2019 SR5 Engine Knock / Burning Oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoNJ92, Apr 2, 2025.
  1. Apr 2, 2025 at 9:24 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
  2. Apr 3, 2025 at 5:21 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
  3. Apr 3, 2025 at 5:25 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I’m a little late to the party but where are you located? Im guessing NJ based on your user name?
    TacoNJ92[QUOTED][OP] likes this.
  4. Apr 3, 2025 at 6:15 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Answer: No.
    2 million trucks sold from 2016 to 2023, and less than a hundred here. Many of whom, like OP, only signed up to report an issue. I’m sure others exist outside of this list, but held up to a statistical light, your list ironically only supports a case of how reliable the 3.5 actually is.
    OP’s situation illustrates that crap can happen to some unfortunate souls, even on otherwise reliable trucks. I hope it works out.
    Beyond that, it’s 2025, so if you still don’t like Gen3, maybe just consider letting it go. Or, hate on Gen4, whatever.
  5. Apr 9, 2025 at 8:55 AM
    TacoNJ92
    TacoNJ92 [OP] Member
    @Road_Warrior , yes I’m located in NJ
    Here’s an update of what’s going on.
    Toyota dealership #1: engine has a knock in the lower block. Needs new engine. $12,000 parts and labor + tax for salvage engine with 8000 miles.
    Toyota dealership #2: same diagnosis as above, in addition to a timing cover that’s leaking oil “like crazy”.. for the exact same salvage engine listed above, they quoted me $16,500.
    Close-friend Mechanic: the engine knock is coming from the driver side cylinder head. Needs new engine. Power steering fluid from the pump is what was leaking “like crazy”. Engine is burning oil likely near timing cover.
    At this time I am considering running the engine until something catastrophic happens. Shitty part is that I took a loan out for this vehicle, and a new engine is pretty tough for me at this time. Not saying I’m not going to do it in the near future, (sooner than I want to, lol), but I wonder how many more miles I can get out of this one? This engine knock has been around for over a month or 2 now and it’s been running just fine. Only reason I brought it in to be looked recently is because it suddenly got louder one day and it was because I was burning/leaking oil (smoke at start-up). I also had to replace the coil on cylinder 4 as it died on me one evening a month ago. I know running it with a knock isn’t the best idea, I’m well aware of what that is. But what’s the worst that can happen? I need a new engine? We know that already lol.
  6. Apr 9, 2025 at 9:41 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I’d throw in some 15w-40 oil and see how long it lasts. That will likely help it last longer if it’s currently eating itself. And it’ll at least burn less oil.
    If the noise is something easy like a tapping/stuck lifter, thicker viscosity oil might help that too by pumping the lifter back up. Worth a shot. They did say it’s in the block so it’s probably not a lifter anyways, but thicker oil could prolong how long it takes to grenade.
  7. Apr 9, 2025 at 9:45 AM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    It might be more of a concern as to "when" that catastrophic failure might happen. For example, in a very unfortunate location or possibly even a situation that could prove to be dangerous.
  8. Apr 9, 2025 at 9:49 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Something to consider....
    Obviously funds are an issue...
    If you continue to drive it & its burning oil, you are contaminating your cat converters...
    So by the time you get around to throwing an engine at it, you will also potentially need cat converters too & theyre VERY costly...
    Not worth the gamble....
    Not trying to throw salt in the wound, just trying to educate & help with the wound not getting worse...
    STEELeR43 likes this.
  9. Apr 9, 2025 at 9:55 AM
    slater
    San Diego
    & if a truly catastrophic failure does occur like piston coming apart & contaminating the entire motor with shrapponal that will require additional parts like an intake manifold assy......
    Just turns into a more costly shit sandwich....
    Or if engine seizes, more labor involved to unseize engine prior to removing so you can access all the torque converter nuts, or more extensive teardown to remove engine with torque converter...
    if its an auto...
    If it's a stick, dont throw an engine at it without replacing the clutch. Thats suicide even though yes, another added expense...
    TacoNJ92[OP] likes this.
  10. Apr 9, 2025 at 10:01 AM
    TacoNJ92
    This was my next concern. Does driving with this knock lead to any stress or damage to the transmission? My truck is automatic.
  11. Apr 9, 2025 at 10:12 AM
    slater
    San Diego
    Stress to the trans? Ide say not really...
    Unless its on the verge of seizing due to wasted crank bearings.
    But if she truly is smoking as stated, cat converters are super costly...
  12. Apr 9, 2025 at 2:08 PM
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    at this point running your truck until it blows up is not a good idea unless you plan to scrap it afterwards and buy a new one and i wouldn't drive it too far from home, it is going to strand you one way or another.
    slater and TacoNJ92[OP] like this.
  13. Apr 9, 2025 at 5:55 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    OP , a few questions how much oil are you burning ? Also I know you say you have a knock , can you tell me about it . If your in park and rev the motor does it speed up and get louder as the revs come down ? When the engine under load does it get quieter.? Also , all these people that checked this truck how did they determine what failed ?
  14. Apr 9, 2025 at 6:05 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, if you do decide to drive it until it grenades keep a watch on the engine temp cause if it runs hot you could cook the auto transmission and I agree with others with it smoking you will trash those expensive cats.
  15. Apr 9, 2025 at 9:46 PM
    #35
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Assuming worst case scenario.
    Truck is 6-7 years old close to 100k miles.
    As much as we'd all like 200k minimum and a decade of excellent service there are times when you gotta let go.
    $12,000 ( plus incidentals ) into another engine or $12,000 down on a lightly used 2022 or 2023 is where I'd be snooping.
  16. Apr 10, 2025 at 7:40 AM
    #36
    TacoNJ92
    my previous mechanic told me I burned about 2 quarts in half an oil change, so about 2500 miles. The knock is a light tick coming from the driver side cylinder head. It can be heard at idle and when revving. The noise is pretty quiet when the oil levels are normal, but as oil levels drop overtime, it gets louder. no concrete answer on what it is, just recommendations of the new engine. All my mechanics I have visited that said they won’t be able to determine what is knocking until the engine is stripped apart. I’m driving it now and I don’t even hear the knock unless I’m at a complete stop where there’s no background noise.
  17. Apr 10, 2025 at 7:41 AM
    #37
    TacoNJ92
    While I agree with you, I still owe money to the loan for this truck. A decent amount too
  18. Apr 10, 2025 at 8:00 AM
    #38
    2021SR5V64WD
    Yikes.!
    Well I hope it all turns out for you.
