2021 rusting?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TOML-Moose, Jan 3, 2022.
  1. Jan 8, 2022 at 4:59 PM
    #81
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Register on the Toyota app and it will tell you everything any dealer has done to your taco. You’re looking for an entry that looks like this.
  2. Jan 8, 2022 at 5:03 PM
    #82
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    Thanks, I suppose I'll sleep a little easier for sure.
    RustyGreen[QUOTED] likes this.
  3. Jan 8, 2022 at 5:09 PM
    #83
    Ferball
    Ferball Well-Known Member
    Brent
    Unity, New Hampshire
    2019 Cement TR5
    Rustoleum makes a rust converter spray on product can't remember what its called, but I keep a can of handy when working on my '99 wrangler. If I spot some frame rust, brush off the dirt and tag it with paint. It only works on rust so it is useless to put on before the rust appears, but it does a great preventing rot.
    usmc2msu likes this.
  4. Jan 9, 2022 at 3:43 AM
    #84
    Scorp
    Scorp Well-Known Member
    Adirondacks
    2022 Magnetic Gray Metallic SR-5 4x4 Double Cab with 6ft box
    I have 350 miles on my truck and I have an appointment to have it krowned on Tues. (Forcasted high of 7f that day....great). I live someplace that salts almost daily.
    My plan is to ride it out this season after I krown it and then wash every nook and cranny this spring, then apply cosmoline. Then have it krowned again in the fall before snow.
    Where are you guys getting the cosmoline? It's on backorder on the site. https://www.cosmolinedirect.com/cos...39b2Z7r-PwW8V6wrRvL6n6Gz6LwpaDdBoCyhkQAvD_BwE
  5. Jan 9, 2022 at 5:18 AM
    #85
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    @skorp yeah, you're not going to find any Cosmoline readily available at this point. CRC is pretty much the same thing as far as i can tell though:
    https://www.amazon.com/CRC-06026-He...t=&hvlocphy=9004242&hvtargid=pla-568707703809
    i ordered 6 cans of Cosmoline back in the summer. in November i started spraying down the undercarriage on my new truck and went a bit heavy. needed another can and a half to get the floor boards but CRC was all i could get on short notice. goes on the same, smells the same, tastes and sticks to your skin just the same (really - wear gloves)... it's the same.
  6. Jan 9, 2022 at 6:43 AM
    #86
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've used the rustoleum rust converter on metal i beams. it works well but you need to scrape any heavy rust scale away before applying it. Once it dries you can paint over it. I've seen the similar done with chassis on trucks, plus a goods coat of cosmoline afterwards.
    Mark77 likes this.
  7. Jan 9, 2022 at 6:47 AM
    #87
    zoo truck
    None
    I've bought cosmoline off ebay when they had a good deal on it, but the shipping could be a factor. Getting it direct from cosmoline generally was the best option.
    #87
  8. Jan 9, 2022 at 6:58 AM
    #88
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Aha, I found this. Was done just before the guy traded it in (before I bought it).
    usmc2msu[QUOTED] likes this.
