2019 Tailgate Lock - PN: PK3B6-35JS0
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Goncalves_Taco, Nov 7, 2019.
  1. Nov 10, 2019 at 5:31 PM
    #81
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    The bed lights wiring harness runs down the driver’s side and up under the drivers seat. The wiring is then tapped into wiring on the driver side kick panel. At least that is the way it is on my 2019 dcsb sport.
  2. Nov 11, 2019 at 6:15 AM
    #82
    monkman
    monkman Well-Known Member
    New York
    Looks like you're right. So then what if any is the conflict with the bed lights? I would love to get the OEM kit instead of Pop 'n Lock. Thanks.
  3. Nov 11, 2019 at 3:55 PM
    #83
    Goncalves_Taco
    Goncalves_Taco [OP] Well-Known Member
    2017 Black Tacoma TRD Sport
    here is the install guide for the 2020 bed lights! Interesting enough they say there's is no conflict with the oem tailgate...take a look.
    Frosti II likes this.
  4. Nov 11, 2019 at 9:33 PM
    #84
    BadFlounder
    BadFlounder Well-Known Member
    Colorado
    2020 MGM TRD Pro
    That’s the question we’re still working on. It seems like it should work fine given all the evidence we’ve seen to this point but no one has installed it yet. I was hoping to install my kit last weekend but ran out of time. Hopefully I can get to it soon.
  5. Nov 11, 2019 at 9:45 PM
    #85
    BadFlounder
    Colorado
    2020 MGM TRD Pro
    Excellent find with the manual once again. So this confirms what has been mentioned in the part number thread, that the 2020 is pre-wired for the new 2020+ bed lighting kit. That will be cake to install on a 2020, and I see nothing that would interfere with the remote tailgate lock.
    I still have no idea why it says the bed lighting kit conflicts in the remote lock install guide. It must be specifically referring to 2019 since they use a different bed lighting kit than the 2020+? But then what about the older kit is a conflict?
  6. Nov 15, 2019 at 11:10 AM
    #86
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    It looks like the part number for the DC LB is PK3B6-35JL0
    S for Short and L for Long I guess.
    crnasdaTaco, Tmaloy and BadFlounder like this.
  7. Nov 15, 2019 at 1:25 PM
    #87
    Goncalves_Taco
    any thoughts to what the worst case scenario might be if someone was to try this '19 OEM pop n lock on a '16-'18; based on what's been mentioned it seems like a good chance it might work....looking for thoughts
  8. Nov 15, 2019 at 1:39 PM
    #88
    dilbert
    dilbert AI Member
    PNW
    Worst case scenario is that it wouldn't work. Follow through the instructions posted in here and if you can confirm that the grommet into the cab is available and the plugs that it ties into match the photos, then you could reduce some of the risk.
    If you buy the kit, you could assemble everything out of the vehicle, and plug it in behind the kick panel to test if it functions. This way, if it doesn't work, you wouldn't have wasted a bunch of time routing wires.
  9. Nov 15, 2019 at 1:52 PM
    #89
    dilbert
    dilbert AI Member
    PNW
    I suppose this could be the worst case scenario though...
  10. Nov 15, 2019 at 4:18 PM
    #90
    caribe makaira
    Caribbean, Puerto Rico
    OP, you have the harness yet? Could you verify the fuse to connectors relation?
  11. Nov 16, 2019 at 5:38 PM
    #91
    Goncalves_Taco
    Yup I'd say that's about it....worse case lol...any excuse to trade up I guess
    ERod27 likes this.
  12. Nov 17, 2019 at 6:45 AM
    #92
    caribe makaira
    :tumbleweed:
  13. Nov 23, 2019 at 3:41 PM
    #93
    BadFlounder
    Colorado
    2020 MGM TRD Pro
    I finally installed the kit today. Works perfectly and the actuator is not nearly as loud as I’ve seen with some of the aftermarket kits. It sounds similar to the other OEM door locks, which is great. No real issues during install either. The instructions are spot on. The only slightly tricky part was running the wiring harness next to the exhaust because that area is not very accessible in some spots. It was difficult to position the 5 metal wire ties because of that! All in all this was an easy upgrade on a 2020 Tacoma.
    One little tip. It’s touched on in the instructions briefly, but when applying the final wire ties under the end of the bed, make sure you wire tie the new bed harness to the camera harness only and not the body harness or truck. That way if you ever need to remove the tailgate it’s a simple matter of unplugging the two connectors (camera and remote tailgate lock) and the harnesses will come out together.
    pp2small, Lowkey, dezdog and 7 others like this.
  14. Dec 10, 2019 at 9:26 AM
    #94
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
  15. Dec 10, 2019 at 9:33 AM
    #95
    monkman
    New York
    My 2020 came with the bed lighting kit. I installed the tailgate lock and have zero issues.
    pp2small likes this.
  16. Dec 10, 2019 at 9:34 AM
    #96
    AZ_Tumbleweed
    Wilmington, NC
    Thanks, mine didnt come with the bed lighting but read the 2020s already had the wiring and just wanted to make sure these two dont conflict for some reason
  17. Dec 10, 2019 at 9:38 AM
    #97
    monkman
    New York
    You should be fine. Bed lighting kit is really nice.
  18. Dec 10, 2019 at 10:45 AM
    #98
    kconeil
    kconeil Active Member
    So is the KTJO kit any easier to install?
    KTJO 4x4 likes this.
  19. Dec 10, 2019 at 10:58 AM
    #99
    monkman
    New York
    The Toyota OEM kit is really easy to do, plus it comes with the special fittings for the wire to pass thru the body of the truck into the tailgate. I would definitely recommend it.
    shakerhood likes this.
  20. Dec 10, 2019 at 11:17 AM
    #100
    kconeil
    ok thanks
