2020 Tacoma OEM LED Headlight Megathread
Discussion in 'Lighting' started by MikeyMcFly, Feb 7, 2019.
  1. Sep 16, 2022 at 11:28 PM
    #2821
    guest_707
    guest_707 Well-Known Member
    Thanks, but I'm not at all knowledgeable in electrical stuff so I wouldn't have the capability, lol. Couple that with a busy work schedule and I wouldn't be able to do it at all. I'm gonna get in contact with the Toyota parts dealer I bought it from and take it from there, most likely. The lights are awesome though. The sequential turn signal is mesmerizing!
  2. Sep 16, 2022 at 11:33 PM
    #2822
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Yeah, ultimately a warranty claim is going to be the best route. But it’s an open offer if you change your mind
  3. Sep 17, 2022 at 4:17 AM
    #2823
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    My next step would be to test the headlight on the bench with a known good harness. Since yours are installed the only thing you can try is swapping sides or swapping harnesses. Easiest to swap harnesses. I assume the problem will persist. Then you could swap sides if you revert to halogen but at that point I’d just send it back I think. If they will take it as exchange.
    The last thing you can try is plugging a halogen bulb directly into the low beam connector, bypassing the LED housing and see if brightness changes at all.
  4. Sep 17, 2022 at 4:25 AM
    #2824
    caribe makaira
    Caribbean, Puerto Rico
    Mine would test the LED headlight, yours might test the connector, wire, fuse and relay.
    My money is on the LED headlight being FUBAR'd.
    Tacospike and daveeasa[QUOTED] like this.
  5. Sep 28, 2022 at 4:33 PM
    #2825
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    I bit the bullet and ordered the headlights and the harness off Dave here.
    Was my only gripe about my build is that while I bought it off the lot, it didn't have the LED headlight option!
  6. Sep 29, 2022 at 6:06 AM
    #2826
    Tacospike
    Two Trucks
    You'll love them!
    stan23[QUOTED] likes this.
  7. Sep 29, 2022 at 7:34 AM
    #2827
    19cement4xor
    19cement4xor Well-Known Member
    Eric
    Clear Lake TX
    19 Cement Trd off road 4x4
    TRD Pro suspension, Method Nv, 265/70-17 bfg ko2, meso TRD center caps
    agreed!
    stan23 and Tacospike[QUOTED] like this.
  8. Sep 29, 2022 at 9:58 PM
    #2828
    guest_707
    I've installed the new unit a few days ago and now everything seems to be 100%. Along with OEM LED fogs that I bought off someone here on TW so I have full LED front lights. The headlights are fantastic compared to the factory halogens. They're a little better than the Morimoto Mini D2S 5.0 HID projectors that I retrofitted in my old car, too. High beams aren't as good as the factory halogens and they don't aim nearly as high as the bell shaped highs on my old car's D2S, but a wider spread compared to them. The fog lights are stupid wide and a short vertical spread which is exactly how I expect fog lights to be and considering how good they are, I think they're the best value in terms of fog lights. Super wide, sharp cut off and not overly bright. With that being said, you're not supposed to drive with fogs on so they're off most of the time. The headlights are fantastic. Makes the front look way more modern/aggressive.
    Tacospike likes this.
  9. Sep 30, 2022 at 10:47 PM
    #2829
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    I bought the lights and they’re great but I feel like the left and right alignment is off. My only real question is to those who had them in the snow, will they melt the snow off or no?
  10. Sep 30, 2022 at 10:52 PM
    #2830
    MGMDesertTaco
    Mine need a little adjustment too. I haven't had a chance to test them in the snow yet, but no they won't get hot enough to melt snow. You might be alright in light snow. :notsure:
    I do have SS3 Max fogs from diode dynamics. I know the pro and max versions will get hot enough to melt snow.
  11. Sep 30, 2022 at 10:53 PM
    #2831
    islesrule123
    New York
    im curious if there is a right and left adjustment
  12. Sep 30, 2022 at 11:02 PM
    #2832
    MGMDesertTaco
    I don't think so. I believe there's a white plastic nut attached to a metal gear (not sure of the wrench/socket size). Turn it clockwise/counterclockwise to adjust up or down.
    Some decent Fog and or Ditch lights will fill in the rest. My SS3 Yellow Max's throw a ton of light out front and to the sides, but I still want ditch lights.
  13. Oct 1, 2022 at 4:46 AM
    #2833
    19cement4xor
    Eric
    Clear Lake TX
    Phillips head screwdriver straight down the channel that’s made into the back of the light housing to guild you into the gear. Adjustment is only up/down.
  14. Oct 1, 2022 at 2:05 PM
    #2834
    MGMDesertTaco
    @islesrule123 Screwdriver not a socket apparently...
  15. Oct 1, 2022 at 2:39 PM
    #2835
    daveeasa
    David
    PNW
    Ratcheting 10mm wrench works but round Philips is a bit easier to find for most and a little easier to twist vs ratchet I think.
  16. Oct 1, 2022 at 4:31 PM
    #2836
    19cement4xor
    Eric
    Clear Lake TX
    I found the washer bottle on the passenger side to be a pain with the wrench but mine was probably long enough.
    daveeasa[QUOTED] likes this.
  17. Oct 1, 2022 at 4:36 PM
    #2837
    daveeasa
    David
    PNW
    Great point, passenger side is definitely tighter w the washer fluid. Anyone with dual batteries is gonna have some squeeze on the driver side too. Round and long Philips head is the least tricky option if one is in the stable.
    This would be a great thing to do at a regional meetup, if someone identified a fantastic location where we could just assembly line this stuff and then go do something fun afterwards. Too bad we don't all live in some small town somewhere in the mountains with rivers of beer or something...
  18. Oct 3, 2022 at 9:36 PM
    #2838
    islesrule123
    New York
    I used my old headlight alignment to get it in the ball park so I think I should be ok.
  19. Oct 4, 2022 at 2:35 PM
    #2839
    Minimedic
    Minimedic Well-Known Member
    Tacoma DCLB OR MGM
    Another success story upgrading to OEM LED headlight using FBC wiring harness. Thank you to @daveeasa for making this a reality for us on TW. If you're in the market for headlights and in the budget. This should be your only choice.
  20. Oct 4, 2022 at 8:47 PM
    #2840
    Kvanator
    Kvanator New Member
    Not sure if anyone will have this answer but here it goes.
    I've been looking at ordering the OEM LED headlights for my 2018 SR5 but here in Canada it is quite challenging to find them at a reasonable price. I went to the local auto part shop in my town and gave them the product numbers I got from this thread, they looked the part up and found the headlights with the number provided and it came up on Rock Auto, but on Rock auto they use the product number TO2503291 and TO2502291. I was wondering if anyone has had success ordering them from Rock Auto or if they are even the actual OEM headlights or a knock off and just labeled as such. They are about $1200CAD each and I have a company discount that would drop the price considerably so I am hoping that these are the true LED headlights and of course I'd still need to get the harness still.
