2019 Tailgate Lock - PN: PK3B6-35JS0
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Goncalves_Taco, Nov 7, 2019.
  1. Jan 28, 2021 at 11:17 AM
    #641
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    I will, once the truck is here Monday :)
  2. Jan 28, 2021 at 11:20 AM
    #642
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    For what it's worth I got mine (https://www.oempartsource.com/oem-parts/toyota-tailgate-lock-remote-super-long-wheelbase-pk3b635jl0) from OEM Part Source. After shopping around, their shipping cost was the cheapest for me
    farmtacoma[QUOTED] likes this.
  3. Jan 28, 2021 at 11:41 AM
    #643
    ToyoProTaco
    ToyoProTaco Well-Known Member
    2020 Magnetic Gray Metallic Tacoma TRD Pro
    The '20 + bed lights have a harness behind the taillights so there is no conflict with the tailgate lock kit.
    PK3B6-35JL0 says fits "2019-21 Tacoma Double Cab Longbed". It's a relatively easy install. The worst part was running the wires to the front and through the floor which really wasn't that hard to do. There are metal zip ties for the area that runs past the exhaust. Everything is included, easy plug and play.
  4. Jan 28, 2021 at 11:43 AM
    #644
    farmtacoma
    Julia
    Great, will order it up. Appreciate the confirmation
    I saw the video on youtube. All of it seems simple, ONLY part that confused me is where you have to bolt the actuator part.
  5. Jan 28, 2021 at 11:58 AM
    #645
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Once you take the tailgate apart and see the mount for yourself, positioning the actuator to match it to the picture in the instructions it will all make sense.
    Download a copy of these and read though it as you watch the video. Even though its labeled for a shortbed the instructions are the same for a longbed, you just have more zip ties in the kit and a longer cable harness from the tailgate to the cab.
    catalina34 and daveeasa like this.
  6. Jan 28, 2021 at 12:06 PM
    #646
    farmtacoma
    Julia
    Ah ok!
  7. Jan 28, 2021 at 4:32 PM
    #647
    mrCanoehead
    mrCanoehead Well-Known Member
    Ottawa
    2018 DCSB Sport manual 3.5 l
    I installed KTJO's kit but my camera has never been pointed right since I installed it. Do you think it would be feasible to use the existing wiring with the Toyota actuator, to avoid re-pulling the harness?
  8. Jan 28, 2021 at 4:34 PM
    #648
    MtRainier
    MtRainier Well-Known Member
    Randy
    Seattle, WA
    2021 Super White TRD Off-Road 4X4
    just picked up the part today. Tomorrow is install day. Very excited to not have to manually lock my tailgate.
  9. Jan 28, 2021 at 4:34 PM
    #649
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    No idea how KTJO's kit is wired and if the actuator plugs are the same.
  10. Jan 28, 2021 at 4:35 PM
    #650
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    The harness is 2 wires. The OEM version has fuses and OEM connectors and gaskets and a billion zip ties but it's still just + and - which when pulsed does the lock/unlock. I can't imagine that the ktjo or pop-n-lock is fundamentally different, the lock pulse comes from the vehicle.
    Assuming you splice in with something weatherproof (solderless butt connectors perhaps) you should be fine if you get polarity right (test first?)
    mrCanoehead[QUOTED] likes this.
  11. Jan 28, 2021 at 4:42 PM
    #651
    mrCanoehead
    Ottawa
    I'm going to give it a shot. I will solder/heatshrink.
    Does the Toyota bracket use the same mounts as the camera? That is the issue I have, I think KTJO's bracket is wonky and I was not able to point the camera straight however many times I reinstalled it and tried to make it "flat."
  12. Jan 28, 2021 at 4:45 PM
    #652
    daveeasa
    David
    PNW
    I remember looking through my phone for some good photos earlier, will scroll again and post if I have. The installation instructions don't give 100% clarity on the actuator in my opinion, that's one area where one or two extra photos could help.
    I don't remember touching the camera at all, but it's been a while. It's certainly 100% functional as before (see also the license plate light delete in reverse thread for more on backup cameras at night :)
    ETA: Yeah, I looked, I don't have any photos of the inside of the tailgate, sorry.
  13. Feb 10, 2021 at 6:21 AM
    #653
    TravisMD
    TravisMD Well-Known Member
    2020 DCSB TRD OR Black
    upTOP Bravo Rack BAKflip G2 Tonneau Cover
    Does anyone have the pdf instructions?
  14. Feb 10, 2021 at 6:55 AM
    #654
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    Have had mine on for awhile now and working great. I decided to run the harness along with Matt Gecko's bed lighting kit to save me time one shot. No issues so far and haven't had any problems. Like the rest of us, Toyota should make this standard on the Tacoma.
  15. Feb 10, 2021 at 10:29 AM
    #655
    AZPhys13
    Here is the PDF
    Extrakrispy and TravisMD like this.
  16. Feb 10, 2021 at 10:44 AM
    #656
    TravisMD
    Thanks my man
  17. Feb 10, 2021 at 11:18 AM
    #657
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Glad I found this thread. We just got a 2021 TRD Sport double cab short bed and the whole short vs long version of the kit had me confused. Short it is. Thanks all
  18. Mar 8, 2021 at 7:35 PM
    #658
    coolrunnings82
    coolrunnings82 Member
    Tim
    Tucson, AZ
    2017 DCSB SR5 Automatic
    Hey thanks for this thread! I picked up the part for my 2017 SR5 DCSB and installed it this evening. It worked perfectly. The only odd part was as mentioned elsewhere in this thread: the body harness is on the driver side not the passenger side on SR/SR5 models so I had to make my own was for zip tie attachments. I'll check on it after a few hundred miles and see how things are hanging in there. Overall very happy about this being a factory part and relatively simple to install. Also I found this video incredibly helpful:
    https://www.youtube.com/watch?v=gz-8j4S3Dkw
    (just ignore the horrible music - the rest is great)
  19. Mar 11, 2021 at 9:54 AM
    #659
    JoeS3845
    JoeS3845 Member
    Joe
    21 Tacoma TRD
    Stock
    I just installed mine today. I was dreading taking the front passenger moulding out without breaking it. Turns out the worst part is putting the wires back in the bezels at the tailgate. About 2 1/2 hours taking my time and double checking my work. Also, when putting the actuator in the tailgate the handle slightly moves so its a pain getting the screw in the hole.
    Taco_mike73 likes this.
  20. Mar 11, 2021 at 10:00 AM
    #660
    cspcrx
    Awesome. I am with you those two plastic protectors by the tailgate were not fun. I also found my wife could get her hands under the carpet to feed the harness through much easier than I could.
    coolrunnings82 likes this.
