2020 truck immobilized--Toyota cannot locate source of problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by parkse, Oct 20, 2020.
  1. Oct 20, 2020 at 9:18 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    @tonered with no codes being thrown and the description, could this be brake related?
    CygnusX191 and tonered like this.
  2. Oct 20, 2020 at 9:20 AM
    parkse
    parkse [OP] Member
    Ernie
    2020 Double Cab Off Road with 6 speed manual transmission
    Guess anything is possible, but I have been driving Tacomas for 15 years with 6 speed manual transmission(294,000 miles on previous truck. Since I have gotten the truck back, I have tried starting out in other gears....truck goes.....no warning lights etc...
  3. Oct 20, 2020 at 9:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It seems like it, but it is really hard to tell.
    In my mind, esp with no codes, my progression would be:
    -- Try pulling the battery terminals. Negative off first and on last. Touch them together for a few seconds to fully drain down the systems.
    -- Try a DTC and Learned Value Reset. That will need TechStream and a USB OBD adapter, like a Tactrix. Unless they can hook up with a local TW'er.
    Do a 5min idle while touching nothing before driving.​
    -- Dealer, if a code gets stored.​
  4. Oct 20, 2020 at 9:22 AM
    parkse
    parkse [OP] Member
    Ernie
    When it does not move, I push clutch in to keep engine going. Try several times. Then shut engine off.
    tonered likes this.
  5. Oct 20, 2020 at 9:23 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Man there are some sharp tacks on this thread OP, give the suggestions a go and please keep us all posted
    rando451 and tonered like this.
  6. Oct 20, 2020 at 9:24 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The ABS in the 3rd Gen is next level, esp the ORs and Pros. It can do really good stuff in all Tacos and is the only one that I have had that I don't shut off before every drive. But, yours is unique problem?
    tcjacado likes this.
  7. Oct 20, 2020 at 9:24 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Wonder if there's a position sensor on the shifter that's bad.
    tonered likes this.
  8. Oct 20, 2020 at 9:28 AM
    parkse
    parkse [OP] Member
    Ernie
    Yes. I wondered whether I might somehow be trying to start in 3rd instead of 1st. Tried that to see the reaction. It is not pretty, but truck will move without stalling and there are no warning lights....
    CygnusX191[QUOTED] likes this.
  9. Oct 20, 2020 at 9:30 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Did you use the parking brake prior to the behavior? Some of this sounds similar to the parking brake issue I encountered but much of it does not.
  10. Oct 20, 2020 at 9:31 AM
    parkse
    parkse [OP] Member
    Ernie
    Let's say that the truck is not completely in gear.....What would cause low engine oil pressure etc to come on?
    tonered likes this.
  11. Oct 20, 2020 at 9:33 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Um....is the oil in fact, low? Just a thought.... :bananadead:
    LoveableWerewolf and tonered like this.
  12. Oct 20, 2020 at 9:34 AM
    parkse
    parkse [OP] Member
    Ernie
    Not been washed. Am in southern Arizona. Only 1800 miles on truck. First incident was about 1300-1400 miles.
    CygnusX191 likes this.
  13. Oct 20, 2020 at 9:37 AM
    parkse
    parkse [OP] Member
    Ernie
    First thing we did was to check oil level. Dealer has had the truck twice....I assume that they also checked. They did say that oil pressure was normal.
    CygnusX191[QUOTED] and tonered like this.
  14. Oct 20, 2020 at 9:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    AFAIK, the only sensor on the MT is for neutral.
    If the RPMs dip below idle, the oil pressure drops low enough to hit the sensor threshold.
    CygnusX191[QUOTED] and tcjacado like this.
  15. Oct 20, 2020 at 9:38 AM
    #35
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    Doesn't sound like the drum brake issue since the issue resolves upon restart.
  16. Oct 20, 2020 at 9:41 AM
    #36
    tcjacado
    tcjacado Well-Known Member
    Have to rule everything out at this point.:cheers:
  17. Oct 20, 2020 at 9:41 AM
    #37
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sounds like the brakes aren't releasing for one reason or another. Do these have a hill start assist?
    tonered likes this.
  18. Oct 20, 2020 at 9:44 AM
    #38
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It seems like it, but MT ORs and Pros do not have HA.
    I believe there is a problem with CrawlControl on either 2019 or 2020 ATs? I wonder if this could somehow be related?
  19. Oct 20, 2020 at 9:45 AM
    #39
    TheCochese
    Describe what happens to the engine RPMs when you let the clutch out during these events. Does it drop like it is stalling, or does it stay at idle?
    tcjacado, tonered and 0xDEADBEEF like this.
  20. Oct 20, 2020 at 9:48 AM
    #40
    0xDEADBEEF
    Or something sticky in that newfangled electronic brake system, a slow switch or a valve or something. I actually have no idea how it works.
    Seems like we'd see other complaints if it were widespread
    CygnusX191 and tonered[QUOTED] like this.
