2020 Tacoma OEM LED Headlight Megathread
Discussion in 'Lighting' started by MikeyMcFly, Feb 7, 2019.
  1. Oct 14, 2021 at 6:02 AM
    #2181
    poe_fosho
    poe_fosho Well-Known Member
    Colorado
    2021 Tacoma TRD Sport 6 Speed Manual
    Here is a quick picture I snapped this morning.. I see the "notch" but I wonder if mine is more defined then the others have shared... How do you properly aim it when there is this notch..?
    Still not sure if mine is out of alignment or is normal. When pulled directly up against the wall, the beam cut off looks level and identical.
  2. Oct 14, 2021 at 6:42 AM
    #2182
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Headlight aiming instructions:
    https://www.danielsternlighting.com/tech/aim/aim.html
    Specifically:
    U.S. (DOT, SAE) VOR headlamps can have a straight-across cutoff line extending all the way across the top of the low beam, or a stairstep-shaped cutoff that's lower on the left and higher on the right side of the beam, or just a squared-off top edge of the high-intensity "hot spot" (brightest part of the beam). Whichever style it is, the cutoff to pay attention to is at the top of the right half of the beam pattern. It should be aligned with the applicable horizontal line per the table above.
    doublethebass likes this.
  3. Oct 14, 2021 at 8:59 AM
    #2183
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    It was something I noticed on my headlights when I first drove at night. Thought there was a bad LED on my set. When I looked it up, I found out a lot of other headlights with multiple LEDs have a similar notch.
    It is kind of like the step effect on HID projectors. When it shines down the road, the notch in the beam pattern should line up with the lane lines. Helps to prevent glare for incoming cars.
    Thought I was just behind the times, so didn't bother to post about it.
    poe_fosho[QUOTED] likes this.
  4. Oct 14, 2021 at 11:02 AM
    #2184
    poe_fosho
    Colorado
    Gotcha.
    So I guess mine are fine and I will consider it case closed.
  5. Oct 24, 2021 at 12:23 AM
    #2185
    TRDPro75
    TRDPro75 Well-Known Member
    Victor
    North Seattle
    2017 TRD Pro Cement Auto
    NitroGear 5.29 Regear OVTune 2.O Tune TRD Cold Air Intake TRD Pro Stock Exhaust 285 75X65 Gladiator X Compe 2020 OEM TRD Pro LED Headlights SnugTop GB Sport Canopy RIGID 30” Radiance Light Bar RIGID 40” Radiance Light Bar Custom Avente Roof Rails on Snugtop Icon RXT Spring Stage 3 Fox 2.5 Tundra Rear Shocks CBI Covert Bumper RCI Full Aluminum Skids RCI Rear Diff Skid RCI 20° Sliders ExperiMental Designs Anytime Locker Wilco Offroad Hitchgate Offset to Passenger Spare Carrier
    Hi @CF615, i just tried to install my new LED headlights and I too bought the TRS harness and I'm running into issues where none of my headlights are working but Daytime Running Lights, Fogs, Park, and Turn Signals all work. I keep blowing fuses every time my headlight plugs are connected. I tried every combination of hooking up to change polarity as well. The TRS harnesses didn't come with wire diagrams and I'm not sure the wires are the same year to year for Tacomas anyway. Did to get your issue solved?
    I used a voltmeter to test my headlight plug outputs and I was convinced I needed new OEM plugs which cost me another $200 on top of the cost of 2021 headlights.
    I can't get ahold of TRS and I'm frustrated as shit.
    Wondering if to could let me know if their harnesses are shit.
    Thanks
    Victor
  6. Oct 24, 2021 at 12:47 AM
    #2186
    Rainoffire
    @daveeasa can help you get things sorted out.
    Tacospike and TRDPro75[QUOTED] like this.
  7. Oct 24, 2021 at 12:59 AM
    #2187
    TRDPro75
    Victor
    North Seattle
    Yes thanks. I actually ordered a set of harnesses from him too b/c the TRS set sat at USPS for a week. Took two weeks to arrive to me. Unfortunately Dave had been away on vacation and won't be shipping the these till Monday. It's tough right now b/c my truck is a daily driver and the days are a lot shorter right now.
    @daveeasa if you can ship these on a faster method it would be greatly appreciated. I'm hoping I can return all the wiring harnesses that I paid Toyota $200 for today. It's absolutely absurd that plugs and wires cost that much!
