2020 Tacoma OEM LED Headlight Megathread
Discussion in 'Lighting' started by MikeyMcFly, Feb 7, 2019.
  1. Feb 7, 2019 at 5:00 PM
    MikeyMcFly
    MikeyMcFly [OP] This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    I figure since the other 2020 Tacoma threads are getting muddled with OT stuff, we should have an OEM headlight megathread here that hopefully stays on the technical side.
    Searching through this article I've found the following pics of the TRD Pro and TRD OR units.
    TRD OR
    It appears the general design of the head lamp is the same, with the TRD Pro having the TRD and PRO insignia, while the OR simply has a open space.
    The TRD Pro is listed as having sequential LED/DRL headlamps, which is not something listed with the TRD OR / Limited / Sport. It appears the side indicator varies between assemblies, with the OR having a regular reflector and the Pro appearing to have an outline on the side indicator, maybe for an LED?
    My personal questions are as follows:
    • What is the difference in turn signal indication? Does the "racetrack" on the headlights change color on the Pro and not on the OR?
    • Where is the front facing turn signal on the OR, if it's not part of the "racetrack"
    • What is the DRL situation for each truck? In the photo above the Pro has the "racetrack" on with the fogs, but not the regular head lamps. This is akin to the current LED DRL setup. However for the TRD OR the photos I've seen don't show the DRL only situation, it shows this:
    • This shows the little spot below the "racetrack" illuminated as well. So what's the turn signal configuration and what's the DRL setup.
    So this is where I am at. Further questions / comments / answers are welcome.
    sly1, Mz_A_808, Tacoman589 and 4 others like this.
  2. Feb 7, 2019 at 5:01 PM
    Kabanstva
    Kabanstva Well-Known Member
    I love the updated LED headlights. Anyone notice it already has Rigid foglights installed?
  3. Feb 7, 2019 at 5:04 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Side marker appears the same to me. Angle of headlight (picture) is just different.
  4. Feb 7, 2019 at 5:05 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The 3rd gen Pro has always had the option of ridgid fogs from factory
  5. Feb 7, 2019 at 5:05 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Why do they look like something off Ebay?
    xola3que, Ronin47, Rooster87 and 8 others like this.
  6. Feb 7, 2019 at 5:05 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Wonder what the SR5s are going to look like
    Flipstik likes this.
  7. Feb 7, 2019 at 5:10 PM
    na8rboy
    WI
    I'm guessing what we have now.
    TacoBuffet likes this.
  8. Feb 7, 2019 at 5:12 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    You're right. I watched a vid on YT and all the LED headlights have LED corner lights, which is pretty neat.
    EDIT Embed didn't work at the time, check 4:04
    Double Edit:
  9. Feb 7, 2019 at 5:14 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Lifted on 275/70/17
    I think the design of the light itself looks really good. However, I think it's going a little overboard on the drl like most others are doing as well. Will be interested to see in person and light output.
    Tacoma1818 likes this.
  10. Feb 7, 2019 at 5:29 PM
    Tacoma1818
    Tacoma1818 Well-Known Member
    Honestly... after watching that video posted above, I’ve gotta agree. At least for now, till I see them in person. Those headlights look like someone checked all the boxes possible for an eBay pair ( not in a good way).
    Not to be a naysayer, but the grilles they showed in that vid were WOOF. Not that many of the tacoma grilles have been great... so par for the course there.
    I am most excited about the new infotainment system and panoramic camera, I guess.
    I mean, I get the updates as necessities but for me personally, nothing really stands out.
  11. Feb 7, 2019 at 6:52 PM
    jimmydean
    jimmydean Well-Known Member
    Camarillo, CA
    16' DCSB TRD SPORT 6M
    Limited Grill/Wheels, 265/65/18 Nitto RG
    I guess the big question will be if this will be a simple plug and play swap or will more wiring modifications be required
  12. Feb 7, 2019 at 6:57 PM
    smikec
    smikec Well-Known Member
    Agree, and price $$$$
  13. Feb 7, 2019 at 7:12 PM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport
    Yep, first thing that came to mind....”those look like the tacoma beast/oemassive lights”
    El Duderino, Bridge4, Madtown and 3 others like this.
  14. Feb 7, 2019 at 7:16 PM
    avi8or_co
    Can’t see that happening. Our lights have a bunch of bulb connectors made to fit specific bulbs. These are probably going to have one wire harness plugged into them. Not saying you can’t probably rewire the stock plugs to make it work.
  15. Feb 7, 2019 at 7:42 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD 2JZ
    Side marker is definitely changed. Looks like 2 side emiting LEDs. Also more squared off in the front. Curious as to the “sequential turn” and DRL. The reflector based led is better than a halogen, but still nowhere near the performance of a purpose built projector. Depending on price, these would be a great candidate to use as a base for a retrofit.
  16. Feb 7, 2019 at 7:43 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    When I first saw that new LED headlights were going to be on it I was excited, but as I look at them, then look at mine... I dont like the new headlights, or tail lights for that matter (at least the chrome alteza ones)
    The grill on the limited in the video looked pretty cool, would like to see what it looks like color matched to a inferno.
    I also like the new radio, I would like to get a peak into the new radio, I would love to know if the new software can be pushed to older radios like other companies have done.
    SilverSurfer_Sr5 and TacoBuffet like this.
  17. Feb 7, 2019 at 7:53 PM
    smikec
    Curious question, retrofit what? Not questioning your expertise, just an honest question as how would you upgrade this, if it is reflector based?
    S
  18. Feb 7, 2019 at 7:55 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    For a split second, this made me want to check into trading up for a 2020, now I'm really thinking a supercharged 4runner would be cool!
  19. Feb 7, 2019 at 7:56 PM
    boywonder77
    boywonder77 Well-Known Member
    Bay Area
    2018 Tacoma Cement DBSB TRD Sport
    Same here. At first, I was like YES LEDS. But i think the current generation with a retrofit with Halos and diodes switchback look better than this.
    Bridge4 and TacoBuffet like this.
  20. Feb 7, 2019 at 7:58 PM
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2021 Cement TRD OR DCSB
    Truxedo Pro X15 tonneau, front tinted windows
    Will I be able to use Waze??? If so, I’ll be trading in for it.
    TacoDelcid, DogsandTacos and 1bad2k like this.
