2019 OR Propeller Shaft: No Zerks for DIY Lubrication?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ddanjeong, Dec 8, 2020.
  1. Mar 6, 2023 at 6:30 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If it only has one zerk on the front shaft, it might have had one u-joint replaced. Hard to say which one, as your model was in the phase-out period, IFAK.
    Ben J[QUOTED] likes this.
  2. Mar 6, 2023 at 6:42 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is a good article on greaseable vs. non-greaseable joints.
    “Bottom line on strength: The non-greaseable joint is slightly stronger than a greaseable joint. The exact number, how much stronger, is unknown and we do not believe it to be very significant.
    Bottom line on wear life: A regularly greased greaseable joint will outlive a non-greaseable joint. But a non-greaseable joint will outlive a greaseable joint that does not get greased properly.”
    https://4xshaft.com/blogs/faq/greaseable-vs-non-greaseable-joints-which-is-better
    Ben J, bulalo and splitbolt like this.
  3. Mar 11, 2023 at 1:03 PM
    Ben J
    Ben J Member
    You were right. The second one is there - just didn't look for it long enough the other day. thanks for your expertise.
    splitbolt[QUOTED] likes this.
