2019 Tailgate Lock - PN: PK3B6-35JS0
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Goncalves_Taco, Nov 7, 2019.
  1. Nov 8, 2019 at 5:23 PM
    #41
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Can you post a picture of the wires for the connectors?
  2. Nov 8, 2019 at 5:25 PM
    #42
    baldbeardedtaco
    FL
    It’s not that- they made a part specifically to pass 2 harnesses through so no modifications necessary
  3. Nov 8, 2019 at 5:30 PM
    #43
    Goncalves_Taco
    Goncalves_Taco [OP] Well-Known Member
    2017 Black Tacoma TRD Sport
    Amen to that!
  4. Nov 8, 2019 at 5:57 PM
    #44
    caribe makaira
    Caribbean, Puerto Rico
    Seems the UNLOCK (4) color changed or it may be to ID to the Y harness...:notsure:
  5. Nov 8, 2019 at 6:24 PM
    #45
    baldbeardedtaco
    FL
    It’s shouldn’t matter if the color changed so long as it’s the correct wire for the function correct? Do you have one of those connector diagrams for the 2020 to compare?
  6. Nov 8, 2019 at 6:25 PM
    #46
    caribe makaira
    You are correct, it shouldn't matter.
    Not yet:playball:
  7. Nov 8, 2019 at 6:34 PM
    #47
    Goncalves_Taco
    I agree different colors shouldn't be a deal breaker but comparing the current wire diagram mentioned along with a '19+ to ensure they are in fact for the same unlock function would be ideal :)
  8. Nov 8, 2019 at 6:38 PM
    #48
    Goncalves_Taco
    Something caught my eye; wire 3 is green and wire 4 (from the diagram appears light green)...maybe the wire change was just for practical purposes (why have two wires next to each other so close in color!)
  9. Nov 8, 2019 at 7:11 PM
    #49
    caribe makaira
    4 is LIME green...:D and to screw with color-blind folks...
  10. Nov 9, 2019 at 5:46 AM
    #50
    caribe makaira
    Thanks:hattip:
    Awaiting the reveal:popcorn:
    BadFlounder[QUOTED] likes this.
  11. Nov 9, 2019 at 8:33 AM
    #51
    caribe makaira
  12. Nov 9, 2019 at 9:06 AM
    #52
    caribe makaira
    I'm thinking fuses are to "blow" if rear collision occurs...
    BadFlounder likes this.
  13. Nov 9, 2019 at 9:20 AM
    #53
    Goncalves_Taco
    So are we thinking this'll be plug n play for '16-'18...
  14. Nov 9, 2019 at 9:21 AM
    #54
    caribe makaira
    90%...:rofl:
  15. Nov 9, 2019 at 9:26 AM
    #55
    caribe makaira
    If @BadFlounder would open the fuse holder and remove the fuses, then check continuity from fuse pins to connectors.
  16. Nov 9, 2019 at 9:59 AM
    #56
    caribe makaira
    For those without this harness but are contemplating the other choices, you can do this:
    Acquire these connectors (x2 pairs), they are on the Tundra and the 2nd Gen Tacoma tail lamps(and other vehicles) and remove the pins from BN1 to the new 6 slot connector, hide the wires in same loom. One exit, removable tailgate...
    Vttroy likes this.
  17. Nov 9, 2019 at 12:42 PM
    #57
    baldbeardedtaco
    FL
    The purpose of that would be to? Prevent a short in the passenger door lock/unlock cycle or
  18. Nov 9, 2019 at 1:04 PM
    #58
    caribe makaira
    That's my thought, in case of rear end collision or similar, the fuse would perform if wires are grounded and you could still unlock the doors via door switch or FOB. (Especially the rear passenger doors)
  19. Nov 9, 2019 at 1:15 PM
    #59
    baldbeardedtaco
    FL
    That makes sense I suppose. so a fuse for each wire is why it would have 2 fuses then
  20. Nov 9, 2019 at 1:23 PM
    #60
    caribe makaira
    Don't know for sure, I don't have the harness to verify or any other info. Waiting on BadFlounder...
