2021 Speaker upgrade (Please help)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shortyg83, Sep 3, 2021.
  1. Oct 18, 2021 at 9:50 AM
    #61
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Ahh....I Grew up in Dover
  2. Oct 18, 2021 at 10:12 AM
    #62
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I ran it off the power circuit from the headunit. According to the install manual, this will work without issue. In about a year of operating I have had zero issue.
    Taco_mike73[QUOTED] likes this.
  3. Oct 18, 2021 at 10:16 AM
    #63
    Taco_mike73
    York, PA
    Very cool I was thinking of pulling one for it anyway since I need one for my powered sub. It's not much more effort to pull two wires through the firewall at the same time.
    Speedfreak[QUOTED] likes this.
  4. Oct 18, 2021 at 2:06 PM
    #64
    ronopolis
    ronopolis Ronopolis
    Ron
    Ft. Collins, CO
    '22 DCSB TRD Sport
    How much does it push?
  5. Oct 18, 2021 at 3:05 PM
    #65
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    There is a thread here somewhere... a member did a pretty good test and I think the peak numbers were 17 watts. There is also the bass drop out at higher volumes. Even with amps and a sub above 25 it is noticeable.
  6. Oct 19, 2021 at 6:11 AM
    #66
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Taco_mike73 likes this.
  7. Oct 19, 2021 at 6:23 AM
    #67
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    For my laziness sake, any good plug and play front door speakers? I have a 21dcsb with no jbl
  8. Oct 19, 2021 at 6:26 AM
    #68
    Taco_mike73
    York, PA
    Damn then the powerpack amp though small is a HUGE upgrade.
    I have almost all the parts as of yesterday to get mine installed. I still need to work out a mount for the sub I already had. looking at taking out the left rear storage bin and seeing what I can do there.
  9. Oct 19, 2021 at 6:27 AM
    #69
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Any good quality 6x9 speaker will work with the correct harness adapter. I am running Kicker DSC6930's in my doors. I am happy with them.
    edit: corrected model number
    codyjphoto[QUOTED] likes this.
  10. Oct 19, 2021 at 6:29 AM
    #70
    Taco_mike73
    York, PA
    the most popular ones seem to be Kicker CS series 6x9 if in stock. If those aren't in stock the DS series is what I got, a little bit cheaper too. Or the more expensive KS if you are going to add some real power later.
  11. Oct 19, 2021 at 6:30 AM
    #71
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Before the amp install, the volume would be at 20 windows closed, up to 45 with the windows open.
    After the amp, it the volume sits at 5 or 10 and 25 with the windows down. It is quite the improvement.
  12. Oct 30, 2021 at 12:38 PM
    #72
    Taco_mike73
    York, PA
    So another question for anyone that has installed a subwoofer in the area behind the rear seat. About how much speaker wire length am I going to need? This would be from the center dash to the left rear storage area.
    My powered subwoofer will connect to the left and right channels, I'm probably tapping the fronts.
  13. Oct 30, 2021 at 5:09 PM
    #73
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I honestly know how much I used, I made up 2 twisted pairs that were about 24 foot in length. Then I ran them and cut off what I didn't need. I figure it was about 17 foot or so down behind the dash to the right sill, into the back behind the panel and to the amp mounted in the left pocket behind the seat.
  14. Oct 30, 2021 at 8:19 PM
    #74
    davbri59
    davbri59 Member
    David
    2021 Tacoma TRD Sport
    Well this is the 3rd gen I have changed. I did not want to add an amp and I still don't.
    2016 SR5 without JBL changed tweeters to what is on a Subaru WRX, yes they are the same, and then through Crutchfield changed front door 6 x 9 to Kicker and 6x 6 to Kicker. Sound was very crisp and alive with a good base. Maybe too much tweeter
    2021 TRD Sport, without JBL only did not change the tweeters and sounds better. Spent less then $200 and very happy. When you look at the magnets on the OEM and then the Kicker you will understand why it sounds so bad.
  15. Oct 30, 2021 at 8:22 PM
    #75
    Taco_mike73
    York, PA
    That is about what I sort of thought. The amp wire kit I got only came with one 17' roll of wire. Looks like I need more.
    I'm working on getting as much wired together was possible. Using them heat shrink tubes with solder in them. Did the wire harnesses for the anytime front and rear camera and they worked great.
