2021 Speaker upgrade (Please help)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shortyg83, Sep 3, 2021.
  1. Oct 15, 2021 at 12:42 PM
    #41
    Taco SR5 Newbie
    Taco SR5 Newbie Member
    2013 SR5
    I just went with the Crutchfield setup, the Kicker 47KSS6904 6x9 component with the silk tweeters for the front, Kicker 47KSC6504 for rear, and a small 4ch amp, Soundstream ST4.1000DB to run them. Was going to get a subwoofer but was assured I'd get a ton of bass so will try this. Definitely a good value, under $700 out the door with all the adapters, wires and mounting HW for the tacoma. Only thing I didn't like, I have to manually splice all the speaker wires, no PNP.
  2. Oct 15, 2021 at 12:46 PM
    #42
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    According to @shortyg83 , the 2020 plug changed. He linked an alternate connector in post #34.
    Taco_mike73[QUOTED] likes this.
  3. Oct 15, 2021 at 3:22 PM
    #43
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Ok thanks I ordered that. I'm just trying to wrap my head around how it all wires up with that one harness. It looks like it is made to be cut in half and you splice in the amps input and output between the ends so you don't have to cut factory wires. I'm sure it will make more sense to me when it's all here to see in person.
    Speedfreak[QUOTED] likes this.
  4. Oct 15, 2021 at 5:00 PM
    #44
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    That is correct. That is a nice set up. You only have to order 1 and you get both ends. To do my set up I had to order each end separately.
  5. Oct 15, 2021 at 5:07 PM
    #45
    Taco_mike73
    York, PA
    Sweet thanks.
    Now I just have to figure out where this powered sub that I previously had in my Liberty needs to live.
    It's 14" long x 9" wide and 3 1/4 tall at the highest part. I'd like to do under the a front seat. It however may not fit as it doesn't slip under. Can't be sure with out pulling a seat. Or I was thinking in the area behind the left rear seat if I pull the bin on that side.
    https://www.crutchfield.com/p_777B8PTD/Sound-Ordnance-B-8PTD.html?tp=114
    Going to ask in the audio section and see if I get any good ideas to help me figure it out.
  6. Oct 15, 2021 at 5:12 PM
    #46
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    That I can't help you with, I did a home built fibreglass enclosure and a shallow 10" sub in the right cubby and mounted a small mono sub amp in the left. I found that in almost 4 years of having the truck I didn't use those pockets, so I did that. Right after I do the install, my wife suddenly wants to store her purse back there :annoyed:
    Bastek and Taco_mike73[QUOTED] like this.
  7. Oct 15, 2021 at 5:26 PM
    #47
    Taco_mike73
    York, PA
    I do use the left one to keep a few things like waterless car wash and some towels and wipes to clean up inside if I make a mess inside or get a big bird poo on the paint. Nothing on the right side which is larger so it can move there with room to spare.
    Funny how it works with the ladies sometimes tho.
  8. Oct 15, 2021 at 7:08 PM
    #48
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    I like it, I have not looked at the kicker setup so I’m not sure about the difference in pricing. I spent about $800 for the amp, sub and plug and play wiring. The kicker speakers were $186 from Crutchfield and the Subaru tweeters off Amazon were free with my credit card points. I would definitely do it again because it is well above and beyond the anemic factory speakers. I tuned it with the volume set to 50 and I listen to it mostly on 15. Some pandora stations/songs I turn it up a little. Once in a while I crank it to 25-30 but that is just to see what parts of songs sound like, I couldn’t ever listen to it that loud.
  9. Oct 16, 2021 at 10:12 AM
    #49
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    whatever you all do make sure you put some type of sound deadening in the door cavity.
    i did not and the door panels vibrate when playing EDM!
  10. Oct 18, 2021 at 9:02 AM
    #50
    KoalaTACO
    KoalaTACO Active Member
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    2021 DCSB, non JBL (8") here...
    Please excuse the ignorance, but I haven't installed a "system" since High School...
    If I simply upgrade the front 6x9s and the rear 6.5s with the Kicker CS line, will the factory Head Unit push enough juice to have a noticable difference compared to the OEM trash speakers?
    I've already done the Tweeters and was pleasantly surprised - I'd like to not worry about an amp if I don't have to.
    Thanks!
    Taco_mike73 likes this.
  11. Oct 18, 2021 at 9:04 AM
    #51
    shortyg83
    shortyg83 [OP] Active Member
    It will sound better, but not be any louder than currently.
    KoalaTACO likes this.
  12. Oct 18, 2021 at 9:07 AM
    #52
    Hogbaseball06
    Hogbaseball06 Well-Known Member
    2021 Cement Trail Ed.
    If you don't plan on installing an amp replacing rear door speakers is pointless. Factory HU doesn't push hardly any power to those speakers.
  13. Oct 18, 2021 at 9:08 AM
    #53
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
  14. Oct 18, 2021 at 9:10 AM
    #54
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    Ok, I wasn't sure...and I've noticed when messing around with the Fade control that when I go full rear (TWSS)...it's dismal at best!
    Thanks - looking like I'll stick w/ the front 6x9s for now.
    Cheers!
  15. Oct 18, 2021 at 9:12 AM
    #55
    Hogbaseball06
    KoalaTACO[QUOTED] likes this.
  16. Oct 18, 2021 at 9:28 AM
    #56
    Taco_mike73
    York, PA
    I put the DS series Kickers in mine right after I bought the truck with the tweeters. I wanted the CS series but they were not available at the time. I think it was a good upgrade and the Kickers are better than stock for sure. However here I am a year later not totally satisfied. I am adding the Alpine Power pack and the powered sub I pulled from a prev car. Doing it because while the new speakers are better the factory head unit just does not power them quite enough. that and I planned for the sub since I had it. it was originally with an Alpine head unit that stayed with the old car and probably was more powerful than the stock radio in our trucks is. it should fill in the low end well but not rattle any windows.
  17. Oct 18, 2021 at 9:32 AM
    #57
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    Right on man - yeah, my window rattling days are over, but getting some better sound is a must! I used to cruise the "Circuit" in downtown York back in the late 90s!
  18. Oct 18, 2021 at 9:39 AM
    #58
    Taco_mike73
    York, PA
    Holly crap me too on occasion.... but for me it was the early 90's! always with friends looking for fast women in slow cars! Agree I am too old for those systems too and annoyed by the music people with them tend to play. better sound! yes please
  19. Oct 18, 2021 at 9:42 AM
    #59
    Taco_mike73
    York, PA
    @Speedfreak when you installed the PowerPack did you use the Radio circuit or run a new fused power lead from the battery?
  20. Oct 18, 2021 at 9:45 AM
    #60
    KoalaTACO
    PA
    21' TRD OR DCSB
    Nothin crazy yet...
    Haha! Hell yeah - those were the days. Red Land-er here.
