6 disc changer in my '06 with a single din Kenwood excelon. Radio and everything to install it, with the steering wheel adapter cost about 350. I have a friend who installs and got somewhat of a break, not a whole lot. So, ymmv on cost. And, I installed it myself. You can spend big bucks on a head unit, so it'll be good idea to list out the things you need, vs the things you want, it you decide to go this route.
    I knew swapping the radio was going to be an improvement, but oooooomfg; I couldn't believe what these crappy stock speakers sound like. Channel separation, a wee bit of thump l, lol. Huge huge improvement.
    It's only gonna get better from here.
    Good luck.
    ZMan2k2 likes this.
  3. Jan 26, 2022 at 7:03 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    This is the comment referenced. That said, I used an AX-DSP-TY3 harness to add all of the aftermarket stuff in my 2020 4Runner because I’m not convinced I was going to retain all functionality with an aftermarket. Your 2019 probably does not use this same harness, you have to verify which version applies to your specific radio.
    This is the thread I’m using for that project:
    https://www.tacomaworld.com/threads/2020-entune-factory-integration.691221/
    ZMan2k2 and Larzzzz like this.
  4. Jan 26, 2022 at 7:22 AM
    Larzzzz
    Larry
    MA
    Thank you sir.
  5. Feb 11, 2022 at 11:32 AM
    DirtyGovnuh
    DirtyGovnuh Well-Known Member
    2021 TRD OR DCSB 4x4
