2020 Tacoma Front End Popping Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Calikid74, Jun 24, 2020.
  1. Oct 5, 2020 at 11:54 AM
    Surferbro7
    Surferbro7 Member
    Cullen
    2020 super white trd sport 4x4
    I have not going to give that a try Wednesday on my day off. Thanks for the advice man, hopefully that’s it
  2. Oct 6, 2020 at 11:38 AM
    PJTACO
    PJTACO Well-Known Member
    2017 Cement TRD PRO
    Good Luck!
    That shit is annoying!
  3. Apr 4, 2022 at 3:53 PM
    JordansBlackTaco
    JordansBlackTaco Well-Known Member
    Jordan
    Arkansas
    2019 DCSB TRD Off-Road
    Sorry to revive an old thread, but mine is doing the same thing, as stated in the comment above mine seems to only happen but only with the windows up. Is there any thing that this might point to in particular or should I just poke around and see what else I can find. I’ve double checked all suspension and can’t seem to find anything.
  4. Apr 4, 2022 at 4:49 PM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    Sounds like sway bar links. Check em.
  5. Apr 4, 2022 at 6:46 PM
    18CHUÑO
    18CHUÑO Well-Known Member
    Antoine
    2016 Tacoma SR5 i4 AC 4x4 Super White
    One thing that helps silence the rattling dash is to not set your steering wheel all the way up or all the way down of it's available up/down adjustability. Doing so transfers vibrations from the steering column to the dash and makes dash rattles/noises way worse. Adjust the steering wheel so that it isn't all the way up or all the way down.
    As for the pop sound, worn/loose body mount seems to be a popular occurrence in 3rd gens, but are you sure it's not just the bump stops doing their job?
