2021 brand new Tacoma doesn’t start on 1st try
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kicker18, Oct 30, 2021.
  1. Oct 31, 2021 at 7:56 AM
    andersen24
    andersen24 Well-Known Member
    Andy
    Pismo Beach, CA
    2021 Tacoma SR DCSB V6 4X4
    I think I get what the OP is saying. I have a 2021 SR DCSB and does a "similar" thing. It isn't that they won't start on the first try, it's that it takes longer than most cars to start when you turn the ignition. Ironically my diesel F-250 starts faster than my Tacoma as well as does my 2016 Civic. I am so used to not having to hold my tumbler forward that long when I start my Tacoma, I still instinctively release it too early thinking it will have started. The second time I turn the tumbler, it fires right up. Definitely not anything wrong with the truck, just part of a Tacoma. After getting my Tacoma, my next door neighbor got a 2021 SR5 ACLB and asked me if I noticed how much longer the Tacoma's take to start up. He noticed it as well. Again - nothing wrong with the truck, just have to get used to holding the key longer.
  2. Oct 31, 2021 at 8:06 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Get a new battery and see what happens, if the truck still does not start on the first crank. You will still have a new battery. Keep the old battery for when you trade the truck in.
    BOZOJUICE likes this.
  3. Oct 31, 2021 at 8:17 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I actually toyed with the idea of moving to a 4Runner, since the only reason I need the truck is to be able to tow. The 4Runner will tow what I need, so I was poking around online looking at inventory and the value of my truck. The wife walks by while I was doing that, stops and looks at me and says "don't even think about it unless you're ready to sleep in it". That was the end of that.
    RustyGreen likes this.
  4. Oct 31, 2021 at 8:48 AM
    Coffeetime
    Coffeetime Well-Known Member
    I do not know the specifics of the fuel injection system on a Tacoma and it has been a long time since I have been involved with fuel injection systems, but I would expect there to be a check valve that maintains fuel pressure in the system so it does not bleed down. Also when the key is turned to the on position a relay usually triggers a few seconds of fuel pump activation. Additionally it may have a pre-pump at the fuel tank that primes they main fuel pump that would be activated when the key is on for a few seconds.
    As far as holding the key in the start position, I have a habit of not doing that and would not be ready to accept a vehicle that required "How long are you holding the key to the "start" position" if longer time is needed.
    Does anyone know if the Tacoma fuel system maintains fuel pressure overnight when not running. I would be curious what the cold start process is for the engine, I assume it has an increased enrichment and increased idle speed feature.
  5. Oct 31, 2021 at 8:52 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Not all vehicles have a computer system that automatically runs the starter until the vehicle is started. I was always taught to keep the key turned until the engine starts. I've never had a vehicle not start on me that wasn't related to something else.
  6. Oct 31, 2021 at 8:53 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:.
    "...it didn't start on the first try when I turned the key over."
    I assume that you mean the starter motor cranked the engine as expected but the engine did not start and continue to run?
    Question: How long (measured in seconds) are you holding the key in the crank position? Are you holding the key in the crank position until the engine starts or only as long as you think it should take to start?
    Section 4.2 of the owners manual cautions "...do not crank the engine more than 30 seconds at a time..." Implying that up to 30 seconds of continuous cranking would fall under "normal usage" of the starter. Note: If the truck routinely took 30 seconds of continuous cranking to start that would indicate a problem and not fall under normal operation.
    You can't fairly compare a 1997 vehicle to a 2021 and yes, I have had many older vehicles that started with literally "a flick of the key".
    Clearwater Bill and RedWings44 like this.
  7. Oct 31, 2021 at 8:56 AM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    The fuel line indeed holds pressure overnight. The check valve is in the in tank pump/sender, which is the only pump. These pumps DO NOT prime unless the engine is cranking. You will hear nothing if you turn the key to the "on" position.
    MOC221_ likes this.
  8. Oct 31, 2021 at 1:35 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Just hold the key in ACC position for a second or 2 to allow the fuel pump to prime and all the sensors to register with the ECU. God, I would hate be a dealership tech these days.
  9. Oct 31, 2021 at 1:50 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    MOC221_ likes this.
  10. Oct 31, 2021 at 2:22 PM
    Tacoma Mike
    Southern Maine
    Me either
    brian2sun[QUOTED] and RustyGreen like this.
  11. Oct 31, 2021 at 2:23 PM
    RedWings44
    Michigan
    See comment above
  12. Oct 31, 2021 at 2:28 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Maybe
  13. Oct 31, 2021 at 2:34 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Go drive your truck
    Woofer2609, Chew and Tacoma Mike like this.
  14. Oct 31, 2021 at 2:55 PM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    On the other two try just clicking the key forward, like you are tapping a button.
    my guess is those other two have essentially “push to start”, with a key. My guess is both of them will run the starter until they start regardless of how long you “hold” the key. They likely fire up a little faster and also FEEL faster since no matter how short you hold they key they still start running.
  15. Oct 31, 2021 at 4:15 PM
    #35
    brian2sun
    California
    Even if the pump doesn’t have to prime, all the sensors still have to come online. I’d be willing to bet at least one of those sensors has to do with the fuel pump/fuel pressure, so even if it has actual fuel pressure at all times, the sensor that detects fuel pressure may need a second to register with the ECU, as well as all the other sensors in the truck.
  16. Oct 31, 2021 at 4:28 PM
    #36
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    This was clearly a troll post.
    Chew and RedWings44 like this.
  17. Oct 31, 2021 at 4:37 PM
    #37
    RedWings44
    Michigan
    Sounds more like OP isn't holding the key long enough or trolling. OP hasn't been back online since this was posted.
    brian2sun[QUOTED] likes this.
  18. Oct 31, 2021 at 5:26 PM
    #38
    Clearwater Bill
    Billy
    Largo Florida
  19. Oct 31, 2021 at 5:41 PM
    #39
    TDImark
    TDImark Well-Known Member
    Marko
    Mojave Desert of CA
    2020 SR5 4x4 DC
    39 responses and no word from the OP! I wonder if the OP ever took anyone's advice. I must admit, I was not used to holding the key in the "start" position for so long when I first bought the truck.
  20. Oct 31, 2021 at 6:28 PM
    #40
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    OP clearly just needs more practice starting the truck.
    I had a Tercel. Silver, 5 speed, dark tint, gray cloth, and 5 spoke rims. I actually loved it. I have low expectations.
    Chew likes this.
