2020 JBL Amp wiring and booster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Smoothmove, Dec 8, 2019.
  1. Sep 9, 2020 at 12:21 PM
    dehydratedEV
    dehydratedEV Member
    2016 Tacoma Basic
    Entune 3.0 w/ Carplay no Dynamic Nav yet,
    Does anyone know if the 2020 JBL entune 3.0 will work with the 2016 JBL equipped truck? I was able to create a harness metra parts, and I was able to get a 2018 Sienna entune 3.0 w/ Carplay to power on in the dash. The only issue I now have is that I cannot hear anything nor can I move the volume up or down. Any ideas?
  2. Sep 10, 2020 at 9:49 PM
    RedRocket4x4
    RedRocket4x4 Dcsb
    SoCal
    Barcelona Red 4x4 Taco
    you need the new jbl amplifier off a
    2020 tacoma i have done this to my 17
    tacoma and i got audio already but it’s not
    100% tho there is still lil kinks to work out
    ericegonz likes this.
  3. May 10, 2021 at 12:24 PM
    TacoHugger
    TacoHugger Member
    Wylie
    20 TRD OR DCLB
    Does anyone know where I can get the 10 pin and 12 pin connectors at the amplifier, so that I can make my own 'plug and play' harness? I want to run the high level outputs into my D-6.1200, then back into the factory harness to connect back the the speakers in the dash and doors. I have a separate amp running my sub. I can cut and splice, but would rather build a harness for some reason. Thanks.
    LQQKITZME likes this.
  4. Jul 15, 2021 at 9:16 AM
    Dan2021
    Dan2021 New Member
    Dan
    2021 Super White Tacoma TRD Pro
    New
    Exact same boat here looking for the 10 pin and 12 pin connectors at the amplifier... any luck?
  5. Jul 15, 2021 at 12:27 PM
    iLLFadedBowl
    iLLFadedBowl Well-Known Member
    2019 Super White TRD Offroad Tacoma
    Remote start w/ vehicle control and locator, Prinsu rack w/ Cali Raised Light Bar and 360 LED lights, LED Bedlights, Tailgate lock, 3" Lift, Wheels and Tires, Raptor Lights, LED headlights and fog lights, Blacked out LED taillights, Front windshield eyebrow tint, Rough country bed molle, 8-gang switch to control LEDS, Dominator D6 running boards/side steps, Blacked out sequential mirror turn signals
    Maybe try contacting idatalink and see if the ato3 harness will work or has the connectors you are looking for. I upgraded my 2019 jbl system using that harness with the maestro ar. Im not sure why it doesnt work for the 2020 tacoma but does for the tundra. Looking at the pictures the 2020 harnesses look like they match mine. Probably wouldnt hurt to contact them and see why those harnesses dont work for the 2020s. They have good customer service.
  6. Jul 17, 2021 at 10:47 AM
    Dan2021
    Dan2021 New Member
    Dan
    New
    Found them both at AutoHarnessHouse.com
    4438 Toyota Factory Amp Upgrade harness 1
    4439 Reverse Toyota Factory Amp Upgrade harness
    $30 - and customer service email responded the same day...
    It's like a sore wiener.
  7. Feb 22, 2022 at 3:47 PM
    sharkytowers
    sharkytowers Member
    2019 Taco TRD Pro
    YES! This is clutch, thank you. Just to clarify - the middle black and top white connectors are routing directly the speakers correct? So if I were to splice on to the correct wire I've got a straight path to each corresponding speaker, right? (I think I know the answer, but just double checking)
    Also... I'm using all new head unit, and all new amps (and speakers for that matter). So can the JBL "amp" be completely abandoned without losing some other functionality? That is to say... is it all audio related on those three connectors? Or is there something random like interior lights or something odd?
    Thanks a ton for your post. I think I found it also at diymobileaudio.com which must have been you as well. So clutch for me. Cheers.
  8. Aug 11, 2022 at 3:48 PM
    captain.cardinal1
    captain.cardinal1 instagram @e11lfd
    chad
    louisville, ky
    2016 trdorsb inferno FTMFW
    Pelfreybilt front aluminum bumper, full Pelfreybilt skid set, Pelfreybilt sliders, hondo garage phone vent mount, icon stage 3 lift, scs rays 10, 285-70-17 ridge grappler, c4 fab mid height bed rack (currently getting powder)
    any answer for this?
  9. Aug 11, 2022 at 3:52 PM
    sharkytowers
    sharkytowers Member
    2019 Taco TRD Pro
    I completely abandoned the amp and still have everything I need. So... it's fine. Just follow the wiring diagram alluded to in this post.
  10. Aug 11, 2022 at 4:48 PM
    captain.cardinal1
    chad
    louisville, ky
    Awesome. Thank you.
