2020 Tacoma stalling out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chuck X1, Jul 2, 2020.
  1. Jul 3, 2020 at 8:02 AM
    #41
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    No one is going to boot you off the forum for naming a lousy dealer if you are being honest about how they are treating you and your issue. In fact, you might find that other people have had similar issues with the same dealer and might advise you where else you could go for better service and the best way to follow up and how to use the manufacturer to get the dealer to act in accordance to the manufacturer warranty.
    And document, document, document, get every piece of paper you DEMAND from the dealer every time it happens and make sure the lousy employee ID number or name is on it. You may be surprised at how helpful a lousy employee becomes when they have their name/ID documented on paperwork to use against them if need be. And that paperwork can be extremely useful when you have to go the lemon law route because it WILL be used against them if need be.
    Also, call/E-mail corporate Toyota and explain the issue calmly, politely, and logically and explain the danger and safety risks to you and your riders if it stalls in an unsafe place like an intersection. And have the persons ID/mane to reference when you are speaking with them. Employee XXX id much better then just ''the dealer'' because it shows you are compiling a record if need be.
    If you know of TSB's and such that relate to the issues you have, let the employees you are speaking with, or his manager if he is unwilling to discuss it, that you know there are issues and you have done research, it is much harder to blow off a customer when the customer is informed and ignorance is seldom rewarded by good service.
  2. Jul 3, 2020 at 8:37 AM
    #42
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I really can't believe Toyota says it is normal. That makes me lose confidence in Toyota. Hopefully its just that dealership. Hope things work out for you.
    Chuck X1[OP] likes this.
  3. Jul 3, 2020 at 8:45 AM
    #43
    Chuck X1
    Chuck X1 [OP] Well-Known Member
    Chuck
    NW Indiana
    2020 Tacoma TRD Off Road
    I’m pretty sure it’s an isolated issue. When I broke down last night Toyota Care was towing me to another dealer that was closer. That dealer said “uh oh..sounds like another Tacoma fuel pump.” I waited nearly three hours for a tow truck that never came. At that point the dealer was closed and I was so far from home (over two and a half hours) that I needed a hotel stay. Truck finally restarted (and died a few more times) and drove it home to original dealer near my house. Don’t trust this truck anymore.
    xxTacocaTxx and bulalo like this.
  4. Jul 3, 2020 at 10:38 AM
    #44
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Take truck to other dealer. The one that mentioned the fuel pump. Your current dealer sounds like an ass.
    dbole007, Smokinnuts, Chako and 2 others like this.
  5. Jul 3, 2020 at 2:15 PM
    #45
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Research your state lemon law. I may be wrong but I believe 3 strikes you’re out ? Or it may be number of days. Document document and document.
    Nick2014 and Draxxas like this.
  6. Jul 3, 2020 at 2:24 PM
    #46
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    1st & last its NOT Normal
    no less its UNSAFE being on a hi-way or In traffic & Ur vehicle takes a powder
    not the 1st time a car/truck sitting in a dealers svc bay is ok ????
    most every1 has access to video/cameras get A journal.............no less write down & RECORD each & every instance
    UR truck lets U down/ leaves U stranded
    make Sure Uv done NO modifications or attempted to fix on Ur own
    good luck
  7. Jul 3, 2020 at 3:32 PM
    #47
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    OP, when was the last time you put fuel in it? Bad fuel can mimic a bad fuel pump. Although the low pressure code would not apply. Just a thought. What a shitty dealer thou...
  8. Jul 3, 2020 at 4:32 PM
    #48
    Chuck X1
    Chuck
    NW Indiana
    The problems have occurred multiple times with different tanks of fuel, so I don’t think that’s the issue. I won’t have any updates until Monday due to the holiday weekend. I’ll just enjoy my base model Camry. It’s kinda like a Tacoma TRD Off-Road.
    AKGSD and doorsidedown like this.
  9. Jul 6, 2020 at 1:22 PM
    #49
    Chuck X1
    Chuck
    NW Indiana
    Latest update. Truck threw another low fuel pressure code. Shop wants to replace the high pressure fuel pump, although threads elsewhere here said that didn’t always fix the problem. Will keep you up to date.
  10. Jul 6, 2020 at 1:25 PM
    #50
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    What a bummer man. I’m sorry this is your introduction to this truck, I hope you get this situated and fixed without the hassle. Good luck OP
    Chuck X1[QUOTED][OP] likes this.
  11. Jul 6, 2020 at 2:28 PM
    #51
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I don't blame you for not trusting the truck, clearly it needs help that the dealer isn't giving it.
    Hopefully you get this sorted out. I can imagine how frustrating it has to be for you.
    BGXtobe and Chuck X1[QUOTED][OP] like this.
  12. Jul 6, 2020 at 2:51 PM
    #52
    JNG
    So accept a new high pressure fuel pump for free under warranty and see what it does.
  13. Jul 6, 2020 at 3:04 PM
    #53
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    20k miles on a 2020? damn you definitely drive your truck. i am sitting at 1174 bought it on April. As for OP, definitely not normal, I have not seen any type of major issues with mine.
  14. Jul 6, 2020 at 3:30 PM
    #54
    2dogs_and_a_taco
    2dogs_and_a_taco Well-Known Member
    Nick
    2020 Army Green Taco
    Yeah, I got it in October of 19 and have been going on adventures ever since.
  15. Jul 6, 2020 at 4:49 PM
    #55
    Chuck X1
    Chuck
    NW Indiana
    Thanks, all. I’m told the pump may not be in until Friday, so that’s one week in the shop. I really like this forum. The post on undercoating was helpful since I live in Northwest Indiana, right below Lake Michigan and we get some pretty impressive snowfalls and lots of road salt. Many of my old Honda’s were conquered by salt, not mechanical issues.
    Bleep100 likes this.
  16. Jul 6, 2020 at 5:17 PM
    #56
    JNG
    Mavcoat or Fluid film is now your best friend.
  17. Jul 6, 2020 at 6:22 PM
    #57
    Chuck X1
    Chuck
    NW Indiana
    Had an old timer tell me about a product called “Cosmoline”. He lives in Pennsylvania and owns an ancient Chevrolet that’s at least thirty years old. I looked it up on Wikipedia and it was developed back inWWII to prevent corrosion.Fluid Film, LPS-3, and others all seem similar. He said the truck still looks like new.
  18. Jul 6, 2020 at 6:24 PM
    #58
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    This does suck man. One reason I went 2Gen. User name says it all!
  19. Jul 6, 2020 at 6:28 PM
    #59
    Chuck X1
    Chuck
    NW Indiana
    Don’t blame you. Simpler is better. When did they start putting two fuel pumps in cars?! I traded in a 2004 Honda Odyssey for this truck and have obviously fallen behind times. I searched and the fuel pump really is over $1,200 !??! Crazy.
  20. Jul 6, 2020 at 6:28 PM
    #60
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    2nd Gen Tacoma's are not without fault either.
    Bleep100, BGXtobe, photogr4x4 and 3 others like this.
