2020 Tacoma Teased
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eric0947, Jan 29, 2019.
  1. Dec 2, 2019 at 12:44 PM
    #5441
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    How would you other 2020 owners rate your driver door? Seems like mine doesn't close all the way unless you put force in it. The other 3 doors are normal push and closes
    PuyallupJon likes this.
  2. Dec 2, 2019 at 12:50 PM
    #5442
    Stars & Strength
    Stars & Strength Well-Known Member
    LaMont
    2018 Tacoma Pro, AT, Super White
    Only Tailgate Inserts and Window Tint/Decals for now
    I just picked up my 2020 on Friday and noticed the same thing. My 2018 didn’t require as much force to close.
  3. Dec 2, 2019 at 12:52 PM
    #5443
    liquidskin
    liquidskin Well-Known Member
    2020 SR5 4X4 DCSB
    I’m getting wind sound when doing highway speeds and haven’t been able to narrow down where it’s coming from yet. Haven’t noticed that the door isn’t completely closed though. What symptom are you experiencing?
  4. Dec 2, 2019 at 1:08 PM
    #5444
    Toyotako
    Toyotako Well-Known Member
    2020 Cement TRD Off-Road 4x4 DCSB
    My driver door also needs a little force to close but it is tightly closed with no wind noise at highway speed
  5. Dec 2, 2019 at 4:07 PM
    #5445
    BangosTaco
    Stock
    No wind sound with me mine but it is hard to close it shut normally
  6. Dec 2, 2019 at 5:08 PM
    #5446
    Palmer812
    Palmer812 Well-Known Member
    Robert
    19 SR5 double cab v6 Cement Gray
    Funny you should ask. I had my 2019 for 5 months and never failed to close the door all the way. On my 2020 about half of the time the door doesn’t shut all the way. I have to open it back and shut it again. It’s not a problem. It’s just tighter and requires a little more force to close.
  7. Dec 2, 2019 at 5:55 PM
    #5447
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    They may have tightened tolerances up some or made the seals thicker. I know they made the side windows thicker to help reduce noise, so that was a concern and not surprising that they may have made other smaller tweaks as well.
  8. Dec 2, 2019 at 6:30 PM
    #5448
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    This is true for my PRO.
    You have to slam the door to get it to close. All the doors for that matter.
  9. Dec 2, 2019 at 7:02 PM
    #5449
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    Every Toyota that I have owned, when the air vent is open the doors are easy to close. When the air vent is set to recirculate, it takes more force to close the doors.
  10. Dec 2, 2019 at 8:49 PM
    #5450
    ahaberkorn
    ahaberkorn Member
    My truck finally came in on Friday. Took it on its first fishing trip on Saturday. Pic is bad, but loving the truck so far!
    jetguy1, Spades4Lif3, Sandy94 and 2 others like this.
  11. Dec 2, 2019 at 11:22 PM
    #5451
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    I recently purchased a 2020 TRD OR and my driver's door does just the same as yours. However there is no way would I let a dealer f**k with it in any case. I just have to give a little more force unless a window is down or another door is already open. I have actually got use to it and just give that door a little extra push when closing.
  12. Dec 3, 2019 at 4:07 AM
    #5452
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Re: wind noise/ hard to shut doors
    Something was probably changed for wind noise purposes- firmer seal, one less vent hole in the seal, door adjustment process was changed, etc. If you could see how that is adjusted on other cars, you'd be horrified. It's enjoyable to do when you're angry, I'll leave it at that.
  13. Dec 3, 2019 at 4:21 AM
    #5453
    Eagle46
    Eagle46 My Baby..
    Blake "Blakie"
    Langhorne, Bucks Cty Pa SEPA Philadelphia Area
    2020 TRD Sport DCLB, AT 4X4 VDB
    I Am in Philadelphia Area, I found the OEM was $169.00, then I did some digging, and I found a dealer that is in KS and would sell it for $143.00, Local dealership did price match for the $143.00, also My local dealership printed of copy if install instructions for dealership all 23 pages!,They tried to email it to me!, all I told them was my email was having issues, so they printed it off, let them use their ink!
  14. Dec 3, 2019 at 4:23 AM
    #5454
    Eagle46
    Eagle46 My Baby..
    Blake "Blakie"
    I got a $143.00 from a dealership in KS, Local dealership price matched the $143.00, also local dealership printed off the 23 page install guide for No Charge.
  15. Dec 3, 2019 at 5:40 AM
    #5455
    Sandy94
    Sandy94 Well-Known Member
    The Commonwealth
    Toyota Tacoma
    Elaborate
  16. Dec 3, 2019 at 6:38 AM
    #5456
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    A normal situation would go like this: Top rear of the door gap off? Over flush on top and pulled in at the bottom? Bend the bottom out until it's even, adjust door in or out at the striker, adjust closing force. Bend, slam, over-extend, whatever you need to do. The noises are horrifying too, at first. Once you remember cars are just shiny sheet metal, it makes a lot more sense. Same for hoods, hatches, etc. A twist here, a shove there and it's like magic. I'm usually watching, I'm not too fond of doing it.
  17. Dec 3, 2019 at 6:45 AM
    #5457
    AManWearingAHat
    AManWearingAHat Member
    2020 Cement Grey TRD Offroad
    Stock
    Brand new 2020, no issues with my driver door.
  18. Dec 3, 2019 at 8:18 AM
    #5458
    Grindstone
    Grindstone Requires Adult Supervision
    Whichever door is last to close, if you do it too lightly. My guess is the air seal is strong and the cabin air acts as a cushion.
    markgphoto likes this.
  19. Dec 3, 2019 at 12:53 PM
    #5459
    ReloadX
    ReloadX Well-Known Member
    Yep, I can concur that the 2020 doors are harder to close than the previous years. I have to put a little bit more effort into closing it or it will not close all the way. I suspecting the stronger rubber air seals as well.
    Grindstone likes this.
  20. Dec 4, 2019 at 6:57 PM
    #5460
    Toyotako
    Just came back from the dealer for the power tailgate lock installation. $169 + labor. Supposedly the lead auto tech took on the project by reading 23-page install guide and working on it for 3 hrs. Amazing job w/ no traces of wires visible anywhere! I would highly recommend it at the Toyo dealer. Part and service are under warranty.
    HiroAntagonist likes this.
