2020 Tacoma driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ucf120, Jan 2, 2020.
  1. May 10, 2020 at 7:45 AM
    #41
    Mat Briand
    Mat Briand New Member
    Mat
    2020 tacoma trd offroad premium
    I've had the same problem with my new 2020 TRD OR double cab. Dealer checked it out and the drums were replaced. It got better but still doing it at same speeds as op. I have 6000km so far and it has done it since day 1.
    Heres how I've narrowed mine down to being a problem with rear brakes and not the drive line.
    1) No vibration in steering wheel.
    2) Decelerate by manually downshifting - doesnt do it.
    3) Brake with truck in neutral - still does it.
    I haven't tried applying the parking brake and driving it around at all yet. The last visit to the dealership they drove the truck and said it could be something to do with the brake shoe material. It could be doing the something similar to a chattering clutch. They want my truck back again to take some more measurements for toyota to use for diagnosis.
  2. May 10, 2020 at 7:50 AM
    #42
    2019tacosr5
    2019tacosr5 Well-Known Member
    Jacob
    2019 White Tacoma SR5 V6
    Mine does it intermittently, almost feels like warped rotors, but it’s not because it only does it sometimes.
  3. May 13, 2020 at 12:51 PM
    #43
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    If I put an aftermarket lift would that void the TSB for my truck?
  4. May 13, 2020 at 1:59 PM
    #44
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    I imagine you may get some push back if you have aftermarket suspension components and larger tires. I specifically had this done prior to installing my lift for that reason.
  5. May 13, 2020 at 3:29 PM
    #45
    cdoghump
    Amarillo, TX
    17' TRD OR DCSB 4x4
    :frusty:
  6. Sep 25, 2020 at 9:51 AM
    #46
    hotrodder636
    hotrodder636 Well-Known Member
    2020 Tacoma TRD Pro (MGM)
    I am currently dealing with a vibration issue but mine is not linked to deceleration at lower speeds. Mine seems to come into play at speeds between 70-80MPG at varying speeds and varying engine RPMs. Initially I thought it was tires, but after my 3rd set of tires and multiple RF balancing, I am thinking it is something else. As a last restore on tires, I am going to go to a different shop and see if I get better results. The vibration I am feeling at the above mentioned speeds is almost like a ‘shuddering’, so much that the passenger seat shakes fairly violently. I have some videos of it in action but don’t know how to post them on here.
  7. Sep 26, 2020 at 1:11 AM
    #47
    Flying_Viking
    Flying_Viking Member
    Dallas, TX
    2020 Tacoma TRD Pro Army Green
    Diamondback HD w/RTT
    Same problem on my 20 PRO. 3 sets of tires and multiple rebalancing of each, no change or improvement. Comes and goes. Please post here if service is any help at all. I am taking mine in next week, and if they can’t or won’t locate the problem, it is getting traded in immediately.
  8. Sep 26, 2020 at 2:53 AM
    #48
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  9. Sep 26, 2020 at 7:55 AM
    #49
    AgTaco98
    AgTaco98 Well-Known Member
    Edmond, OK
    2020 DCSB 4x4 TRD OR
    '20 4x4 DCOR. Same rumble strip vibration on decel.
  10. Sep 26, 2020 at 8:00 AM
    #50
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I had/have the same thing. Usually it was after I’d driven for a while. I thought it might be the brake pump I’ve heard the OR and Pros have after reading a few things. I’ve got about 3500 miles on my truck and it’s now lifted as well. I’ll say after putting about 500 miles on it with the lift I barely notice it. Could have been the leafs not being quite right while stock or something else. While testing the lift I did do a lot of heavy/quick breaking and acceleration but I don’t notice it nearly as much. Could all just be in my head though...
  11. Sep 26, 2020 at 8:09 AM
    #51
    weaksauce
    weaksauce Active Member
    Los Angeles, Ca Eagle Rocks
    2018 TRD Sport DCSB
    Console safe. Hondos garage tablet mount, Diamond back SE. Baja Designs fog lights, Limo Tint,
    I had the same issue w/ my 2018 trd sport, started@ 500 miles. Long story short, turns out the rear brake drums had warped.
  12. Sep 26, 2020 at 8:14 AM
    #52
    BillsSR5
    bill
    2014 SR5
    hard to believe rear drum brakes are warped at 500 miles, ive had no issues at 240,000 miles on mine without ever bothering at all with them, most of the braking action occurs using the front brakes, also warped out of round drums will cause pedal pulsation not vibrations on deceleration when slowing down
  13. Sep 26, 2020 at 8:35 AM
    #53
    hotrodder636
    Please update us with what you find out/hear.
  14. Sep 26, 2020 at 8:57 AM
    #54
    weaksauce
    2018 TRD Sport DCSB
    Yep, started feeling it @500 miles. took it to the dealership @1500 got the run around a bit. finally got new drums @ around 5000 miles haven’t had any issues since. I went through the forums searching for a poss. cause, my money was on drive line issue. I was surprised when they told me the drums were bad. My vibration was when braking/deceleration. jus saying.
  15. Sep 26, 2020 at 11:00 AM
    #55
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    the transmission is still learning optimal shift points. what you are probably feeling are the clunky downshifts which are common during the first 1000 miles.
  16. Sep 26, 2020 at 11:43 AM
    #56
    BillsSR5
    bill
    2014 SR5
    drums on Toyota trucks don't warp at 5000k miles its impossible
  17. Sep 26, 2020 at 12:43 PM
    #57
    cryptolyme
    Virginia
    not if it was a manufacturing defect
  18. Sep 26, 2020 at 1:02 PM
    #58
    BillsSR5
    bill
    2014 SR5
    so we have 1/2 dozen people who said online the rear drums warped, I would like to see the receipt and mileage on that, it doesn't exist, Tacoma rear drums are bulletproof for way over 200k miles easily without little or no maintainence ive owned 5 of these trucks I know.
  19. Sep 26, 2020 at 1:09 PM
    #59
    4x4spiegel
    4x4spiegel Well-Known Member
    Earlier trucks maybe yes , later trucks well ?
  20. Sep 26, 2020 at 1:16 PM
    #60
    BillsSR5
    bill
    2014 SR5
