2020 parts list
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Siblue, Jul 12, 2019.
  1. Jan 2, 2020 at 9:57 PM
    #441
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Check out the Bed Lights link in my signature for a simple alternative.
  2. Jan 3, 2020 at 1:23 AM
    #442
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    82153-04150 - Wire, Rear Door RH (Access Cab without Rear Seat)
    82153-04170 - Wire, Rear Door RH (Access Cab with Rear Seat)
    82153-04160 - Wire, Rear Door RH (Double Cab without JBL Audio)
    82153-04130 - Wire, Rear Door RH (Double Cab with JBL Audio)
    82154-04090 - Wire, Rear Door LH (Access Cab without Rear Seat)
    82154-04070 - Wire, Rear Door LH (Access Cab with Rear Seat)
    82154-04060 - Wire, Rear Door LH (Double Cab without JBL Audio)
    82154-04080 - Wire, Rear Door LH (Double Cab with JBL Audio)
    If you're just looking for the updated connector that plugs into the speaker:
    90980-12808 - Housing, Connector (Qty: 1 per speaker)
    82998-24350 - Terminal, Connector (Qty: 2 per connector)
    If you're looking for the connector that plugs into the door harness from the speaker:
    90980-12807 - Housing, Connector
    82998-24340 - Terminal, Connector (Qty: 2 per connector)
    Sorry, I don't have any specifics on that.
    53101-04090-B0 - Grille, Radiator (Limited with Silver Sky Metallic Colour)
    52127-04030 - Bezel, Fog Lamp RH
    52128-04030 - Bezel, Fog Lamp LH
    USA MSRP is $70 USD.
    Canada MSRP is $85 CAD.
    PT948-35160-AA - Wire Harness, Bed Lighting (MY 2016-2019 Type)
    90980-11003 - Connector, Bed Light (MY 2020 Type, Qty: 2)
    82998-12440 - Terminal, Connector (Qty: 4)
    This is for the old wiring harness and the new style connectors to plug into the 2020 lights. For some reason this harness is showing as discontinued, but there is stock available. Not sure if dealers will be able to order it, if not the instructions should provide enough information to build your own harness as was said.
    Even just taking the lights and measuring them should give you enough information to make it work, but if that fails, you could always....
    65100-04520 - Box, Cargo (Shortbox, 5 ft)
    65100-04530 - Box, Cargo (Longbox, 6 ft)
    Jeff
  3. Jan 3, 2020 at 4:35 AM
    #443
    Tullie D
    Tullie
    Wilson, NC
    Thanks Jeff !
  4. Jan 4, 2020 at 9:14 AM
    #444
    ToyoProTaco
    ToyoProTaco Well-Known Member
    2020 Magnetic Gray Metallic Tacoma TRD Pro
    Anyone still looking for these, I got a set from Sparks this week. Used a coupon code found on here, came to $51.30 + shipping. Ordered online New Years Day, dealer ordered them Thursday from their depot, shipped out Friday. This is the 2020 PT857-35200 lights. Local guy said they can't order them.
  5. Jan 7, 2020 at 1:44 AM
    #445
    e3po
    e3po Active Member
    2020 Tacoma TRD Off-Road
    @Jeff Lange
    Can you come up with the part number for the the JPL audio amplifier for a 2020 OR with the premium audio package?
    Mine was a bad part from the factory and I am currently in backorder limbo waiting for the part. Looking to see if I can just buy and install myself. Big thanks in advance.
  6. Jan 7, 2020 at 6:53 AM
    #446
    northwoods_
    northwoods_ Well-Known Member
    cole
    2020 DCSB
    Yes, I am looking for a set. Ebay has them listed at $87. https://www.ebay.com/itm/TOYOTA-TACOMA-2020-BED-LIGHTING-KIT-PT857-35200/333467688875
    Knoc31 likes this.
  7. Jan 7, 2020 at 7:18 AM
    #447
    Jeff Lange
    Calgary, Canada
    86280-04080 - Amplifier
    Jeff
    e3po[QUOTED] likes this.
