2019 Lone Star Toyota Jamboree @ Barnwell Mountain, Gilmer, TX May 2nd-5th
Discussion in 'Off-Roading & Trails' started by ETXTacoma, Jan 1, 2019.
  1. Apr 16, 2019 at 1:07 PM
    #821
    ETXTacoma
    ETXTacoma [OP] Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Why does everyone have to be running 16s
  2. Apr 16, 2019 at 1:12 PM
    #822
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I’ve got 17’s
    ETXTacoma[QUOTED][OP] likes this.
  3. Apr 16, 2019 at 1:13 PM
    #823
    ETXTacoma
    Steven
    Tyler, Texas
    Because you are a baller.
    But do you want to buy some tires lol.
  4. Apr 16, 2019 at 1:16 PM
    #824
    BulletToothTony
    Ha, far from it! 295’s would be too small for the runner I think.
  5. Apr 16, 2019 at 1:42 PM
    #825
    ETXTacoma
    Steven
    Tyler, Texas
    Nawwwwwwwwwwwwwwww not at all!
  6. Apr 16, 2019 at 2:03 PM
    #826
    ChadsPride
    Sponsored by TacomaWorld.com
    :drool:
    ETXTacoma[OP] likes this.
  7. Apr 16, 2019 at 7:37 PM
    #827
    Texas-Elvis
    Texas-Elvis "Checkers, or Wrecker"
    Elvis
    Republic of Texas
    86 1stGen 4-Runner; Restored."Sand-Flea" 93 PU; RIP. 83 1st Gen Hilux
    In preparation for Jambo, here is a small sample of the presentation that I will be offering on Friday. I am honored to offer two sessions covering "Radio Communications on the Trail"
    This has become a common issue during wheeling weekends, so thought I would share to provide a little self help.
    Some of this content is courtesy of the following
    Radioreferance.com
    Wikipedia.com
    Motorola.com
    But…. If we are both on channel ONE; why can’t we communicate?
    That’s a great question, and a common problem
    Believe it or not, there are a number of reasons this can happen..
    The Channel to Frequency assignments have evolved, and in 2017 the FCC swizzled the FRS and the GRMS frequencies.
    Channel “ONE” on old FRS; and old GRMS channel “ONE” are on different frequencies. See the chart below. (I highlighted a common frequency, as an example)
    GEEZZ.. How do I tell if I have old VS new frequencies?
    Good question, spunky..
    The documentation included with your radio will list the channel VS the actual frequency.
    You can see, this radio is programmed to the 2017 standard, but was manufactured over 10 years ago.
    OK; we have old FRS and GRMS radios, so we just need to select FRS ONE and GRMS NINE and we are all peachy!
    Hold on, Buckaroo. Not quite.
    Another common problem, is the enablement of a “PL” tone.
    CTCSS is often called PL tone (for Private Line, a trademark of Motorola), or simply tone.
    Continuous Tone-Coded Squelch System or CTCSS is one type of circuit that is used to reduce the annoyance of listening to other users on a shared two-way radio communications channel. It is sometimes referred to as tone squelch. It does this by adding a low frequency audio tone to the voice. If your radio is not set to “Monitor”, “open squelch” or pass audio; CTCSS circuitry mutes those users who are using a different CTCSS tone or no CTCSS. It is sometimes incorrectly referred to as a sub-channel because no additional channels are created. All users with different CTCSS tones on the same channel are still transmitting on the identical radio frequency, and their transmissions interfere with each other, however the interference is masked under most (but not all) conditions. The CTCSS feature also does not offer any security.
    Family Radio Service (FRS), PMR446 and other consumer-grade "bubble pack" radios often include a feature called "Interference Eliminator Codes", "sub-channels", or "privacy codes"
    Adding tone or digital squelch to a radio system doesn't solve interference issues, it just covers them up. Interfering signals masked by tone squelch will produce apparently random missed messages. The intermittent nature of interfering signals will make the problem difficult to reproduce and troubleshoot. Users will not understand why they cannot hear a call, and will lose confidence in their radio system. In a worst-case scenario in a life safety environment a missed message, or a misunderstood message, may result in fatalities.
    Using coded squelch systems can prevent weak signals from being received, for example, when the person transmitting or receiving is in an area obstructed by buildings or terrain or is a long distance away. A well-tuned receiver that isn't configured to require CTCSS or DCS tones to open the squelch might still carry the weak message along with static noise, while a coded squelch enabled receiver may not perceive the tones and will ignore the message entirely.
    OK. I get it. If I have “PL”, “Tone“ , “Privacy code”, “Sub Channels” or whatever else, we just need to set that number to the same value on both radios?
    Almost, Skippy. Almost.
