2020 TRD sputtering...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitelandcruiser, Mar 23, 2023.
  1. Mar 23, 2023 at 6:24 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I thought something sounded familiar.
  2. Mar 23, 2023 at 6:26 PM
    Firn
    Firn Well-Known Member
    White OR
    87e10, 88e15, 91 (probably e something), and 93 top tier. Never noticed a change on any of them. Even logged ignition advance vs load and zero change regardless of what fuel I was running, I don't remember what the fuel trims did aside from being nothing major that stood out
    After my tests it's been 87 from a variety of stations.
    I cannot say with certainty I tried e0 but I have not seen it around here
    Junkhead[QUOTED] likes this.
  3. Mar 23, 2023 at 6:27 PM
    Firn
    White OR
    I don't think 2500 is lugging, that's where it does it most for me. All the way up to 3400 actually.
  4. Mar 23, 2023 at 6:35 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    My truck is sensitive to gas. It runs worse on non shell/chevron 87. Costco for ex makes it more likely to “stutter” at 1500-2500 rpm in 1st and second gear. It’s really annoying, you’re sitting there like a bobble head
    cryptolime and Lt. Dangle like this.
  5. Mar 24, 2023 at 4:33 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    3rd owner with only 14k miles? Kind of tells you something.
    shakerhood, oconnor and Junkhead like this.
  6. Mar 24, 2023 at 6:10 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Didn't answer the question about what the RPMs were. But if you're letting off the throttle at 60, in 6th, then slowly getting back on the throttle? "Barely touching the gas" as you said...sounds like you're lugging the motor.
    Chew and zoo truck like this.
  7. Mar 24, 2023 at 7:23 AM
    Firn
    White OR
    How would using 6th gear at 60mph be lugging the motor?
  8. Mar 24, 2023 at 8:00 AM
    blu92in99
    Justin
    Elk Grove, Ca
    Comprehension of the written language is a lost art, apparently. OP said they're letting off the gas at 60, in 6th, then they're barely touching the gas to get back on it. Steady cruising at 60mph in 6th won't lug the motor, but that's not what OP is complaining about.
    Admittedly; We don't know how long they're off the gas, how much speed is being scrubbed while they decelerate/off the gas, what the RPMs/vehicle speed are at when they barely get back on it, if the road is flat or on an incline when this happens, etc. I'd specifically asked OP about engine RPMs, amongst other variables, and they basically side-stepped all of it. So I'm forced to go by the assumption they're lugging the motor.
    Chew likes this.
  9. Mar 24, 2023 at 9:58 AM
    Firn
    White OR
    Dont be pedantic. Let off the gas at 60mph and then barely touch the gas is LESS or the SAME throttle input as it took to cruise at 60mph.
    Pretty darn easy to let off the gas and then get right back into it without losing hardly any speed at all. But fine, if we want to play the what-if game then do you think that cruising at 55mph in 6th is "lugging" the motor? Because its darn easy to do that without losing 5mph.
    Anything else is conjecture to justify an argument and I'm pretty darn sure he wouldn't specifically identify 60mph if his speed dropped to 40 and was climbing pikes peak at the time. Apparently "reading comprehension" includes inventing a story to justify ones argument.
    "Forced to go by the assumption he was lugging the motor", or, you know, this low mileage three owner truck has similar issues to those that have been discussed on here frequently before.
  10. Mar 24, 2023 at 10:21 AM
    blu92in99
    Justin
    Elk Grove, Ca
    Conjecture to justify an argument? Look in the mirror much? o_O
    The devil's in the details...of which OP has provided almost none. You're making as much of an assumption on how they're driving/what they're experiencing as I am.
    I've been driving manuals for decades, everything from '3 on the tree' up through modern-day manuals and haven't to play the on/off throttle game to maintain a set speed since I was a kid.
    End of the day Firn; you asked me a question, I answered it. I tried to explain my POV, and you're trying to berate me for it. Talk about pedantic. Have a good day.
  11. Mar 24, 2023 at 10:25 AM
    Firn
    White OR
    Don't claim the victim, you were treated with the attitude you responded with.
    If you need this kind of victory in life then have it, I'm done
  12. Mar 24, 2023 at 12:51 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Light throttle, low RPM (less than 1500) gives my truck a noticeable miss on 87. I wouldn't call it a sputter, but I don't know if OP and I use the same vernacular. I always tell people with weird issues to try a tank of 93 and see what happens. Maybe it helps, maybe it doesn't. It matters on my truck.
  13. Mar 24, 2023 at 12:57 PM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    All the clamps post MAF tight? Any false air only on accel?
  14. Mar 24, 2023 at 7:59 PM
    MGMDesertTaco
    The multiple owner issue mentioned given the low mileage wouldn't concern me given the truck is a manual. Most claim they can drive a manual or want a manual and then quickly begin to hate it for a daily driver. It's not for everyone. :burnrubber:
  15. Mar 24, 2023 at 8:18 PM
    #35
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Being a parts cannon kind of guy, I’m going to say ditch the low output oe ignition coils for some higher output msd sparkolators and see if that makes any difference
  16. Mar 24, 2023 at 8:40 PM
    #36
    eon_blue
    Azusa, CA
    Rolling down the road in 5th/6th gear.... Do you mean the freeway? I can't think of any reason I'd be in those high gears on any regular road unless it was highway speed limits. Sounds like you're lugging the engine
    Taco y mas and Chew like this.
  17. Mar 25, 2023 at 7:08 AM
    #37
    zoo truck
    None
    Buddy of mine's 2019 3.5 trd did the same, while my 2020 3.5 won't. Both of the trucks were using 87....at least I know i was. It drove him nuts. I think it's the way some of these engines are tuned as my truck had definitely more giddy-up than his, although both had the same latest stock tsb tunes. Only difference, his was a trd double cab while mine is an access cab.
  18. Mar 25, 2023 at 10:01 AM
    #38
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I cruise in 5th/6th in city all the time. 1200-1300 or so RPMs. With light throttle application it’s perfectly smooth. Stock or tuned.
    FWIW, I’ve always used 91E0 or higher after dealers fill.
  19. Mar 25, 2023 at 10:24 AM
    #39
    zoo truck
    None
    My truck cruises fine at 1400 rpm, or so on the back roads here in 6th doing around 50 mph running 87 E10 fuel. It rarely needs to exceed 2500 rpm, even on the hills to maintain those speeds.
  20. Mar 26, 2023 at 7:04 AM
    #40
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    reset learned values. these trucks are sensitive to fuel quality.
