2021 audio Upgrade, Thoughts?
Discussion in 'Audio & Video' started by isayno1525, Jan 21, 2021.
  1. Jan 23, 2021 at 11:40 PM
    #41
    Yodastacotruck
    Yodastacotruck Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    yeah I found the seller the suite is down the street from where I live wonder if I could just walk In there lol
  2. Jan 23, 2021 at 11:43 PM
    #42
    Juice Weasel
    Juice Weasel Well-Known Member
    3rd Gen Tacoma SR5
    Maybe you are the seller and are just messing with us all!
  3. Jan 23, 2021 at 11:45 PM
    #43
    Yodastacotruck
    Stock
    was thinking of going the direct to speakers route as well but then have to find a way to
    Hide the new wire and make it look clean and I’d lose the factory eq I’n the head unit also what’s throwing me off is the front tweeters are connected to the door speakers so I wonder if there is a factory crossover somewhere the dash
  4. Jan 23, 2021 at 11:47 PM
    #44
    Yodastacotruck
    Stock
    Plot twist
    Juice Weasel[QUOTED] likes this.
  5. Jan 23, 2021 at 11:48 PM
    #45
    Juice Weasel
    3rd Gen Tacoma SR5
    The factory crossover is not likely bc tweeters are wired in parallel with door. Probably just so weak as to no blow them or measly little capacitor imbedded in factory tweeters.
    The EQ in the head would not be lost if it indeed happens in the head.
  6. Jan 23, 2021 at 11:51 PM
    #46
    Yodastacotruck
    Stock
    I added the Subaru kicker tweeters and the kicker cs in the doors so it has tons of highs but I thinking probably is just a capacitor built into the tweeters I wonder how many watts these little tweeters can handle if wired in parallel will the rms watts I send to the front speakers also be the same power going to
    The tweeters? Wonder if it be better to
    Just get a high wattage component speakers
  7. Jan 23, 2021 at 11:53 PM
    #47
    Juice Weasel
    3rd Gen Tacoma SR5
    From what others are saying the Subaru suck and are just a plu n play snake oil remedy circular logic....they fit therefore they are awesome. NOT!
  8. Jan 23, 2021 at 11:55 PM
    #48
    Juice Weasel
    3rd Gen Tacoma SR5
    easy to test just hook one up to a mono block low passed sub amp with a minimal of 1k watts and see what happens. Lol
  9. Jan 23, 2021 at 11:56 PM
    #49
    Yodastacotruck
    Stock
    they actually sound pretty clean to be honest they have a nice clear highs but I suspect more wattage they fry
  10. Jan 23, 2021 at 11:58 PM
    #50
    Yodastacotruck
    Stock
    well if they don’t blow you have a winner?
  11. Jan 23, 2021 at 11:58 PM
    #51
    Juice Weasel
    3rd Gen Tacoma SR5
    Imagine if in life if all it took was something to fit perfectly somewhere else to be considered awesome. I would have a thousand kids by now.
    GRNT4R likes this.
  12. Jan 23, 2021 at 11:59 PM
    #52
    Juice Weasel
    3rd Gen Tacoma SR5
    lol
  13. Jan 24, 2021 at 12:00 AM
    #53
    Yodastacotruck
    Stock
    I never said they were awesome but I would not say there junk they sound pretty damn good compared to the factory ones the highs are very clean and clear for what they are
  14. Jan 24, 2021 at 12:01 AM
    #54
    Juice Weasel
    3rd Gen Tacoma SR5
    I can’t hear anything over 10k not the best person to ask. Disregard everything I have typed!
  15. Jan 24, 2021 at 12:22 AM
    #55
    Yodastacotruck
    Stock
    thanks for the knowledge
  16. Feb 6, 2021 at 9:50 AM
    #56
    Presley217
    Presley217 Active Member
    2020 TRD OR Manual
    Hey man is there an adapter just for adding a subwoofer? I'm new to wiring stuff but I don't need the 4 channel adapter I just need one to connect my subwoofer and amp. Thanks!
    #56
  17. Feb 7, 2021 at 8:14 AM
    #57
    Juice Weasel
    3rd Gen Tacoma SR5
    yeah just use the 2 channel version that only sends out and doesn’t return. There are links to it in other threads just use search. I think it’s just called add an amp harness or 2 channel loc. You only need one channel for a sub although you can run stereo subs for modern music where there is still stereo information below 100hz. Otherwise a single mono channel is fine. the same eBay seller probably has it. Should be cheaper too like 20-30 bucks.
    #57
  18. Feb 7, 2021 at 10:28 AM
    #58
    Presley217
    2020 TRD OR Manual
    I tried looking but if you have any luck and can send me the link that would be amazing. I'm not sure what to do now because if I don't have a harness idk what to do.
    #58
  19. Feb 7, 2021 at 10:34 AM
    #59
    Juice Weasel
    3rd Gen Tacoma SR5
  20. Feb 7, 2021 at 10:40 AM
    #60
    Presley217
    2020 TRD OR Manual