  11. Nov 22, 2023 at 6:01 AM
    Taconetti
    Taconetti Member
    Tony
    23 Lunar Rock TRD OR
    I know this is an old post but I’m trying to understand how using a plug and play unit like Trail Grid Pro offers works when installing a new head unit into the jbl system if the jbl system only has a 2 channel input. How would the crossover, balance/fader etc work if that’s true? It would have to have separate inputs not just 2 for those functions to operate. If the jbl amp separates all the speakers out using only a 2 channel input then anything you plug into it upstream would lose the functionality Im talking about. Is this right?
  12. Nov 22, 2023 at 3:39 PM
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    the data path issue with the JBL really stumped me for a long time as i was trying to understand what components were necessary to do a DIY upgrade. i could never really get anyone to diagram it or otherwise explain it in a way that made sense. but what i've gathered over time is that it's a mistake to see the head unit and amp as discrete boxes with a one-way data or signal flow. that's why you can't just take the output of the head unit and discard the amp.
    soundman98 likes this.
  13. Nov 22, 2023 at 9:24 PM
    Taconetti
    Taconetti Member
    Tony
    I spoke with trail grid pro today. They are currently testing a JBL amp bypass that is a plug and play harness. As for my original question, even as it currently stands they have plug and play units that can go through the jbl amp and the crossover built into the new head unit will work as it should so they tell me. There can’t be just a single right and left audio input into the jbl amp. Regardless, it won’t really matter to me because once they roll out the jbl amp bypass I will do that and change out all my speakers and add an amp. This will allow me to utilize all the current wiring installed from the factory. I’ll be buying the Sony xav 9500es from them after the holiday. Cheers.
  14. Nov 23, 2023 at 7:30 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    yes there can. but you're still thinking analogue audio. the jbl system is entirely digital/coaxial input. i understand it to be a proprietary coaxial format to toyota/jbl that doesn't comply with standard coaxial audio standards. meaning that it gets a digitally-encoded left and right audio signal(because the source material here is only a single left and a single right channel), as well as digitally-encoded front/rear/left/right amplitude information, and digitally-encoded head unit eq information.
    the amp deciphers this digital information, divides the incoming signal up per it's active crossover plan, with doubles for front/rear audio partitioning, and then sends it out to the individual amplifier chips which then amplify the signal, and send it out to the individual speakers.
    wradar likes this.
  15. Nov 23, 2023 at 8:42 AM
    #35
    Taconetti
    Taconetti Member
    Tony
    Thanks. Appreciate you explaining it further. Ditching the whole system piece by piece. Strange to me that Toyota would out such a crap system in it with the idea that it’s supposed to be “premium.” The entune I had in my 19 was better than the jbl or at least I didn’t feel as frustrated by it.
  16. Dec 9, 2023 at 12:52 PM
    #36
    BenMorrow21
    BenMorrow21 New Member
    Ben
    2019 Trd Sport
    I bought a plug and play head unit from Trail Grid, Sony Xav 7000. It was simple to install and works well with the stock system. I have since upgraded the speakers with the kicker bundle from Trail Grid. It was also simple to install a has performed well. I also spoke to trail grid about amp and sub kit but wasn’t given a time line for when it would be available. I found a kicker sub and amp in the scratch and dent pile at Crutchfield for under $250 and I am in the process of installing them now. I didn’t get a box just put sub in the enclosure where the stock sub was. It was not a perfect fit, had to drill some holes but so far so good.
  17. May 4, 2024 at 10:12 AM
    #37
    MR.WaynesWorld
    MR.WaynesWorld Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    What Kicker Amp and Sub did you use. I'm in the process of doing the same. Did you tie into the stock speaker wires? If so what harness did you use for that?
  18. May 4, 2024 at 11:25 AM
    #38
    BenMorrow21
    Ben
    2019 Trd Sport
    Kicker 46cxa400 mono subwoofer amp
    Kicker 48 CWRT84 shallow mount sub woofer
    Kicker 46CK8 amp wiring kit
    Kicker 46CXARCT bass control
    i ended up having someone do the install because i just don't have any skill doing wiring
    MR.WaynesWorld likes this.
  19. Jul 3, 2024 at 7:14 AM
    #39
    rickyiceman
    rickyiceman New Member
    2022 Tacoma TRD Pro
    Hi. Do you or anyone else know the type of harness terminal or t-harness kit for the JBL Amp? I'm looking forward on installing an Audio Control D series amp, but I want to retain the factory head unit. I want to hijack the audio signals as speaker level and input directly to the Audio Control D series Amp, but without splicing the factory harness and without using RCA converters of any kind. Any help will be greatly appreciated. Thank you.
  20. Jul 3, 2024 at 7:21 AM
    #40
    MR.WaynesWorld
    Wayne
    North East Pa
    You might want to reach out to https://www.autoharnesshouse.com/ They had harness for the speaker wires going to the speakers and maybe they can build you one for the speaker input plug.
