2020 Tacoma OEM LED Headlight Megathread
Discussion in 'Lighting' started by MikeyMcFly, Feb 7, 2019.
  1. Oct 29, 2020 at 7:59 AM
    #1281
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Oh, that's a better idea, ratcheting wrench. Thanks. I could not come up with good ideas last night and it was late. That sounds preferable to the screwdriver.
  2. Oct 29, 2020 at 8:02 AM
    #1282
    Tacospike
    Two Trucks
    My old screw driver worked for me :confused:
    daveeasa and Rainoffire like this.
  3. Oct 29, 2020 at 9:07 AM
    #1283
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I used a ratcheting wrench in my old halogens before. It works. But for me, it was a pain to reach in to turn the bolt and look at the light pattern at the same time. Lurching over the fender didn't do my back any favors. That and it isn't exactly spacious behind the headlights.
    More than one way to skin a cat. The screwdriver way just much easier, just "stab" and twist. Should be like a dollar at Home depot.
    daveeasa likes this.
  4. Oct 29, 2020 at 12:19 PM
    #1284
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    I’m specifically talking about a ratcheting box end wrench not a normal socket wrench. Gear wrench are much lower profile and easy access to the back of the headlights. If you don’t own any, buy them! You’ll thank me later!
  5. Oct 29, 2020 at 12:26 PM
    #1285
    Rainoffire
    Like these?
    That was what i used before.
  6. Oct 29, 2020 at 12:30 PM
    #1286
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    The correct size Phillips head screw driver is actually the preferred way of adjusting the headlights. I use a Snap-On long reach Phillips on mine and never have a problem.
    A possible better alternative to a Gear Wrench ratcheting box wrench (which I also have) would be a 1/4" drive socket with a universal / swivel and a long extension. Since the up / down / vertical adjustment is actually the harder one to get to because its farther down on the back of the housing, I'm not sure a ratcheting box wrench will be much fun to play with in there.
  7. Oct 29, 2020 at 12:48 PM
    #1287
    Too Stroked
    Tom
    Man, I'll tell you, I just went out there and tried a few things and snapped a few picks to help the OP. Being somewhat of a lighting nut, I've probably played with bulbs and aiming way more than most of you. Taking a close look at the passenger side headlight - because it's the hardest one to play with - I just don't see how a ratcheting box wrench will be easier than a screwdriver. And a screwdriver is what Toyota recommends. Here's what my screwdriver looks like in my passenger side vertical adjustment.
  8. Oct 29, 2020 at 1:30 PM
    #1288
    Redline870
    I’m not saying it’s easier. A properly sized screwdriver is the easiest. I’m suggesting an alternative.
  9. Oct 29, 2020 at 1:31 PM
    #1289
    Redline870
    Yes. I’m a little partial to Gearwrench, but those will work.
  10. Oct 29, 2020 at 1:32 PM
    #1290
    Rainoffire
    Yours is a 2nd gen, so it may be a little different.
    For the OEM LED headlights, it is easier on the driver side, cause there is more space. For the passenger side you might have to pull out the water tank to give you more workable room. *If you are going the ratchet wrench method.
    Driver's side:
    Passenger's side:
    Tacospike likes this.
  11. Oct 29, 2020 at 1:34 PM
    #1291
    Too Stroked
    Tom
    Oops. Good point. Thanks for correcting me!
    Rainoffire[QUOTED] likes this.
  12. Oct 29, 2020 at 1:57 PM
    #1292
    Rainoffire
    No worries. There are some similarities and differences between the two, so other opinions are always welcome.
    3rd gens do not have a horizontal adjustment though, only vertical.
  13. Oct 29, 2020 at 1:58 PM
    #1293
    daveeasa
    David
    PNW
    That's what I had read before and what I saw last night so I was confused about multiple adjustment gears till I saw the photo.
    The OEM LED screwdriver channel also seems significantly tighter than those photos but that may be my fuzzy memory from midnight after wrestling with my bumper.
    I'll try again with a round shank real soon, quite curious...
  14. Oct 29, 2020 at 2:19 PM
    #1294
    Rainoffire
    The photos i posted are the back of my OEM LEDs. They are tighter when compared to the halogen's adjustment channels. If i recall correctly, i was able to use my multi tool set to adjust the halogens but not on the LED headlights.
  15. Oct 29, 2020 at 2:41 PM
    #1295
    Too Stroked
    Tom
    I have absolutely no idea why they even put horizontal (side to side) adjusters on headlights anyway. All it does for us 2nd gen guys is cause folks to totally screw up their headlight aiming.
  16. Oct 29, 2020 at 2:48 PM
    #1296
    Redline870
    Because after it gets smashed in an accident it’s almost impossible to get everything as true as factory spec. Having some lateral adjustment can fix your headlight aim in a situation like that.
    Rainoffire likes this.
  17. Oct 29, 2020 at 2:48 PM
    #1297
    daveeasa
    David
    PNW
    Yeah, exactly, I was following your advice and suggestions to a T and got confused by the confidence expressed by Mr Stroked until I saw his photos and noticed he rolls in 2nd gen. I then thought maybe I had posted in the wrong thread :)
    It's all good, stoked for the info and help and advice from everyone, also kinda stoked on the new headlights, they are cool. Don't know why I spent so much time trying to decide, f it, it's only money.
    EDIT: found the perfect #2 screwdriver and stuck an LED Use Only label on it.
    Tacospike and Rainoffire[QUOTED] like this.
  18. Oct 29, 2020 at 3:07 PM
    #1298
    Rainoffire
    Another great use i found for the #2 Phillips is to keep the holes aligned when you are adding AALs to your leaf pack.
  19. Oct 30, 2020 at 4:26 PM
    #1299
    Redline870
    Anyone use the retrofit source LED conversion harness? They have their plugs wires backwards! There are two little locking tabs on the harness side each at different depths. They have it wired upside down if I match the wires up according to their pictures! You can literally separate the connectors if plugged in according to the wiring diagram in the comments (they don’t even have a wiring diagram on their product page, just pictures). Attached are the wiring diagram I found from a users comment and the pictures of the backwards wired connectors.
    If you flip the connector and plug it in, it plugs in good and tight but then you have the polarities reversed.
    @TRSAndrew are the pictures on your product page really correct? (A wiring diagram would be really helpful) If so, then you guys should fix this because your plugs are wired backwards.
    https://www.theretrofitsource.com/toyota-tacoma-oem-led-headlight-conversion?quantity=1
  20. Oct 30, 2020 at 4:42 PM
    #1300
    Redline870
    I was able to de-pin the connector and flip the wires, but that’s ridiculous and should absolutely be fixed. These gaskets don’t inspire confidence though. I imagine it won’t be long before these connections are corroded in upstate NY.
