2020 tacoma spacer lift. YES OR NO
Discussion in '3rd Gen. Tacomas (2016-2023)' started by milesyorkmendenhall, Feb 9, 2021.
  1. Feb 9, 2021 at 10:32 PM
    milesyorkmendenhall
    milesyorkmendenhall [OP] Member
    miles
    2020 tacoma sr5
    nothing yet
    update/disclaimer... I drive about 2 miles to work everyday. and in the summer months I go camping/off road driving almost every weekend..... small leveling kit and 265s sounds like my best bet.. opinions and comments please.
  2. Feb 9, 2021 at 10:36 PM
    milesyorkmendenhall
    miles
    2020 tacoma sr5
    nothing yet
    your response is the reason why I don't think that 285s are for me. as basic as it is I'm really having a hard time swallowing the idea of cutting into my truck... (cmc). I hope i can fit 265s with minimal (plastic) cutting in order to have ZERO rubbing off road considering I put a lot of time off road.
  3. Feb 9, 2021 at 10:38 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Fair comment. It is important to note that whether you lift with a spacer and blocks, or “properly” with taller lift springs all around, your CV angles and driveshaft angles are subjected to the same increase in wear and tear. Usually below 2” this isn’t a problem.
  4. Feb 9, 2021 at 10:42 PM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    youll have zero issues with 265s stock.
    ghostleaf likes this.
  5. Feb 9, 2021 at 10:45 PM
    Stocklocker
    17TRDORDCSBAT
    tcjacado likes this.
  6. Feb 9, 2021 at 11:19 PM
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    True. That is the reason I dont lift mine. 31s rub I tiny bit at full lock on my 99, but I'm ok with it.
    Have a great night.
    Stocklocker[QUOTED] likes this.
  7. Feb 10, 2021 at 12:08 AM
    RustyRyan
    RustyRyan Member
    2018 TRD Sport DCSB (Cement)
    Is a leveling kit different from a spacer lift? Forgive my newbie question but was wondering if a front leveling kit was helpful if possible?
  8. Feb 10, 2021 at 12:17 AM
    Stocklocker
    17TRDORDCSBAT
    They are the same. A leveling kit usually implies just lifting the front as Toyota’s ride higher in the rear from factory so they level out with load in the bed. A leveling kit gets rid of this “rake”, and makes the unloaded truck level.
  9. Feb 10, 2021 at 12:19 AM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    If you dont plan to offroad at all nor care for it a spacer lift is fine.
  10. Feb 10, 2021 at 4:19 PM
    Ricertruc
    Ricertruc Well-Known Member
    17 OR4B4 06 Prerunner
    ADS CO Icon UCA AAL SCS Rims KO2s Fox 2.0 CO
    Check out Fox performance series 2.0 COs with 275s ( I paid $700 but they can be found cheaper. That setup works well with my 2nd gen (same as a 3rd gen suspension). Even spacer lifts need new shocks or adjusted bump stops or they will blow out.
    A regear starts to get in the mix with 285s on the third gen.
    Edit: The Foxes are sold individually for more now from when I got them and I put 80k miles on them since they were bought
  11. Feb 10, 2021 at 4:46 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    265/70/17 Falkens. Toytec suspension lift & SPC UCA & Toytec aal. The front coilovers are 620 eibach/billys & rears boss shocks
