2020 Formula 1 Season Paddock
Discussion in 'Sports, Hobbies & Interests' started by OZ-T, Jan 1, 2020.
  1. Aug 9, 2020 at 3:50 PM
    #781
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    & Grosjean
  2. Aug 9, 2020 at 4:20 PM
    #782
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Finally
    1buzzbait and wdb like this.
  3. Aug 9, 2020 at 5:13 PM
    #783
    OZ-T
    Peter North
    British Columbia
  4. Aug 9, 2020 at 6:09 PM
    #784
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Poor Hulk
    1buzzbait likes this.
  5. Aug 10, 2020 at 1:39 PM
    #785
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I understand why F1 has a single tire manufacturer, why there are only five (or six?) dry compounds, and why teams must use multiple compounds. What I dont understand is why teams are limited each weekend to only the three dry compounds nominated by Pirelli. Why can't each team select whatever mix of compounds they think may work best for each car and driver at a particular track?
  6. Aug 10, 2020 at 1:42 PM
    #786
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    I know, the answer lies within this thread, but from whom ? Peter?
  7. Aug 10, 2020 at 1:42 PM
    #787
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    great question sir
  8. Aug 10, 2020 at 4:11 PM
    #788
    OZ-T
    Peter North
    British Columbia
    i think so Pirelli can designate the compound range they deem to be safe for the different loads on the tires that different circuits put on them , just like how they designate tire pressures and min and max camber settings
  9. Aug 10, 2020 at 7:06 PM
    #789
    wdb
    Dave
    the perimeter
    plain jane
    Typically they can choose how many of each compound. For this last race even that was mandated.
  10. Aug 11, 2020 at 6:21 AM
    #790
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    The reason for one tire supplier is $$$. As mentioned above, pirelli designates the compounds on grounds of performance and safety at each track, the origins of the must use different compounds during the race was a mandatory pit stop and tire selection would improve the spectacle. It was designed to create pit stops and tire strategy. Then refueling during the race went away. Now we have sub 2 second pit stops.
    While it is easy to say pirelli should build better or different tires, they are building what the FIA tells them to build.
    w.adventures and 1buzzbait like this.
  11. Aug 11, 2020 at 7:56 AM
    #791
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I don't buy the performance and safety explanation. The best performing tires aren't necessarily selected for the grid as a whole and certainly not for particular cars. And safety is is covered by Pirelli dictating pressures, etc, and providing teams with expert opinion on tire use. It's probably true that when track conditions are unsuitable for the nominated compounds it is less safe not to mention expensive for some teams. Williams and Haas can ill afford the cost of hitting the wall because they can't make a particular compound work. The back to back races at Silverstone prove the performsnce point. Different compounds were selected simply to "mix things up". So it's not performance unless it's in regard to limiting performance to somehow "improve the show". I don't really see that being the case other than cases like last weekend where it gave Red Bull a leg up over Merc. That was refreshing but this is supposed to be the pinnacle of motorsport and I don't think I'm a fan of seeing a vendor monkeying with outcomes from an office building.
    Suprajim54 and 1buzzbait like this.
  12. Aug 11, 2020 at 8:26 AM
    #792
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    From what I picked up during the post race interviews, it seems that Mercedes was running more downforce than Red Bull which killed their tires. Guess if you have an engine that much more powerful than anything else in the field, you can usually run a lot more downforce. Unfortunately with the temps, and increased tire pressures, it finally bit Mercedes. As soon as Mercedes gets a "cooler" race and not have to worry about tire wear, they will return to completely dominating the field.
    I would love to see F1 come up with a rule that if your engine is down on power, you're free to do any type of upgrade to catch up to the leader instead of limiting upgrades across the field. Now if you just want one team to dominate (like Ferrari with Michael, and now Mercedes), you keep the rules "as is."
  13. Aug 11, 2020 at 9:46 PM
    #793
    OZ-T
    Peter North
    British Columbia
    syswalla, 1buzzbait and mosccat like this.
  14. Aug 11, 2020 at 10:26 PM
    #794
    mosccat
    Mark
    2020 OR
  15. Aug 12, 2020 at 1:56 AM
    #795
    mosccat
    Mark
    2020 OR
  16. Aug 12, 2020 at 3:35 PM
    #796
    mosccat
    Mark
    2020 OR
    I wonder what the odds are for Lewis being knighted one day...
    se7enine and 1buzzbait like this.
  17. Aug 12, 2020 at 11:23 PM
    #797
    NOESHOW76
    NOESHOW76 Active Member
    Kevin
    Northern Illinois
    2020 Tacoma TRD Off Road DCSB
    all times are Falkland Islands Time correct?
  18. Aug 13, 2020 at 2:02 AM
    #798
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    oh, I have been sayin this for a year or two "Sir Lewis Hamilton" I don't think OP like's it though
  19. Aug 13, 2020 at 2:04 AM
    #799
    1buzzbait
    Murph
    murrilin
    98 yamaha grizzly
    :hattip:
  20. Aug 13, 2020 at 6:13 AM
    #800
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It will be soon, if not by the time he's retired he will have the title.
    w.adventures likes this.
