2020 NorCal Camping, Wheeling, & Shenanigans
Discussion in 'Northern California' started by Twizted, Dec 19, 2019.
How many trips have you gone on in 2020?
  1. None, 2020 has been a real shit-show!
    15.8%
  2. 1
    8.9%
  3. 2-5
    33.7%
  4. 6-10
    22.8%
  5. 11-20
    8.9%
  6. 21-30
    2.0%
  7. 31-50
    1.0%
  8. 50+
    1.0%
  9. What's the biggest tire I can fit on my 3rd gen without a lift?
    5.9%
Thread Status:
Not open for further replies.
  1. May 28, 2020 at 7:45 AM
    #1521
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    The MS170 looks appealing for how compact & light it is. Also the price point.
    Any reason why I should look at something bigger and/or with more power, or you think that would be enough?
  2. May 28, 2020 at 8:22 AM
    #1522
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    If I hadn't found the deal on mine, and had bought new, I would have most likely bought the MS170. It's a good saw. My father in law has a bunch of saws including an MS170 (almond orchards). It's got good power and is easy to use.
    For clearing roads, and general stuff around the house, I think the MS170 would make a good saw. It's 16 inch bar will get you through a 30 inch fallen tree... which is a pretty damn big freaking tree lol.
    BalutTaco, nDub and ian408 like this.
  3. May 28, 2020 at 8:44 AM
    #1523
    betterbuckleup
    Ian
    Concord, CA
    Thanks for the input.
    There are so many options and just wasn't sure if there would be a need for a bigger one in my application.
    Sounds like it should be plenty for me.
    Out of curiosity, what's the biggest diameter tree you've cleared on a trail?
  4. May 28, 2020 at 9:20 AM
    #1524
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've never measured... But this one is probably the 2nd biggest (diameter)(but it was perpendicular to the road).
    And the one @2BeersPlease @Sharkfrog and I cleared this past weekend was probably the the most clearing I've had to do on one tree. It was laying almost directly parallel in the road, so it was laying in the road around 40 feet.
  5. May 28, 2020 at 9:35 AM
    #1525
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    it's not about the size of the saw it's how you use it:rofl:
    this is the smallest saw Echo makes and it's always worked well for me
  6. May 28, 2020 at 9:43 AM
    #1526
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    People with small saws tell themselves that all the time. :thumbsup:
    Lmao... Kidding.
    But it IS how you use it. (for others) When you're out there cutting up shit you need to be careful. You can't just go chopping in to the wood. You need to know which way the tree is going to pinch. You need to know if it's on a slope, if and which way it's going to roll, when you get through it. You can get yourself fucked up if you aren't paying attention.
    nDub, notlefty, ian408 and 4 others like this.
  7. May 28, 2020 at 9:56 AM
    #1527
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    knowing this is how you can do big things with little tools :anonymous:
    Blue Canary likes this.
  8. May 28, 2020 at 10:12 AM
    #1528
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    With that little guard on the tip of your saw... I'd say you're doing about 14 inches. :rolleyes:
  9. May 28, 2020 at 10:14 AM
    #1529
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'm kidding with @foxrcing07
    That Echo is a good saw. I've used the older version of that model a lot in the orchard. Ran strong and was easier to start than the Husqvarna or Stihls.
  10. May 28, 2020 at 10:17 AM
    #1530
    Twizted
    Twizted [OP] 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
  11. May 28, 2020 at 10:18 AM
    #1531
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    That the second I got it home
    Shortly after the tip guard came off and I flipped the chain the correct direction (not the bar that doesn't matter)
    the place I bought it from put it on backwards :annoyed:
    12"
  12. May 28, 2020 at 10:21 AM
    #1532
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Does that make you a tree hugger?
  13. May 28, 2020 at 10:24 AM
    #1533
    2BeersPlease
    2BeersPlease Well-Known Member
    Just had a 3rd genner tell me Bowman Lake Road is a "technical" 4WD trail.
    czach, rob1208, codyb209 and 9 others like this.
  14. May 28, 2020 at 10:24 AM
    #1534
    Twizted
    Twizted [OP] 1GR FE
    Rob
    America
    lol
    I have three ego tools (blower, hedge trimmer, & this chainsaw) and three batteries that I got pretty damn cheap. The battery life is very impressive, as well as the charge time. We've got a few acres up here, and I've never actually used more than 2 batteries while working on things.
  15. May 28, 2020 at 10:25 AM
    #1535
    Twizted
    Twizted [OP] 1GR FE
    Rob
    America
    :duh:
    Turds gonna turd!
    :rofl::rofl::rofl:
    2BeersPlease[QUOTED] likes this.
  16. May 28, 2020 at 10:27 AM
    #1536
    betterbuckleup
    Ian
    Concord, CA
    My old man has the ego mower and I was impressed with it. Nice & lightweight and lasts a while on one battery. Folds up pretty compact too
  17. May 28, 2020 at 10:32 AM
    #1537
    MattJakobs
    Matthew
    NorCal
    My dad just picked up their mower last weekend. He said he's been pretty impressed with it so far
  18. May 28, 2020 at 10:45 AM
    #1538
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :frusty:
  19. May 28, 2020 at 11:03 AM
    #1539
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I hope you replied with “you are correct. It’s best avoided. Not so much due to the technicalness of it but more because Of the herpes.”
  20. May 28, 2020 at 11:26 AM
    #1540
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    And leeches... Don’t forget the leeches.
Thread Status:
