2020 Stock Rims fit my 2017 Tacoma Sport ?
Discussion in 'Wheels & Tires' started by Booney64, Nov 16, 2022.
  1. Nov 16, 2022 at 2:46 PM
    Booney64
    Booney64 [OP] Member
    I am setting up snow tires and found a good price on 4/ 2020 OEM Rims. Will these rims fit my 2017 ? Is there a chart out there anywhere for this?
  2. Nov 16, 2022 at 2:55 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Bilstein 8112+650lb coils, 8100+Deaver Stage II leaf pack, SPC UCA, DuroBumps, Mobtown 0* sliders W/fill plates, Mobtown Recovery Bar, Radium PVC & CCV Dual Oil Separator Catch Can System, Snugtop Hiliner Sport, ATH bed Stiffeners (cuz bottle openers!) and front corner tie down, Badger plates for Firestone airbag + Relentless U-bolt flip + Daystar cradles, TRD Pro shift knob, TRD Exhaust, HPS Silicone intake tube, Green Filter, TRD Intake Air Accelerator, 265-70-17 Toyo Open Country ATIII on TRD 17"Rockwarrior Cold Forged wheels, TRD alloy front skid, RCI Aluminum transmission & transfer case skids. Much Meso awesomeness, FreshMexicanTaco TacoGarage Camera Controller + DDM, WarFab Sheridan hitch skid, Rago LCA steel skids + lower rear shock guards, ScanGauge II, FN Koning Countersteer 16" spare, OEM T4R 90105-14104 coilover lower mounting eye bolts
    They will.
    Just know that the 3rd Gen Tacoma has a TPMS system that only sees/reads/allows 4 sensors. So either get clone sensors, for the winter wheels, to use your OEM sensor ID#s, or you will have to have the truck reprogrammed every time you want to swap wheels.
    Booney64[OP] and Tacospike like this.
  3. Nov 16, 2022 at 3:15 PM
    Booney64
    Never thought of that.Thx for that heads up for sure.Not sure what you mean by clone sensors. From Toyota ?
  4. Nov 16, 2022 at 3:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Autel 315MX are clone sensors. Your fav tire shop may have other versions.
    I have three sets of wheels for my '17. OEM with OEM sensors and the other two sets have Autel 315MX clone sensors using the trucks' OEM sensor ID#s.
    Booney64[OP] likes this.
  5. Nov 16, 2022 at 4:01 PM
    Booney64
    The Rims I'm looking at still have tires on them, but no good.I m assuming sensors are OEM .The Rims are in nice shape.So I'd have to reprogram these each time changed out? So I'd need these clone sensors to replace them?
  6. Nov 16, 2022 at 4:39 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Yes, since those sensor numbers are not programmed into your truck. Programming the new ID#s into the truck isn't easy as it has to be done through the OBDII port with specific equipment.
    Well, that is up to you if you swap your wheels yourself at home.
    Booney64[QUOTED][OP] likes this.
  7. Nov 16, 2022 at 7:10 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    The clone sensors @eurowner runs are an excellent option if you do not already have sensors.
    However, if you end up with two sets of OEM sensors, this is the solution you want:
    https://www.ateq-tpms.com/en-us/products/quickset-x/
    I have this tool and OEM sensors in my 3-season and winter wheels. I simply scan and upload each season. It's very straightforward. I was lucky in that I purchased a complete set of TRD Sport wheels and simply sold off the non-winter tires.
    My friend just purchased winter wheels for his 4Runner and went with the Autel sensors and is very happy. I'd have gone that route if I didn't have OEM sensors.
  8. Dec 4, 2022 at 6:37 AM
    Booney64
    So the Autel 315mx system comes with the tool that is needed to program the sensors right. I may do a set of rims for wifes Rav4 as well.I saw a kit online with 8 sensors and programming tool for $199.Does this sound right for what I need or do you have a kit # I could look at ?Thx
  9. Dec 4, 2022 at 8:57 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Plots s lint to what you are looking at.
  10. Dec 4, 2022 at 10:03 AM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    22 TRD Sport LR. 16 Mustang GT. 14 Street Glide
    That would be a smokin deal. Four sensors normally cost that much.Seems too good to be true.
  11. Dec 4, 2022 at 10:34 AM
    eurowner
    eurowner Duke Sky
    Scoty
  12. Dec 4, 2022 at 11:30 AM
    Booney64
    Well,Not sure where I saw that listing,cant find it.Still looking again. Anyway,do I need to buy the programing tool for these clone sensors ?
  13. Dec 4, 2022 at 11:33 AM
    eurowner
    eurowner Duke Sky
    Scoty
    The Autel tools will scan your OEM sensors and you physically write down the four ID#.
    The you insert the new Autel sensor into the tool and type in one of the four sensors ID#s.
  14. Dec 4, 2022 at 4:26 PM
    Booney64
    I just bought 4 OEM Rims,same as what I have. Tires are junk.Not sure if OEM sensors are in or any sensor for that matter.Taking tires off this week and go from there I guess
  15. Dec 4, 2022 at 4:31 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If you have an Atutel tool that reads ID3s, you can find out quickly!
  16. Dec 4, 2022 at 4:38 PM
    Booney64
    I dont have a tool.Im new to this.
