2020 TRD O/R Oil Consumption Advice Request
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Callmesb, Jun 15, 2022.
  1. Jun 15, 2022 at 4:21 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Losing 2 qts of oil between changes with only 20k miles definitely shouldn't happen with a healthy toyota engine. Its gotta be going somewhere. This use to happen on those old 3.0 v6 sludge engines toyota had after 75k miles.
    t2c likes this.
  2. Jun 15, 2022 at 4:24 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I wouldn't go to straight 30W but a 5W30 conventional might help with the consumption.
    That said I'd be fine with that rate on a 200k mi truck not one this new lol
    SR-71A, t2c and davidstacoma like this.
  3. Jun 15, 2022 at 6:16 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    He said his oil light is come on one and sometimes twice between the changes and he’s having to add 2 quarts each time it happens. For the dealership to say they can find nothing to indicate any problems sounds like total bs to me. If it’s really burning 4 per 5k miles there will definitely be a problem you can find without having to look to hard. I’m surprised it’s not smoking.
    zoo truck[QUOTED], t2c and Wulf like this.
  4. Jun 20, 2022 at 7:58 PM
    Callmesb
    Callmesb [OP] Active Member
    Scott
    2020 Tacoma TRD Off Road
    Fox 2.5/2.0s, Icon RXT, Fuel Nitro 6 17x9 with 285/70/17 BFGs AT KO2a, ARE CX HD Canopy, Prinsu Cab Rack, CBI T3 Front and Rear Bumpers
    Nothing on the ground, and no oil that I can see under the hood. I will take a deeper look. The tailpipe smokes visibly anytime it's running (not just on startup or ion cold weather), so I assume it's burning it.
    Hook78[QUOTED] likes this.
  5. Jun 20, 2022 at 8:02 PM
    Callmesb
    Scott
    I burn less than 1 qt. per 1,200 miles, but that comes out to just under 4 or 5 quarts between oil changes at 7k intervals. That's unacceptable IMO.
    Jerry311SD, Junkhead and mosccat like this.
  6. Jun 20, 2022 at 8:03 PM
    Callmesb
    Scott
    I'd trade it in a heartbeat, if only I didn't have $40k worth of parts and upgrades on this thing :-/
    mquibble, hfjeff and Junkhead like this.
  7. Jun 20, 2022 at 8:04 PM
    Callmesb
    Scott
    I will take a closer look. Is that a warranty-able issue?
  8. Jun 20, 2022 at 8:07 PM
    Callmesb
    Scott
    I use 0w-20 per the manual, and have had all my oil changes done by the dealership (whom I assume use the proper weight).
  9. Jun 20, 2022 at 8:09 PM
    Callmesb
    Scott
    I, too, am a previous Subaru owner, and had oil consumption issues. The Subaru dealership gave me the runaround for over two years, until, finally, the class action suit forced them to warranty repair my engine. This is giving me PTSD.
  10. Jun 20, 2022 at 8:11 PM
    Callmesb
    Scott
    My 2018 TRD O/R was the same. No oil usage between 5k oil changes. I am now regretting the fact that I traded it for this 2020.
  11. Jun 20, 2022 at 8:11 PM
    05 4x4
    05 4x4 Well-Known Member
    If it’s smoking out of the tailpipe there is no way there aren’t legit issues.
  12. Jun 20, 2022 at 8:14 PM
    Callmesb
    Scott
    100% will do.
    tonered[QUOTED] likes this.
  13. Jun 20, 2022 at 8:19 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    SR-71A likes this.
  14. Jun 20, 2022 at 8:20 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    It is part of warranty and an easy fix. You would see oil on the ground and not out of tailpipe if it was the timing cover.
    My buddy who did all his oil changes at the dealer had his 5.7 tundra start burning oil that quickly turned into a new engine. All covered under warranty. Could have been something a a simple as a tech not using correct amount/weight of oil once.
    A leak down test and cylinder compression test should be able to answer said question.
  15. Jun 20, 2022 at 8:25 PM
    #35
    Callmesb
    Scott
    That's a great deal.Thanks for the tip!
    brian2sun[QUOTED] likes this.
  16. Jun 20, 2022 at 8:27 PM
    #36
    Callmesb
    Scott
    If only I didn't put all these CBI bumpers and custom parts into it, not to mention the color matched canopy. I think I'm screwed.
  17. Jun 20, 2022 at 8:30 PM
    #37
    Callmesb
    Scott
    Yes, and yes.
  18. Jun 20, 2022 at 8:30 PM
    #38
    Callmesb
    Scott
    I will pull plugs and report back
  19. Jun 20, 2022 at 8:32 PM
    #39
    Callmesb
    Scott
    Dealership does all oil changes, but I have not verified levels directly after. I will going forward.
  20. Jun 20, 2022 at 8:33 PM
    #40
    Callmesb
    Scott
    It's smoking. Albeit lightly, but the exhaust is visible 100% of the time it's running.
