2020 parts list
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Siblue, Jul 12, 2019.
  1. Apr 14, 2022 at 4:13 PM
    #1021
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Anyone have the part number handy for the passenger side trim panel on top of the dash mounted tweeter next to the a pillar with the grab handle? Mine has no ambient light sensor, just a dummy piece, but it’s tempting to put one in and play.
    Part number 1 in this diagram.
  2. May 16, 2022 at 11:32 AM
    #1022
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    @Jeff Lange
    Would you happen to know if there is a variant of the OEM HDMI/USB Port (086b0-00010) with standard HDMI and USB ends?
    It is a JDM Toyota part, so it uses an HDMI Type E connector which is difficult to source an adapter for.
    Hoping there is a version with standard ends.
  3. May 16, 2022 at 9:08 PM
    #1023
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    You could try 82821-48320 in combination with 86842-40020, but that's about all I can think of, but I suspect it is the wrong shape and I haven't personally seen it to verify the HDMI type either.
    Jeff
    Rainoffire likes this.
  4. May 16, 2022 at 9:33 PM
    #1024
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Can you get the part number for the .5 spacer that used for the rear lift for the 2022 Pro? At least I think it was a block when I looked at it…
  5. May 16, 2022 at 11:12 PM
    #1025
    Jeff Lange
    Calgary, Canada
    PT82A-35220-SS
    Jeff
  6. May 17, 2022 at 2:33 AM
    #1026
    Rainoffire
    Do these come in pairs or just one per side?
  7. May 17, 2022 at 2:54 AM
    #1027
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    I thought the same lol
  8. May 17, 2022 at 8:20 PM
    #1028
    Jeff Lange
    Calgary, Canada
    Per side.
    Jeff
    Rainoffire[QUOTED] likes this.
  9. May 21, 2022 at 5:16 AM
    #1029
    Rainoffire
    Would you also happen to know if they require new longer center pin bolts? Or if they can just added on to existing hardware?
    Asking cause, other aftermarket 0.5" blocks use a new center pin as oppose to 1" blocks that you can just slap on without changing anything.
    EatingTacosinmyTaco22 likes this.
  10. Jun 26, 2022 at 9:23 PM
    #1030
    NMHunter
    NMHunter Well-Known Member
    Northern NM
    05 and 22 tacoma
    Just a couple
    Jeff,
    Awesome thread, huge help to the community and much appreciated.
    Does anyone have a new coupon code from BAM wholesale?
    Thanks in advance
  11. Jul 9, 2022 at 4:10 PM
    #1031
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    shiftd likes this.
  12. Jul 16, 2022 at 6:13 PM
    #1032
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Looking for the LH and RH outside part mirror numbers with heated mirror and turn signal.
  13. Jul 17, 2022 at 5:48 PM
    #1033
    TommyBoy51
    TommyBoy51 Well-Known Member
    Tom
    2022 Tacoma SR SX Access Cab Longbed 4x4
  14. Jul 17, 2022 at 6:10 PM
    #1034
    TommyBoy51
    Tom
    Hey Jeff, would this rear view mirror fit a 2022 SR. I think it should, as it is battery powered for the homelike buttons. Keep in mind the SR has no power running to the mirror.
    Thanks
  15. Jul 20, 2022 at 7:27 AM
    #1035
    Oaster
    Oaster New Member
    Josh
    2021 Tacoma SR5
    Does anyone have a part number for the driver side master window switch for one touch up/down for all of the windows. My 2021 SR5 comes with only the driver side doing it.
    Thanks
  16. Jul 20, 2022 at 9:47 AM
    #1036
    Barrister
    Barrister Well-Known Member
    Dennis
    Mesa, Arizona
    2023 TRD Pro, Solar Octane, 6 speed Manual
    Predator Steps, OEM Tonneau
    Hey Jeff,
    Do you have the part number for the side trim pieces for the factory Tonneau? 5 of the trim pieces are the same, and one different to accomodate the mounting bolt. One of mine is chewed up and I would like to replace it. See picture and thanks.
  17. Jul 21, 2022 at 9:16 AM
    #1037
    TommyBoy51
    Tom
  18. Jul 26, 2022 at 11:01 AM
    #1038
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    Longshot but do we have the part number for the 22 PRO bed panel assembly yet?
  19. Jul 27, 2022 at 9:49 AM
    #1039
    Jeff Lange
    Calgary, Canada
    87910-04230 - Mirror, RH
    87940-04240 - Mirror, LH
    87915-04070-B0 - Cover, Mirror (Silver Sky)
    87945-04070-B0 - Cover, Mirror (Silver Sky)
    PK3B6-35JS0 is correct for an Access Cab, but I am not sure if your SR will have the appropriate wiring. I would take a look through the instructions and make sure you have what you need before beginning.
    Yes, this will work on an SR.
    There is no option for all auto on the Tacoma. It's either LH front only or LH/RH front. Rear is never auto. Additionally, swapping out the switch will not work, other components like the motors and wiring are also different.
    84820-0E020 - Switch, Power Window Master (RH/LH Auto)
    Tonneau cover bits can be tricky, but I am pretty sure they are:
    64945-04020 - Cover, Latch (Front)
    64945-04010 - Cover, Latch (Front/Centre); Qty: 3
    64947-04010 - Cover, Latch (Rear RH)
    64948-04010 - Cover, Latch (Rear LH)
    Not sure why the rear ones are different or handed, but that's what I'm seeing.
    65500-04480 - Panel, Bed Side RH (TRD Pro)
    65600-04420 - Panel, Bed Side LH (TRD Pro)
    Jeff
  20. Jul 27, 2022 at 10:49 AM
    #1040
    Kefka
    2019 MBM TRD PRO
    Thanks, Jeff!! Appreciate the support as always.
