2020 Tacoma OEM LED Headlight Megathread
Discussion in 'Lighting' started by MikeyMcFly, Feb 7, 2019.
  1. Nov 8, 2019 at 2:23 PM
    #521
    caribe makaira
    Caribbean, Puerto Rico
    If you find a way to open the fuse box without mangling it, let me know. All it would take is a snip on pin 86 wire and a crimp to a wire from that remaining purple (Parking) wire and a tuck and a bit more...
  2. Nov 10, 2019 at 1:16 PM
    #522
    18BRMTRDSportTaco
    18BRMTRDSportTaco Well-Known Member
    Sachse, Texas
    18 BRM TRDS DCSB
    TRD Pro SEMA wheels, 265/70/17 Falken Wild Peaks, OEM TRD Pro Grill, OEM Toyota Tundra LED foglights, Morimoto 5500K HID w/Hylux ballast, OEM Black Emblem Overlays.
    How did you determine which connector was for the highbeams and which for the lowbeams? Trial and Error I guess?
  3. Nov 10, 2019 at 2:50 PM
    #523
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Are you asking about the pinout of the headlight molex?
  4. Nov 10, 2019 at 3:03 PM
    #524
    18BRMTRDSportTaco
    Sachse, Texas
    18 BRM TRDS DCSB
    No, asking about the conversion harness. He mentioned the high beam and low beam connectors were identical.
  5. Nov 10, 2019 at 3:07 PM
    #525
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    The only difference between both connectors if you look inside hi plug is a little tab which you could easily remove using a razor blade. He is correct physically both are identical except the extra inner tab.
  6. Nov 10, 2019 at 4:36 PM
    #526
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    Simple. I turned on the low beam and walked to the headlight to see which bulb was illuminated. I then marked the connectors “L” with painters tape.
    The conversion harness is marked “L” for the low beam headlight.
  7. Nov 12, 2019 at 7:32 PM
    #527
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  8. Nov 12, 2019 at 11:00 PM
    #528
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Got word from Mcgeorge that headlamps are backordered until 11/26.
  9. Nov 13, 2019 at 6:47 AM
    #529
    RyanDCLB
    4/19 DCLBOR
    I just received this response from them for the non-trd pro LED headlights:
    "We do not have those parts in stock at our facility, but they are in stock at several of our distribution centers. If you place an order for those, we would receive them in from Toyota in 1-3 business days, then they would ship out to you"
    "We do our best to over-pack headlamps. Unfortunately once the parts leave our facility, handling is out of our control and things do happen. If there are any issues with broken materials upon arrival, we will remedy the situation."
    18BRMTRDSportTaco likes this.
  10. Nov 13, 2019 at 10:44 AM
    #530
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Oops, wa referring to Pro Headlamps.
    RyanDCLB[QUOTED] likes this.
  11. Nov 13, 2019 at 12:54 PM
    #531
    18BRMTRDSportTaco
    Sachse, Texas
    18 BRM TRDS DCSB
    That is the exact same response I received from them when I told them to be sure and pack them carefully.:rofl: I went with the non-Pro headlamps too. Mine will arrive tomorrow so I'll let everyone know if they arrive intact and damage free.
  12. Nov 14, 2019 at 11:58 AM
    #532
    18BRMTRDSportTaco
    Sachse, Texas
    18 BRM TRDS DCSB
    My Non-Pro LED headlamps arrived from McGeorge Toyota in flawless condition! They double box them and add layers of bubble wrap. The boxes didn't have a ding or scuff on them, so I guess FedEx took care with them which doesn't happen often.
  13. Nov 14, 2019 at 12:54 PM
    #533
    BiGfOOt17
    BiGfOOt17 Well-Known Member
    Jimmy
    Wisconsin
    2016 Toyota Tacoma TRD off road
    ARE cap Pro Grille Black out
    Wow.. that looks mean! love it!
  14. Nov 14, 2019 at 12:57 PM
    #534
    BiGfOOt17
    Jimmy
    Wisconsin
    What conversion Harness did you use?
  15. Nov 14, 2019 at 12:59 PM
    #535
    TRDProOne
    CA
  16. Nov 14, 2019 at 12:59 PM
    #536
    Tacospike
    Two Trucks
  17. Nov 14, 2019 at 1:03 PM
    #537
    BiGfOOt17
    Jimmy
    Wisconsin
  18. Nov 14, 2019 at 2:39 PM
    #538
    emund
    emund Well-Known Member
    Arroyo Grande, CA
    2017 Inferno TRD OR 4x4
    I heard from my Toyota guy they’ve had three purchases and three returns because the lights didn’t fit. Makes me wonder if people didn’t want to figure out the connectors, because that’s the only way they wouldn’t fit a ‘16 to ‘19 correct?
  19. Nov 14, 2019 at 2:55 PM
    #539
    Viper1092
    Viper1092 Well-Known Member
    2019 cement Tacoma TRD OffRoad
  20. Nov 14, 2019 at 3:15 PM
    #540
    Tacospike
    Two Trucks
    sounds about right
