2020 parts list
Discussion in '3rd Gen. Tacomas (2016+)' started by Siblue, Jul 12, 2019.
  1. Feb 11, 2020 at 8:08 AM
    #501
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
  2. Feb 11, 2020 at 8:18 AM
    #502
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    BAM Wholesale Parts has had the AA and AB numbers listed as available for a week or so.
  3. Feb 11, 2020 at 8:24 AM
    #503
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
  4. Feb 11, 2020 at 4:53 PM
    #504
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Can anyone tell me if I need a part number or are these just standard items the parts department at the dealer stocks? It is a trim retaining clip from inside the engine compartment - was putting on the high lift struts and managed to loose one.
  5. Feb 11, 2020 at 5:05 PM
    #505
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Give me a min. I bought a bag, let me see if it has the pt# on it.
    they should carry them in stock though
    Devious6 likes this.
  6. Feb 11, 2020 at 5:15 PM
    #506
    baldbeardedtaco
    FL
    Sorry, it was the wrong clip
    I forget where this style is used
  7. Feb 11, 2020 at 5:24 PM
    #507
    Devious6
    Mark
    Thanks for looking - maybe someone else will have it. I assume the dealership will keep them in stock but figured it would be easier if I had the part number.
  8. Feb 11, 2020 at 5:54 PM
    #508
    baldbeardedtaco
    FL
    Where does that clip go to by the way? I think, the ones I pictured, go to removing the grill shroud
  9. Feb 11, 2020 at 6:22 PM
    #509
    Devious6
    Mark
    It secures the trim piece along the side of the engine bay to the rubber shroud at the back of the enClip location.jpg gine compartment.
  10. Feb 12, 2020 at 6:57 AM
    #510
    Devious6
    Mark
    I went in to our local dealership - he looked up the part, went into the back and came out with the same clips you have. I showed him mine again, he walked into the back again and came out with the ones I need. So, win there.
  11. Feb 12, 2020 at 7:23 AM
    #511
    baldbeardedtaco
    FL
    Post the pt#
  12. Feb 12, 2020 at 7:27 AM
    #512
    Devious6
    Mark
    Don't have it - I didn't realize that he never ran a new slip until I was sitting here at my computer.
  13. Feb 12, 2020 at 8:10 AM
    #513
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
  14. Feb 12, 2020 at 8:13 AM
    #514
    Devious6
    Mark
  15. Feb 12, 2020 at 10:39 AM
    #515
    Jeff Lange
    Jeff Lange Well-Known Member
    Edmonton, AB
    '86 AE86, '05 NCP13, '11 GSE21
    90467-07215 is that clip.
    Jeff
  16. Feb 12, 2020 at 12:26 PM
    #516
    BadFlounder
    BadFlounder Well-Known Member
    Colorado
    2020 MGM TRD Pro
    For those interested in grille swaps, I finally swapped my 2020 Sport grille with a 2020 Pro grille. I ended up ordering the 2020 Pro OEM camera (Part #
    67B0-04030) hoping it would include the needed mounting bracket, which sure enough it does. I then discovered that you can re-use the Sport/OR/Limited camera wiring harness. The harness simply unplugs from the back of the camera.
    Honestly, I think all you really need is the black metal bracket. The cameras look identical so I think one could remove the Sport/OR/Limited camera from that OEM bracket using the two silver screws, and then mount it into the Pro camera bracket. I don't have a 3D printer, but mimicking the bracket sounds like something easily accomplished with that kind of tool. :D
    Anyway, I'm pleased with the upgrade. I liked the look of the grey OEM Sport grille this time around, but I still like the Pro grille much more so it's a worthwhile upgrade IMHO. But, of course, it is a stupidly expensive upgrade for the OEM parts. :frusty:
    The only thing I don't like about the upgrade is that I can no longer see my front bumper/license plate bracket in the bottom of the screen, but that's the tradeoff with any Pro grille because of the higher camera mount position. I'll simply have to adjust to using the onscreen guides more for parking in the tight garage spot. :thumbsup:
    the_wanny, TacoJoe87, yub and 6 others like this.
  17. Feb 12, 2020 at 12:40 PM
    #517
    The Pirate
    The Pirate Takoyaki Takoma
    Thanks for the update, it looks great!
    I see a business opportunity for whoever is willing to make copies of the mounting bracket...
    6MTPro and BadFlounder like this.
  18. Feb 13, 2020 at 10:05 AM
    #518
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Phoenix
    2020 TRD OR DCSB Cement 4x4 AT
    hyrule_trd likes this.
  19. Feb 13, 2020 at 10:53 AM
    #519
    Jwild909
    Jwild909 Member
    Justin
    2020 White TRD SPORT 4X4
    Did you have to buy the OEM 2020 PRO grille also?
  20. Feb 13, 2020 at 11:26 AM
    #520
    Nito
    Nito Well-Known Member
    Portland, OR
    ‘20 Cement Off-road DCLB
    FarmerJB and AZ_Tumbleweed like this.
