2020 Tacoma Manual Transmission Clanking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ToyoTaco2456, Oct 8, 2020.
  1. Oct 17, 2020 at 8:28 AM
    #61
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    My '16 OR does same thing
  2. Oct 17, 2020 at 8:28 AM
    #62
    ToyoTaco2456
    ToyoTaco2456 [OP] Active Member
    Evan
    2020 Toyota Tacoma TRD Sport
    Cold mornings feels like you’re shifting stone gears but once it’s warmed up it is pleasantly smooth to shift.
    MOC221_ and Junkhead[QUOTED] like this.
  3. Oct 17, 2020 at 8:29 AM
    #63
    ToyoTaco2456
    Evan
    Interesting that’s good to know, they’re still quite raw from what I have seen and that’s definitely not a bad thing!
  4. Oct 17, 2020 at 8:31 AM
    #64
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Lol, yup.
  5. Oct 17, 2020 at 8:39 AM
    #65
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Will agree on that for sure. Good luck downshifting to 2nd when she is cold.
  6. Oct 17, 2020 at 8:46 AM
    #66
    MOC221_
    Frank
    It's like the stick is planted in a bucket of gravel on cold mornings lol.
    Then you have the lazy pedal return if it's cold enough. Fortunately that too goes away fairly quickly.
  7. Oct 17, 2020 at 9:04 AM
    #67
    ToyoTaco2456
    Evan
    Downshifting that low and cold is not applicable for these units.
    Junkhead[QUOTED] likes this.
  8. Oct 17, 2020 at 9:09 AM
    #68
    ferntr33
    ferntr33 Well-Known Member
    It sounds to me like when you push the clutch in at a light and wiggle it left to right to make sure you are in neutral. Almost like the clutch locks in the play they built in the tranny so it’s easier to find each gear.
  9. Oct 17, 2020 at 10:02 AM
    #69
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    can you say take to the Dealer? I can
  10. Oct 17, 2020 at 10:29 AM
    #70
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    For what it’s worth, AMSOIL has been incredible for my MT in all temps. I used Redline and a mobile prior, AMSOIL provided a significant improvement in shifting.
  11. Oct 17, 2020 at 2:29 PM
    #71
    ToyoTaco2456
    Evan
    Haha that is very accurate.
  12. Dec 4, 2020 at 6:22 PM
    #72
    manncura
    manncura Well-Known Member
    2020 DCSB 6MT Sport
    I am in agreement with all these MT observations. What does the tune you used help with in these areas?
    And also, anyone else find it hard to get into 2nd/3rd without a little tinge of grind, unless I wait a hair and gently slip into those gears sometimes. Definitely don’t feel like I can just pulled the shifter boom into 2nd or 3rd.
    Mostly like the OP just wanna see if this my incompetence and/or of I’m fking up my truck >O :). Only got a 1k on mine.
    MOC221_[QUOTED] likes this.
  13. Dec 4, 2020 at 7:11 PM
    #73
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Now that I think about it when I had my silverado it had a similar clunk on the 1-2 shift under lucky throttle and the general forum consensus to fix it was to grade the slip joint on the driveshaft. Granted they were all autos but at the very least it can't really hurt anything. Also @manncura yeah at low RPM shifts my 2-3 is a bit grindy. Everything about these trucks like to be around up to 4k or more and then it's buttery smooth. Also try letting off the gas roughly halfway into depressing the clutch to create a bit of rev hang. I've said it before and I promise once you get the footwork right it shifts so much better.
  14. Dec 4, 2020 at 7:19 PM
    #74
    manncura
    2020 DCSB 6MT Sport
    Thanks. I was just noticing that the subtl grind going into 2/3 is def mitigated if I wait a little longer than I am used to (so lik 3/4 K rpms) ...i will have to commit to That . Just very different than a dinky old 5 sp man corolla that was my last stick years ago
  15. Dec 4, 2020 at 7:23 PM
    #75
    TurdTaco64
    Brandon
    Fort Collins
    Yeah don't be afraid to experiment with footwork and timing your shifts. This taco, plus the first gen I used to have as well as my 06 LJ with a Merc transmission and 91 XJ with an AX 15 all were funky going into third too fast and low RPMs.
    manncura[QUOTED] likes this.
  16. Dec 5, 2020 at 8:58 AM
    #76
    MOC221_
    Frank
    OVtune helps with getting access to available torque down low. It's still not a stump puller, but I find I can be in a higher gear at a lower RPM than with the stock calibration.
    Yeah, both the 16 and this 19 were a bit grindy at first 2-3. As others have said, it breaks in real nice.
    Junkhead likes this.
  17. Dec 5, 2020 at 9:47 AM
    #77
    manncura
    2020 DCSB 6MT Sport
    I am excited to get the OVtune. Does the truck try and revert back to its original setup from the dealer due to any adaptive software ingrained in the ecu? --- I also could drive the truck the way it is now, no problemo, for the next 200k and be perfectly happy :).
    MOC221_[QUOTED] and Junkhead like this.
  18. Dec 5, 2020 at 2:16 PM
    #78
    MOC221_
    Frank
    I wouldn't say it tries to revert back to stock config. The ECU does "learn" over time/mileage though, things like knock correction and idle airflow etc. The driving experience definitely changes from the time you perform a flash through a few hundred km. You will get some "stupid" behaviour right away (surging, throttle response weirdness), but that clears up within 25 km or so. After that the changes are subtle.
  19. Dec 5, 2020 at 2:32 PM
    #79
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Interesting. I tuned about a 1000km ago and it just gets better and better. SFOB is fantastic, even my borla sounds better.
    It did drive very jerky right after the flash though but i expected that. Its just like when you disconnect the battery on any vehicle.