    Unfortunately.. GMRS/FRS radios offering CTCSS codes typically provide a choice of 38 tones, but the tone number and the tone frequencies used may vary from one manufacturer to another (or even within product lines of one manufacturer) and should not be assumed to be consistent (i.e. "Tone 12" in one set of radios may not be "Tone 12" in another). When a radio offers more than 50 codes (121 is becoming common), the higher ones (e.g. 39–121) are usually DCS codes.
    Holy Radio Waves, Batman.. what will we do!!
    The solution is most simple, Favorite son..
    Disable all “tone” codes on all of your radios. So what, if you hear someone else on your frequency. At least is someone calls for recovery, you could respond.
    Below is the display of a typical radio.
    Set the Channel to a Channel that you have verified as “common”. Set the “Code” number to ZERO, or NONE.
    HEY.. I can hear you now! Can you hear me?
    Yes Skippy; I can hear you.. Now, go get a strap.. I’m high centered…Again
    Ch78, BuzzMor, MellyMel and 4 others like this.
  8. Apr 16, 2019 at 8:44 PM
    #828
    tex.proud
    tex.proud Jesus Christ It's Midnight!
    Huntsville, TX
    2018 White SR5 4X4
    3" OME lift with SPC UCA's HD Dakars Shrockworks Sliders KO2's 165/75/16 Decked bed system CaliRaisedLED mount for Everhardt CB Antenna President Bill FCC CB Yaesu FTM-400 HAM radio and Larsen antenna through roof. TVD Vinyl Decals for the tailgate (Black Reflective) and U.S. Flag decals SofTopper (Black) Empyre Offroad Grill Blacked out badges (PlastiDip)
    Very good info here! May I ask that you post it also in this thread? As it IS a common issue, that you addressed very well!
    https://www.tacomaworld.com/threads/trail-comms-what-and-how-hopefully-a-sticky.603601/
    KG5TNK
  9. Apr 18, 2019 at 10:41 AM
    #829
    Texas-Elvis
    Elvis
    Republic of Texas
    GPS map for Barnwell Mountain
    Post up your favorite choices..
    Here is one I used last year.
    Plus: Zero cost
    Super Plus: Seemed to be accurate
    For Android and IPhonies
    MAPs Me
    https://maps.me/
    Step one: Install from your store of choice. (no cost, Free)
    Step two: Enable GPS
    Step Three: Start app, and it should prompt you to download a map, for the area you are in (determined by GPS).
    You can also select:
    Menu: Download maps:
    select United States: Texas (The Great State of)
    and then select "Tyler". Gilmer is located in the "Tyler" map data set.
    Step Four: Once installed, just scroll to Gilmer, then Barnwell; and you will see the trails appear.
    Ezy Pzy
    OK
    Your turn :)
  10. Apr 18, 2019 at 11:08 AM
    #830
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Cool, just did it
    ETXTacoma[OP] and ChadsPride like this.
  11. Apr 18, 2019 at 1:55 PM
    #831
    tex.proud
    Huntsville, TX
    2018 White SR5 4X4
    I had ordered an OHV sticker from Texas Parks and Wildlife web site. A month later no sticker, so I shot them an email. 2 weeks later still nothing, so I drove down to Conroe to buy one. TP&W resent one so i have an extra to bring with me in case someone needs it.
  12. Apr 18, 2019 at 2:06 PM
    #832
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    I'll pick it up from you
  13. Apr 18, 2019 at 2:13 PM
    #833
    tex.proud
    Huntsville, TX
    2018 White SR5 4X4
    You got it!
  14. Apr 18, 2019 at 2:13 PM
    #834
    tex.proud
    Huntsville, TX
    2018 White SR5 4X4
    Nice! Downloaded.
  15. Apr 18, 2019 at 2:14 PM
    #835
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Any chance I could get that from you prior to Jambo?
  16. Apr 18, 2019 at 2:15 PM
    #836
    tex.proud
    Huntsville, TX
    2018 White SR5 4X4
    Sure. I'm actually off work early if you want to meet somewhere this evening, or I'll be around this weekend.
  17. Apr 18, 2019 at 2:17 PM
    #837
    jlusmc
    James
    Huntsville, TX
    97 Reg Cab SAS
    Sending you a PM
  18. Apr 18, 2019 at 2:29 PM
    #838
    CarmenSanDiego
    CarmenSanDiego Battle Tank
    Kelly
    Dickinson, TX
    2011 MGM 4Runner Limited 4x4
    Bilstein 5100's OME HD Springs Shrockworks Sliders Addicted Offroad Front Bumper Proline 4x4 Rear Bumper CBI skids Black Rhino Armory wheels
    Me too...
  19. Apr 18, 2019 at 2:39 PM
    #839
    Texas-Elvis
    Elvis
    Republic of Texas
    would one of you wonderful citizens REMIND ME to purchase my OHV sticker when I'm at the park?
    (Thank you)
  20. Apr 18, 2019 at 3:01 PM
    #840
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I had purchased one from their online site as well and never received it, bought another one from 4wheel parts.
