2020 Tacoma Teased
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eric0947, Jan 29, 2019.
  1. Dec 4, 2019 at 7:05 PM
    #5461
    duckytw
    duckytw Well-Known Member
    Me too on the door!!! I thought it was just me, no issue on a 17 with same force. I noticed when another door is open, its much easier so im thinking its a different pressure flap vent thing.
  2. Dec 5, 2019 at 6:20 AM
    #5462
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    This may be a good thing. If they stiffened or changed the cab vents it will likely reduce the noise levels that are/were present in the 16- 19's.
    Possibly keeping the climate controls on default of position of open rather than recirculate may help the pressure when the last door closes.
    El Chivo Norteño likes this.
  3. Dec 5, 2019 at 7:12 AM
    #5463
    Blauman
    Blauman Well-Known Member
    San Diego
    2020 MGM DCSB 4x4 OR
    On the TFL video posted a while back the Toyota dude said they reduced wind/road noise in the 2020's. So maybe whatever they did to achieve that is what you all are experiencing.
  4. Dec 6, 2019 at 12:19 PM
    #5464
    Eagle46
    Eagle46 My Baby..
    Blake "Blakie"
    Langhorne, Bucks Cty Pa SEPA Philadelphia Area
    2020 TRD Sport DCLB, AT 4X4 VDB
    Truc577[QUOTED] likes this.
  5. Dec 6, 2019 at 12:55 PM
    #5465
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    Build date is the 19th. Been trying to order a 2020 TRD OR with TECH and LED HL minus the TRD PREMIUM PKG since Sept. 5th when the first allocation was submitted. I cant have a moon roof my heads hits, I need that extra 2 inches!
    Eagle46[QUOTED] likes this.
  6. Dec 8, 2019 at 10:23 AM
    #5466
    Bob Laublaw
    Bob Laublaw Well-Known Member
    Pretty sure you work where I work. I've seen your truck in the parking lot lol
    Grindstone[QUOTED] likes this.
  7. Dec 8, 2019 at 11:02 AM
    #5467
    TRDBruiser
    TRDBruiser Well-Known Member
    Northern Idaho
    TRD Pro
    Can someone elaborate on this? I didn’t know remote start was even a possibility. So you can download an app and turn on your vehicle from the app? I have something similar on my Ford and love it. I am in the market for a 20 TRD Pro—remote start would be an added bonus for me!
  8. Dec 8, 2019 at 11:16 AM
    #5468
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    The 2020s have remote start with Entune 3.0. Click lock on the fob 3 times if you are close enough, otherwise also has an app you can use. Free for first year or two then there is an annual subscription. You can also lock/unlock from the app and couple other things.
    Sounds like it is only for the AT sadly, no love for the MTs.
  9. Dec 8, 2019 at 11:25 AM
    #5469
    Grindstone
    Grindstone Requires Adult Supervision
    There's the normal fob remote start, but there's a subscription service through Toyota that uses an app that you can remote start, lock/unlock doors, and monitor status (odometer, fuel, upcoming service, where you parked, trip, etc). You can even link it through Google Assistant/Alexa, but it's extremely cumbersome. Still kinda neato that I can yell at my house to turn on the truck.
    If you're not aware, the truck will stop once you open a door, no matter what method of remote start you used.
    TRDBruiser[QUOTED] likes this.
  10. Dec 8, 2019 at 11:25 AM
    #5470
    TRDBruiser
    Northern Idaho
    TRD Pro
    Okay, thanks for the info. For 2020, entune 3.0 is standard on all PROs correct?
    Lol it would be interesting to have remote start for MTs.
  11. Dec 8, 2019 at 11:33 AM
    #5471
    TRDBruiser
    Northern Idaho
    TRD Pro
    Great info! Kinda of a bummer that the vehicle shuts off when you open the door, but I know Toyota does it to prevent theft. Is there a time limit on how long the vehicle can run on remote start? When Ford first came out with it, The vehicle would only run for 15 mins before it shut off. I like having the remote start for my dogs during the summertime as you can keep the AC running without leaving the keys in your vehicle.
  12. Dec 8, 2019 at 12:07 PM
    #5472
    BadFlounder
    BadFlounder Well-Known Member
    Colorado
    2020 MGM TRD Pro
    The annual subscription has no effect on the fob. If you stopped paying for the app the remote start will still work via the fob, although you do need to be fairly close to the truck. My Jeep was the same way after I declined to pay for the app after the first year.
    TRDBruiser likes this.
  13. Dec 8, 2019 at 12:14 PM
    #5473
    deusxanime
    MN
    Entune 3 is on all of them, I think even down to the SR or at least the SR5.
    They make aftermarket remote start for the MT but Toyota doesn't see fit to give us it from the factory.
    Edit: To clarify, Entune 3 is on them, but the Premium Audio is required for remote start, which sounds like it is only available as an option on TRD trims.
  14. Dec 8, 2019 at 1:18 PM
    #5474
    Grindstone
    I thought I read somewhere else that it was 15 minutes, but the app says 10.
  15. Dec 8, 2019 at 1:35 PM
    #5475
    Palmer812
    Palmer812 Well-Known Member
    Robert
    19 SR5 double cab v6 Cement Gray
    Just tried it on my 20 TRD Sport and no remote start.
  16. Dec 8, 2019 at 2:13 PM
    #5476
    BadFlounder
    Colorado
    2020 MGM TRD Pro
    I know it is part of one of the add-on packages....premium or advtech. I can’t recall which, but you might not have it if you don’t have the right option package.
  17. Dec 8, 2019 at 7:11 PM
    #5477
    sooners71
    sooners71 Active Member
    13 PreRunner
    I use it on my 2020 Pro and it will last for 10 minutes and then shut off.
  18. Dec 8, 2019 at 7:16 PM
    #5478
    Toyotako
    Toyotako Well-Known Member
    2020 Cement TRD Off-Road 4x4 DCSB
    No, the advanced tech package does NOT come with remote start with your remote key. It only comes with premium Audio+Nav or premium off-road package (All Pros, TRD sports & OR with the add-on premium package).
  19. Dec 8, 2019 at 8:14 PM
    #5479
    BadFlounder
    Colorado
    2020 MGM TRD Pro
    Might want to re-read the post. “...premium or advtech package...” meaning it comes with one or the other. lol
    And I have a 2020 TRD Sport with Premium and AdvTech package that has remote start with the fob. ;)
  20. Dec 8, 2019 at 10:03 PM
    #5480
    LongTaco1
    LongTaco1 Member
    Carlos
    2020 Tacoma Trd offroad DCLB
    Picked this 2020 4x4 offroad DCLB up about a month ago
    Instagram: @blackpacktaco
    KaseTRDor, Devious6 and BadFlounder like this.
