2020 parts list
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Siblue, Jul 12, 2019.
  1. Mar 7, 2024 at 11:35 AM
    #1181
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    Is anyone able to help a fellow member out in acquiring some centre caps? Despite having a '23 TRD Pro I'm unable to get the centre caps in Canada. I've tried a few online places and all have cancelled my order despite providing my VIN.
    Looking for 4x PT280-89210-F2
  2. Mar 7, 2024 at 11:53 AM
    #1182
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    Would this dealership work?
    PT280-89210-F2 - Wheel Cap 2022-2023 Toyota 4Runner | Longo Toyota Parts
  3. Mar 7, 2024 at 11:56 AM
    #1183
    MTBTACORN
    Ontario, Canada
  4. Mar 16, 2024 at 3:08 PM
    #1184
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    OK this is maybe a weird one but I seem to have lost one of the 3 poles in the tire change kit that is under the rear passenger seat. I seem to be missing one of the straight ones with the square ends that fit together. Noticed it wasn't there when I went to lower the spare to service the rear differential. I was able to find a way tmake it work for now. Had to have left if behind when we used the jack to change a trailer tire last summer.
    I'd like to find a replacement part. Is that something you can even order or should I try an auto salvage? I'm thinking the 2nd and 3rd gens probably use those same parts.
    Edit
    I found this, it's not OEM and may not be perfect but it gets me the missing part with out scouring salvage yards.
    https://www.amazon.com/gp/product/B099Z11Z9D?ie=UTF8
  5. Aug 3, 2024 at 8:55 PM
    #1185
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I know I’m nearly 4 years late, but I wanted to add some input on this. TRD Offroad 6MT, so whatever instrument panel harness that uses. I do have all of the wiring from the combination meter, at the IS3 connector, and the connector at the jar.
    I jumped the connector and the combination meter does nothing. So I guess that really is a feature set of the combination meter based on which country the truck goes to. Glad I tested it before buying parts.
  6. Aug 16, 2024 at 4:41 AM
    #1186
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Wondering if the new 4th gen Card Key will register with the 3rd gens.
    Do we already have a part number for it?
    Also part number for the air compressor system from the trailhunter.
    Mainly interested in the controller to pair with my Viair Compressor.
  7. Aug 16, 2024 at 1:32 PM
    #1187
    JCruiser
    JCruiser Well-Known Member
    Master Chief (E-9) USN (Ret)
    Georgia
    '23 Tacoma SR5 4WD 4D "Ice Cap" w/ XP Package
    Upcoming...... Pro grille and driving lights
    It may be coming.... but for $335 I'll pass.
    https://raveoffroad.com/products/slim-card-key-fob-for-2022-tundra
    Rainoffire[QUOTED] likes this.
  8. Aug 21, 2024 at 7:39 AM
    #1188
    richeerich
    richeerich Member
    Rich
    2023 Tacoma TRD Off-Road 4x4
    I apologize if this was asked already. I took this image from another post. Do you know the part number for the rubber molding above the trim piece?
  9. Aug 21, 2024 at 8:17 AM
    #1189
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If I recall properly from another post, that is not available from Toyota separately. One has to buy the whole window assembly. Perhaps those that discussed this will see this.
  10. Aug 21, 2024 at 8:22 AM
    #1190
    richeerich
    richeerich Member
    Rich
    I had a feeling. I appreciate the quick response.
    Toycoma2021[QUOTED] likes this.
  11. Aug 22, 2024 at 4:05 PM
    #1191
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    That's correct.
    Jeff
    richeerich likes this.
  12. Sep 13, 2024 at 5:55 PM
    #1192
    Mtaco14
    Mtaco14 Well-Known Member
    Nevada
    2023 TRD Off-Road
    Hello Jeff, Would you happen to have the part#'s for the rear U bolts for a 2022 to 2023 TRD Pro? Please see pic below. I think they are different in length the the normal Tacoma because of the .05 inch rear block on the Pro, but I'm not 100% sure.
  13. Apr 7, 2025 at 10:21 AM
    #1193
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Was trying to order the parking brake spacers from the OEM TRD lift kit. Received two different parts. The part on the left is what is referenced in other posts and pictures. Anyone able to tell if the part on the right is the updated part? BAM has sent the part on the right twice. PXL_20250401_153916518.RAW-01.COVER~2.jpg
  14. Apr 8, 2025 at 4:12 PM
    #1194
    Jeff Lange
    Calgary, Canada
    Should be 90117-14011 for these u-bolts.
    The LH side is what it should be, looks like the RH is mispackaged, but does appear to be some sort of spacer. No idea what it's for.
    Jeff
  15. Apr 8, 2025 at 4:23 PM
    #1195
    chstaco
    SC
    2020 Tacoma
    Appreciate the response. I figured they were mis packaged, but both wrong spacers appeared to be sealed in original Toyota bags. :confused:
  16. Apr 8, 2025 at 6:42 PM
    #1196
    Mtaco14
    Nevada
    2023 TRD Off-Road
    Jeff I believe from my research Your part # is for the TRD bilstein lift kit with 1in. block. The TRD Pro has a half inch block and I was told a while back the TRD Pro U bolt part # is 90117-A0004. This is what I installed with my Pro Fox suspension and it seemed to be correct. Either one should work however your part will be a little longer since it's for the 1in. block.
    Jeff Lange[QUOTED] likes this.
  17. Apr 9, 2025 at 4:06 PM
    #1197
    Jeff Lange
    Calgary, Canada
    You are correct. Interestingly, the bolts used for the TRD Pro are only 5 mm (~3/16 in) longer than the standard bolts.
    The ones I listed are 25 mm (~1 in) longer.
    Jeff
    Mtaco14[QUOTED] likes this.
  18. Apr 10, 2025 at 2:48 PM
    #1198
    Mtaco14
    Nevada
    2023 TRD Off-Road
    Yes Sir, In my research and Taco parts studies I found the third Gen Tacoma to have 3 different size U bolts. Thank you for coming back here Jeff we missed you and your parts knowledge sir.
    90117-A0005 Stock U Bolt for stock suspension
    90117-A0004 TRD Pro U Bolt for TRD Pro suspension
    90117-14011 TRD Lift kit U Bolt for TRD lift kit suspension
  19. May 9, 2025 at 9:17 AM
    #1199
    Mtaco14
    Nevada
    2023 TRD Off-Road
    Hello Jeff,
    Would you happen to know the Toyota Part#'s for the rubber shock bushings for above TRD Pro shock part #'s ? Folks of this forum are looking for them and having a hard time.
  20. May 10, 2025 at 9:21 PM
    #1200
    Jeff Lange
    Calgary, Canada
    You mean the actual bushings pressed into the eyes at the bottom of the shocks? You won’t be able to order those separately.
    Jeff
