2020 Tacoma Teased
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eric0947, Jan 29, 2019.
  1. Jul 22, 2019 at 8:00 PM
    #2161
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    They should start hitting the dealerships in Sept. If you can wait until deep into December I think you'll see the best deals. At least that's how it's always gone... but you never know.
    TacoBowl likes this.
  2. Jul 23, 2019 at 8:07 AM
    #2162
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    The last time the Nissan frontier was updated the current Tundra was newly redesigned and released thats how long it's been. Both Toyota and Nissan do long cycle pulls. Regarding the Tacoma if they don't carry MT over I see a mad dash of people trying to get their hands on 2024 model or whatever the last year is.
    I like a lot of things about my Tacoma but if they offered the 4Runner in manual it would have been a done deal. I also know that it is blasphemy on here, but if they had the Colorado ZR2 Bison diesel or even the V6 in manual that would have been hard to shy away from.
    shakerhood[QUOTED] likes this.
  3. Jul 23, 2019 at 9:03 AM
    #2163
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    So I have convinced my parents to go halves with me on a truck upon finishing grad school next year. Should I go with a new 2020 OR or buy a turn-key built an older model?
    The new model has some things I definitely want but I would then have to put more money in to build it. Turn key sounds so nice as I am not a gear head, just an outdoorsman who needs the truck to get further out there, carry my gear to the mountains in the winter and get into Overlanding.
    What did people do for their first truck here, start from scratch or start with someone else work and learn from there?
  4. Jul 23, 2019 at 9:37 AM
    #2164
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You might as well buy new, resale is so high you basically pay new prices for a few years old truck that you don't know the history of. Maybe the previous owner did his own oil changes and drained it, then got distracted and started it with no oil for 30 seconds. That kind of thing.
    Mods are nice if you can find a truck that has the upgrades you are looking for, as those mods typically don't add much to the price. However, you have to know what to look for, and make sure the mods were done correctly and professionally. Lot's of hack jobs out there.
    onesixonetwo and TacoBowl like this.
  5. Jul 23, 2019 at 10:32 AM
    #2165
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    I suggest a new OR with the trim level you like. Right out of the show room it will do everything you mentioned. Maybe some tires if the EOM's don't meet your needs.
  6. Jul 23, 2019 at 1:57 PM
    #2166
    Overland&UpMoutains
    Parker
    Deleware
    Thanks for the advice. Interesting you say so many hack jobs. I feel like everyone in the classifieds here says they have the paper work and seems official. I’ll have to keep a closer eye out.
  7. Jul 23, 2019 at 2:00 PM
    #2167
    Overland&UpMoutains
    Parker
    Deleware
    I definitely want to mod it out over time so I can get to more off road places. That’s why I was tempted by a used one with the works on it. But I suppose I can start stock see where it takes me and evolve with the truck
  8. Jul 23, 2019 at 3:54 PM
    #2168
    B619
    B619 Well-Known Member
    2020 DCSB OR Premium VooDoo Blue Tacoma
    In that case I’ll probably just take a look in September and do the “take it or leave it” approach then actually leave and come back a few months later
  9. Jul 24, 2019 at 8:24 AM
    #2169
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    I cannot get enough of how good that voodoo blue sport looks. Must not trade, must not trade.
  10. Jul 24, 2019 at 8:51 AM
    #2170
    6MTPro
    HI -> CA
  11. Jul 24, 2019 at 8:52 AM
    #2171
    TacoBuffet
    AL
  12. Jul 24, 2019 at 9:18 AM
    #2172
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    As of now, my 2017 3rd gen doesn't rattle (but my 2nd gen sure did).
    Keep in mind, it's all still hard plastics. Over a handful of summers, I imagine it'll still end-up rattling quite a bit like my 2nd gen used to.
  13. Jul 24, 2019 at 9:32 AM
    #2173
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Wrap yours. About $600 in vinyl and a fun project.
    TacoBuffet[QUOTED] likes this.
  14. Jul 24, 2019 at 9:33 AM
    #2174
    TacoBuffet
    AL
    Touché / great idea. That or just be content for once with my damn truck, pay it off and move onto something else.
    onesixonetwo likes this.
  15. Jul 24, 2019 at 9:38 AM
    #2175
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    +1 done this to a few of my own vehicles. Cheap, fun, and easy to rip off when you are done.
    TacoBuffet likes this.
  16. Jul 24, 2019 at 10:28 AM
    #2176
    Tacocasper06
    Tacocasper06 Active Member
    2020 Cement Limited
    Good to see these side by side, the two colors im undesided on, im waiting on the 2020 had a 2017 bbp that got totalled
  17. Jul 24, 2019 at 10:49 AM
    #2177
    Stryde22
    Stryde22 Active Member
    Are those the new 2020s? I put in my allocation to a local dealership and I am just waiting to hear back from them....
  18. Jul 24, 2019 at 11:14 AM
    #2178
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I don't think dealers can put actual allocations in yet, so it's probably more they are just promising you they will when available. At least my dealer said they can't actually order them (or even price them out) until basically you see them go up and live on the Toyota website and can build and price them through there. That basically means their ordering system is opened up and can start putting in dealer requests/allocations at that time.
    Undertow likes this.
  19. Jul 24, 2019 at 11:18 AM
    #2179
    TacoBuffet
    AL
    Yep
  20. Jul 24, 2019 at 12:02 PM
    #2180
    Stryde22
    Does this mean pricing and availability will be arriving soon?!?! I am a super patient person if you hadn't noticed.
    TacoBowl and TacoBuffet[QUOTED] like this.
