2020 parts list
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Siblue, Jul 12, 2019.
  1. Sep 25, 2020 at 3:10 PM
    #761
    johnr51
    johnr51 New Member
    Need retainer clips for kick panel.
    My apologies if I'm not posting correctly.
    I boogered up the clips when removing the molding on the lower front corner of the driver door opening when accessing the plug to install a trailer brake controller on my 2020 Tacoma SR. I've searched around this forum and the obvious ClipsRUs sites with no luck. Anybody know of a source? These are somewhat unique in that they have a rectangular tab that connects to the molding and the usual pin that attaches to the frame. Thanks for any help. /John
    deusxanime likes this.
  2. Sep 25, 2020 at 6:17 PM
    #762
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    907rx7, Jeff Lange, markram and 2 others like this.
  3. Sep 25, 2020 at 6:27 PM
    #763
    johnr51
    johnr51 New Member
    Homiec, You are the man (regardless of your gender)! Thanks very much. It will give me something to talk to the service manager next time I take it in for scheduled maintenance. /John
    markram and deusxanime like this.
  4. Oct 2, 2020 at 6:07 PM
    #764
    The Pirate
    The Pirate Takoyaki Takoma
    E28DCC86-F247-4242-B8F3-927755ECF42E.jpg 71F1703F-4321-4D79-AF04-14071134CB69.jpg I was parked on the side of the road and someone slammed into my drivers side mirror so hard it folded back and cracked this piece of plastic. @Jeff Lange do you know if I can buy it separately? If so do you have a part number? Thanks!
  5. Oct 2, 2020 at 9:19 PM
    #765
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    That part cannot be bought separately, it is part is the entire mirror assembly.
    The cheapest is for around $165
    87940-04230(LH) 87910-04220(RH)
  6. Oct 9, 2020 at 6:11 PM
    #766
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    Looking for a part # Black Textured Mirror Cap LH / RH with turn signals
    The Pirate likes this.
  7. Oct 9, 2020 at 7:52 PM
    #767
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    I remember a thread awhile back that someone actually purchased all the parts to try to get this to work on a USA Spec Tacoma and wasnt able to.
    i did a search but it may have been buried within another thread...
  8. Oct 11, 2020 at 12:10 PM
    #768
    fj45Jeff
    fj45Jeff Active Member
    Vancouver, BC, Canada, eh!
    2020 Black Taco TRD Offroad
    Awesome thread! Thanks for doing this. @Jeff Lange Is there a part number for the OEM USB plug in the back of the center console (not the one IN the console). Seems to be a US only option?
  9. Oct 11, 2020 at 1:12 PM
    #769
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I'm not actually sure if thats an option. I think the only unpainted mirrors caps they sell come with no mirror turn signals (its for the utility package SR)
  10. Oct 11, 2020 at 3:31 PM
    #770
    lpfe42
    Kenny
    20 DCSB CEMENT
    5100/887 Icon uca
    Thats a bummer
    Thanks
  11. Oct 17, 2020 at 1:55 PM
    #771
    Atom
    Atom Well-Known Member
    Vermont
    2020 ACLB Cement
    does your trd sport have a cargo light in the brake light? Or is it like mine (SR5) and doesn’t have a cargo light?
  12. Oct 17, 2020 at 9:10 PM
    #772
    DBTacoma2020
    DBTacoma2020 Member
    Damon
    Layton, UT
    2020 TRD Sport-Access Cab-Manual Transmission
    Stock TRD Offroad Suspension and 16" Rims with 265/70 Tires
    Hello folks....can anyone give the clear answer regarding adding the OEM bed lights on my 2020 TRD Sport. It is an Access Cab, so there is no cargo light with the third tail light and there is no switch in the cab for cargo lights. But the truck does come pre-wired at the tail-lights to add the OEM lights. If I add them, how do they turn on? Really appreciate the help.
  13. Oct 18, 2020 at 10:26 AM
    #773
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I think that has been asked before and the answer is you have to buy the switch too. I can't remember if it is prewired and you just plug it in, but I think it was, but don't quote me on it! Maybe pull that left panel out and see if you have the plug back there before committing to too much.
  14. Oct 18, 2020 at 10:32 AM
    #774
    deusxanime
    MN
    Sorry for double post but wanted to separate this out since it is different question/topic.
    @Jeff Lange or others - Do you have a part number for the rubber grommets under the cab? I got Woolwax undercoating done and they forgot to put it back in. Here's a picture of the one I need that is missing from the other side:
    This is inboard of the rocker seam and just behind the first mount point for the step bar brackets (as you can see). Want to get the side that is missing the plug all closed up ASAP before winter and salt season starts!
  15. Oct 18, 2020 at 10:34 AM
    #775
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    And it’s not the same size as the one you remove for the tailgate lock?
    deusxanime[QUOTED] likes this.
  16. Oct 18, 2020 at 6:08 PM
    #776
    FLJB
    FLJB Well-Known Member
    J
    FL
    2020 4X4 Sport MT
    Thread has the answers you seek and the part numbers for the switch, relay and install pics. You need to buy the switch and install it for it to work.
    https://www.tacomaworld.com/posts/23986324/
  17. Oct 18, 2020 at 6:21 PM
    #777
    deusxanime
    MN
    Good point! I'll have to see if that one fits since I have it leftover from the lock install.
    daveeasa[QUOTED] likes this.
  18. Oct 19, 2020 at 1:12 AM
    #778
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    i was directed here. I'm looking for a part number for the predator steps end caps.
  19. Oct 19, 2020 at 10:13 PM
    #779
    deusxanime
    MN
    Turns out the one that is pulled off for the tailgate lock is bigger, so will have to find a different one. Darn, would have been nice and easy if that would have worked out!
    daveeasa likes this.
  20. Nov 1, 2020 at 4:00 PM
    #780
    Roadkill1081
    Roadkill1081 Well-Known Member
    Maryland
    2020 DCSB TRD SPORT CEMENT
    It has the cargo light in the bed light
