2020 Tacoma weak heater
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sandalsnsocks, Jan 21, 2020.
  1. Jan 21, 2020 at 8:53 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The heated seats are freakin awesome!
  2. Jan 21, 2020 at 8:53 AM
    Falcon5Romeo
    Falcon5Romeo Active Member
    Tex
    2019 Tacoma SR5 Magnetic Gray
    I start my '19 and drive, and about 3 minutes later it's blowing hot air. It was 15 degrees this morning.
  3. Jan 21, 2020 at 8:54 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Set to auto at the highest temperature setting. If the cab is not burning up after 25 minutes of driving, you have a problem.
  4. Jan 21, 2020 at 8:56 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    take it in, not normal at all.
    mine heats up fast and after 5 min. I have to turn it down, same with the seat heaters, those will melt my ass on high! :eek:
    Chew likes this.
  5. Jan 21, 2020 at 8:58 AM
    ryan760
    ryan760 Well-Known Member
    [​IMG]via Imgflip Meme Generator
  6. Jan 21, 2020 at 8:58 AM
    Sandalsnsocks
    Sandalsnsocks [OP] Member
    2020 Tacoma SR 4wd V6 auto double cab
    It’s definitely something I can live with, as long as you guys don’t think it would have any detrimental effect on engine life?
  7. Jan 21, 2020 at 10:55 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    I could be wrong but I think I remember reading that the electric heat element used to supplement the standard heater core (until the coolant reaches warm enough temp to heat the vehicle) was part of a separate package called "cold area package" or something along those lines, and possibly included the electric block heater as part of the package. Couldn't even get one in the south if I remember the post correctly.
  8. Jan 21, 2020 at 11:28 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I'm fairly sure I don't have it in my 18. I have the exact same problem as the OP. Some of these people chiming in saying it's more than adequate living in areas they consider cold when it's 30 degrees.
  9. Jan 21, 2020 at 11:41 AM
    Sandalsnsocks
    Thanks for all the reply’s really cool to get so many! Is there any way to check the thermostat without pulling it?
  10. Jan 21, 2020 at 11:47 AM
    shakerhood
    Southern Ohio
    I believe all V6's come with it, pretty sure if you look at the Underhood fuse box you will see a couple relay's marked PTC.
  11. Jan 21, 2020 at 1:16 PM
    WZ00R2
    TN
    2020 Cement OR
    If it doesn't work when you set it to AUTO and the temp to high, just take it to the dealer.
    shakerhood likes this.
  12. Jan 21, 2020 at 1:21 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  13. Jan 21, 2020 at 1:22 PM
    BillsSR5
    bill
    2014 SR5
    o_O
  14. Jan 21, 2020 at 1:24 PM
    WZ00R2
    TN
    2020 Cement OR
    You can also view PID data via an OBDII port reader. You will be able to view the coolant temp in real time to get a good idea of what the thermostat is doing.
    shakerhood[QUOTED] and Paul631 like this.
  15. Jan 21, 2020 at 1:26 PM
    #35
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    So 24 degrees here today, started truck cold after work shift, cranked heat controls, and I'll be damned but there was much warmer than outside air at the vents.
    I have a 19 without auto climate control.
    Still took the engine almost 15 minutes to reach operating temp.
  16. Jan 21, 2020 at 1:28 PM
    #36
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I appreciate you posting this and @shakerhood for bringing the subject up, I had no idea we had a "preheater"!
    shakerhood and ryan760[QUOTED] like this.
  17. Jan 21, 2020 at 1:34 PM
    #37
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Harbor Freight sells a cheap infrared thermometer you can point at various things to get a temp reading - that would work great, point it at the top and bottom radiator hoses/tstat housing while the truck warms and you'll get a great idea of when the tstat opens.
    Tacman19 likes this.
  18. Jan 21, 2020 at 1:37 PM
    #38
    Icancounttotensometimes
    Icancounttotensometimes Well-Known Member
    James
    Colo Springs, CO
    ‘19 Cement DC TRD ROW YOUR OWN
    Non-ethanol 91
    My ‘19 is the same, very slow to warm up. Takes about 3 miles or so to blow decent warm heat on auto (68) with butt warmers on high. Takes 15 min under actual driving to warm to full normal temp. If I get stuck at a stop light for 5 min the temp gauge won’t move, however it will do a high idle about 1200-1300 rpm. I have a manual. Temps in my morning drives 5-35 (F) so far this winter.
  19. Jan 21, 2020 at 2:52 PM
    #39
    Sandalsnsocks
    Maybe 15 minutes to get to operating temp is normal then? Just seems a bit slow compared to others
  20. Jan 21, 2020 at 3:54 PM
    #40
    Sandalsnsocks
    On way home with air going to dashboard vents it heated like a champ! I guess it’s just the floor vents that suck