  8. Jan 7, 2020 at 1:03 PM
    #448
    Shellshock
    Iowa
    Is the part number for the 2020 fox shocks floating around somewhere? I can't seem to find it anywhere. I'm only finding the old 17-19 part number which has been discontinued.
  9. Jan 8, 2020 at 6:42 PM
    #449
    B619
    B619 Well-Known Member
    2020 DCSB OR Premium VooDoo Blue Tacoma
    Tried buying a OEM tacoma tonneau cover but it seemed like it was missing parts...
    Can I get the parts needed/part number for the bolt and nut and whatever it screws into?
    Also the part where the cover snaps into place when folding it down?
    Thank you in advance.
    MannyS likes this.
  10. Jan 9, 2020 at 4:38 AM
    #450
    robb1887
    robb1887 Well-Known Member
    Norfolk, VA
    2020 Limited
    Anyone had hands on a 2020 SR grille insert yet? Curious to see the lower back side to see if the same mold was used as the Limited and has the mounting for the Limited front camera.
  11. Jan 9, 2020 at 10:49 AM
    #451
    Jeff Lange
    Calgary, Canada
    I took some pictures of a couple trucks to see a couple weeks ago but they weren’t very good. I suspect it will be there but I will take another look when I get a chance.
    Jeff
    robb1887 likes this.
  12. Jan 9, 2020 at 6:26 PM
    #452
    TacoStarv
    TacoStarv Well-Known Member
    New Jersey
    2020 Black Tacoma SR
    Hey @Jeff Lange any word of the OEM roof rack for the 2020?
    Nito likes this.
  13. Jan 10, 2020 at 11:50 AM
    #453
    Jeff Lange
    Calgary, Canada
    Haven't seen anything yet. :(
    Jeff
    e3po and Nito like this.
  14. Jan 13, 2020 at 12:40 PM
    #454
    txranger83
    txranger83 Well-Known Member
    Colby
    Republic of Texas
    2020 Tacoma TRD Off Road
    If I wanted to keep everything OEM, to take my 2020 TRD OR w/ front camera to 2020 Pro grill I would need the following items:
    ECU - 86792-35030
    Harness - 86799-04020
    Camera - 867130-04030
    Mounting Nuts (2x) - 90178-A0023
    Mounting Screws (2x) - 90167-A0021
    Grill - PT228-35200-AA
    Garnish - 53141-35060
  15. Jan 17, 2020 at 12:19 PM
    #455
    bigsmirt
    bigsmirt Member
    Florida
    2020 Tacoma Limited
    OEM Tonneau, Running Boards, Bed Lights, Mud Guards
    Can definitely vouch for Sparks, received my OEM in-bed lights in just a couple days from purchase. Install was plug in play, looks awesome. If only my new OEM Tonneau cover that was installed from local dealer made me as happy.
  16. Jan 17, 2020 at 12:23 PM
    #456
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Toyota just released the stop sale on them. Dealer put them on order again for me yesterday as they finally fixed whatever was wrong with them.
    bigsmirt[QUOTED] likes this.
  17. Jan 20, 2020 at 3:32 PM
    #457
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    For the 2020 PRO is it true that the fogs are different from the 17-19 years?
  18. Jan 20, 2020 at 5:32 PM
    #458
    Jeff Lange
    Calgary, Canada
    I haven't seen any information showing that the fog lights changed for the 2020.
    Jeff
  19. Jan 20, 2020 at 7:45 PM
    #459
    BadFlounder
    BadFlounder Well-Known Member
    Colorado
    2020 MGM TRD Pro
    The only change I’m aware of is with the non-Pro fog lights in that you can now get the OEM LED fog light upgrade. But the Pro still uniquely has the RIGID LEDS, just like the previous years.
  20. Jan 20, 2020 at 8:14 PM
    #460
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    https://parts.toyota.com/showAssemb...veline=0&ukey_trimlevel=144694&modelYear=2020
    Click on view more images for other diagrams of tonneau cover parts
    Jeff Dartfrog likes this.
