2021 OR transmission shudder/surging at speed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlueTaco4x4, May 6, 2021.
  1. Aug 14, 2021 at 1:55 PM
    #121
    MarlonB54
    MarlonB54 Well-Known Member
    Fishaholic
    22’ Barcelona Red TRD Off Road
    Has anyone verified their trans fluid levels are to spec themselves who are experiencing these issues? I dont think id trust the dealers to verify this themselves.
  2. Aug 14, 2021 at 2:33 PM
    #122
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Yes. Did the proper fill/check on a level surface with truck at correct temp. Trans was 250ml low. No difference. Truck is always shuddering/bogging and shifting rough. OVtune 2.0 also did nothing to help, even though it was touted as the be all fix all. Apprehensive to try other tunes as it seems to just be another cycle of the same hype. Dealership says it’s all normal. Mind you, This is a 2018, but same engine and trans
  3. Aug 14, 2021 at 3:31 PM
    #123
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    They told my buddy the same for his 2019 trd that its normal for this to happen in some tacoma's when running low rpm under load. Just the nature of how they run if you operate them that way. he was told i'll have no effect on the trucks reliability. Maybe its more noticeable in double cabs, idk.
  4. Aug 14, 2021 at 3:36 PM
    #124
    zoo truck
    None
    I've found running the tire pressure no higher than 30 psi with 265 70 16 goodyears to run a lot smoother, plus i'm getting good tire wear. I never put up with the stock firestones to see where they were.
  5. Aug 14, 2021 at 3:37 PM
    #125
    MarlonB54
    Fishaholic
    some input, kdmaxx helped a ton but i was not a fan of the truck jolting forward on very light throttle
  6. Aug 14, 2021 at 5:57 PM
    #126
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    There are a few different options for throttle sensitivity with that tune
  7. Aug 14, 2021 at 6:21 PM
    #127
    MarlonB54
    Fishaholic
    yes, i was running the lowest throttle settin6. Wife tip in or something like that. Truck was still jolting forward
  8. Dec 11, 2022 at 10:30 PM
    #128
    Andrew.arw
    Andrew.arw Chief Beer Officer
    South Carolina
    2018 Toyota Tacoma TRD OR 3.5 V6
    *** Current Setup - 2/27/24 *** - Wheels // Method 316, 17” - Tires // 275/70/R17 // Falken WildPeak A/T4W - Suspension // 2.5” lift // Eibach’s Pro lift, Stage One - front & rear // Eibach Pro Springs // Icon AAL // TC UCA’s - Lights // Rigid Industries Dual Pod’s [Grille] // Rigid Industries Dual Pod’s [Rear Bumper] // Rigid Industries 40” LED Bar [Roof Rack] // XenonPro Hi/Lo Beam // LASFIT Switchback Fogs - Auxiliary // Switch-Pro controller, SP-9100 Series - Audio // Rockford Fosgate R500X1D Amplifier // Dual Rockford Fosgate P1 10" Subs - Accessories // TRD Pro Grille // Prinsu Roof Rack // Rough Country Soft Tri-Fold Tonneau - Armor // Body Armor Rear Bumper, 4x4 Desert series // TRD Pro Skid Plate - Misc Mods // ECGS Bushing // Cali Raised AC Drip relocate // CMC
    Been experiencing exactly what you are describing. What came of it in your case? (In respects to working with Toyota, and what they “determined”)
    EDIT: Noticed the user has not been on in sometime… so, the world may never know
  9. Dec 12, 2022 at 4:47 AM
    #129
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Maybe you all need to check in with the Ford, Chevy and the Dodge people every one of them seems to have the same exact issue you are having best bet is to blame it on the converter lockup/unlock ease up on the gas the converter unlocks give it some gas it locks up again don't think you'll ever fix it. In the dark ages they did it but it was not real noticeable because they only had 3 or 4 speeds.
    gearcruncher likes this.
  10. Dec 28, 2022 at 12:14 PM
    #130
    airsickbuffa1o
    airsickbuffa1o Well-Known Member
    Anthony
    2017 Silver TRD OR
    OVtuned 1.03
    I'm having the same issues. I'm taking it into the dealership as I don't have the time to diagnose and it's ski season so I'd rather not get stranded with the kids because I ignored the issue. 2017 with 91k on the clock.