    The voltmeter seems to suggest my OEM plugs are the issue but it's hard to believe that now based on what I've been reading on this thread about the TRS harnesses.
    The new Toyota plugs arrive Tuesday. Fortunately I don't need to do night driving between now and then. Hoping your harness may be the solution!
  8. Oct 24, 2021 at 1:56 AM
    #2188
    daveeasa
    David
    PNW
    Hmm, sorry about that @TRDPro75, I could have shipped you a set on Thursday without grille lights had I known the context. Or I could have sent the set on my truck but they are a little dusty. I wasn’t aware of the urgency.
    I bet we can get the TRS harness working. I’ll need photos to tell you what to do. The low beam and high beam connectors must both be oriented correctly on both sides.
    I’m not sure what OEM harnesses you ordered, could you link to a part number? I do have H9 connectors and I can throw 4 of those in your box in case you need them but I’m not sure what a voltmeter is telling you that’s causing concern?
  9. Oct 29, 2021 at 8:58 PM
    #2189
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    Was able to put it in a few days ago... It looks better in person
  10. Oct 29, 2021 at 10:38 PM
    #2190
    TRDPro75
    Victor
    North Seattle
    Looks good!
    Got mine installed last week and wiring figured out for the main lights with the TRS harness compliments of @daveeasa this last Monday. Thanks Dave!
    Weather is better tomorrow where I can get some pics to post.
    Tacospike likes this.
  11. Oct 30, 2021 at 6:05 AM
    #2191
    Tacospike
    Two Trucks
    Nice flooring
    FishnTx and tclavell like this.
  12. Nov 5, 2021 at 2:30 PM
    #2192
    conantm2
    conantm2 Active Member
    Monroe, WA
    2018 Barcelona red Off-road dcsb at
    285/70/17, kings with Icon uppers, trigger six, roof rack, blackhawk tuned
    Hey everyone, started clicking through all 110 pages of this thread a bit ago. I remember reading about some clips that people are commonly breaking when installing the headlights. If I remember right it was on the fenders? Was wondering if anyone has the part numbers for these so I can have some on hand when I do the headlights. Cant seem to find the comments talking about this again. Thanks for the help!
  13. Nov 5, 2021 at 2:33 PM
    #2193
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Might be the fender flare clips. Or the bumper retention bracket. Both cab be found easily on Amazon.
    conantm2[QUOTED] likes this.
  14. Nov 5, 2021 at 2:40 PM
    #2194
    TRDPro75
    Victor
    North Seattle
    It's pretty unlikely those fender clips will break if you just reach from inside the engine compartment and pinch it while you push the fender away. I've opened mine up 8 to 9 times for various projects and still have good working clips. If you pry from the outside you'll likely break them. It's only 2 clips you have to reach on each side and you can see them both once the grill and black plastic air guide scoops are removed.
    Tacospike and conantm2[QUOTED] like this.
  15. Nov 5, 2021 at 4:31 PM
    #2195
    Tacospike
    Two Trucks
    same. Engine bay way
    tclavell and FishnTx like this.
  16. Nov 5, 2021 at 6:30 PM
    #2196
    jjrek9
    jjrek9 Well-Known Member
    I believe these are the clips
    suaveflooder[QUOTED] likes this.
  17. Nov 8, 2021 at 7:29 AM
    #2197
    ScootARoot
    ScootARoot Where's my keys
    TJ
    Georgia
    '21 DCSB OR Black
    Do you have a PRO? I like the badging in the headlights, and would like to put them in my OR. Hoping it's just as easy to plug-n-play that headlight into my OffRoad. The LED harness is currently being shipped.
  18. Nov 8, 2021 at 7:32 AM
    #2198
    Tacospike
    Two Trucks
    Looks like an offroad
    It will be plug and play with your harness for the lights.
    tclavell and ScootARoot[QUOTED] like this.
  19. Nov 8, 2021 at 7:36 AM
    #2199
    ScootARoot
    TJ
    Georgia
    '21 DCSB OR Black
    Thanks! Wish I was more creative to make the PRO say OffRoad or anything besides PRO. I do like that badging though.
    Tacospike[QUOTED] likes this.
  20. Nov 8, 2021 at 7:38 AM
    #2200
    Tacospike
    Two Trucks
    Yeah, I would have liked "Sport" but owell. Sticking with Pro.