    I'll let you know how it goes.
  11. Feb 15, 2023 at 8:51 PM
    #131
    Birder
    Birder Member
    2022 DCSB
    My 2022 SR5 6,000 miles has same shudder stumble convulsive bog at 40mph + on any slight incline up where light throttle is needed.
    My fix is that if i’m around town or road under 65 mph then i put it in 5th and leave it there = no more bog stumble.
    When i was at the dealership getting something else fixed the kid checking in my truck couldn’t make heads or tails of what i was telling him about the bog stumble. After i got the truck back he said that the tech couldn’t get the bog stumble to happen LoL so it happened twice on my way home instead.
  12. Feb 16, 2023 at 1:54 AM
    #132
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    In situations like that it can be helpful to ask the tech to go for a ride with u and demonsrate the problem first hand. They sometimes just drive around the parking lot expecting to find the problem
    petethemeat likes this.
  13. Feb 16, 2023 at 4:23 AM
    #133
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    I had a Silverado doing a similar shuddering in 2015. The dealership checked and said they could not duplicate the problem. I was pissed so I asked the shop foreman to come for a ride. He went through a series of starts and stops, cruising and accelerating, and said to me there was no issue. I asked to go up this particular long hill at 40mph, and there the shudder came on strong. He said "wow we've never saw a problem like this!" to which I said "maybe you should listen to the customer and their explanation of what is happening". They totally rebuilt the transmission including torque converter and $3500.00 worth of parts. Unfortunately the truck started acting up again shortly after, so I traded it in on a 2500hd.
  14. Feb 19, 2023 at 11:11 PM
    #134
    mckgyver
    mckgyver Active Member
    2020 TRD OR silver
    Any updates?
  15. Feb 20, 2023 at 3:29 AM
    #135
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you are asking about the OP:
  16. Feb 21, 2023 at 1:13 PM
    #136
    Birder
    Birder Member
    2022 DCSB
    My fix is still just to ride around town in 5th gear. My top speed is about 60mph and i don’t get the bog shudder on slight inclines like it does when i’m in D gear.
    Out on the interstate where everyone cruises around 75mph i ride in D and the slight inclines don’t make it bog shudder because the rpms are around 2000.
    After reading a lot about it i would guess that the problem has to be the Atkins cycle lower power and transmission gearing/torque converter aren’t seamless, and the computer doesn’t switch to Otto cycle on slight throttle increases because it wants to stay in “high gas mileage” mode.
    skidooboy, DTaco18 and Shades_Of_Red like this.
  17. Feb 23, 2023 at 5:57 AM
    #137
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    Ive had this issue for a while on my 2019. I find it hard to believe its from a bad batch of TC's since its spread across multiple model years. Ive seen anywhere from 2017-2022s with this issue.
    I personally think its engine related. Using higher octane fuel seems to make it less noticable but doesnt eliminate it for whatever reason.
    I had the KDMax tune done a while ago and it did seem to go away for a while but then came back again.
    It is an annoyance and I would like find a way to eliminate it.
    Birder likes this.
  18. Feb 23, 2023 at 7:33 AM
    #138
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    seems like the cure is, below 60 mph, keep the truck in S4, or S5, whatever works for you. and or update the KDmax tune, to the pro 9.0, with lite throttle setting. it has almost totally eliminated my shudder issue. started with the normal throttle on the tune, and it work great for a few days, until the truck "learned" the new tune, and habits... then it came back but, not as bad. after reading a post on the tune forum, I switched to the lite throttle, and I have been on that for months, with almost zero shudder. give it a try. Ski
    Shades_Of_Red[QUOTED] likes this.
  19. Feb 23, 2023 at 10:04 AM
    #139
    Birder
    Birder Member
    2022 DCSB
    I forgot to put mine in 5th on the way to work this morning and the bog shudder in D was so bad i thought it was on the verge of backfiring!!!
  20. Feb 24, 2023 at 6:24 AM
    #140
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    And it looks like u have a 2022?
