2021 Sport already starting to rust out? Is this a warranty issue?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BudFriendguy, Dec 19, 2021.
  1. Jan 27, 2022 at 10:41 AM
    #81
    ImBAVID
    ImBAVID Well-Known Member
    David
    Utah
    19 Tacoma Pro
    Dobinsons MMR 3" Suspension BAMF Front Bumper UpTop Bed Rack Desert Armor Tank RTT Baja Designs Lights All Over Cali Raised Rock Sliders
    The bolt on the leaf spring is not backwards. The manufacturer is using a bolt that is too long. Btw, you should check the bolt on the front of the leaf spring as well. That's where the gas tank is.
  2. Jan 27, 2022 at 5:55 PM
    #82
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    The bolt is backwards...Toyota installs them with the nut on the outside.
    INSAYN and Lt. Dangle like this.
  3. Jan 27, 2022 at 6:10 PM
    #83
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I did the same thing when swapping my leafs. Difference is I caught it right away and reversed it.
  4. Jan 27, 2022 at 6:12 PM
    #84
    ImBAVID
    David
    Utah
    19 Tacoma Pro
    I'm having a hard time wrapping my mind around this. How are you able to reverse the bolt with an inch and a half of space?
  5. Jan 27, 2022 at 6:14 PM
    #85
    DTaco18
    Install it first, before the shackle is bolted to the frame.
    Lt. Dangle and BudFriendguy[OP] like this.
  6. Jan 27, 2022 at 6:22 PM
    #86
    ImBAVID
    David
    Utah
    19 Tacoma Pro
    Lol not sure why I wasnt thinking that the diff is dropped...dumb moment
    Lt. Dangle likes this.
  7. Jan 27, 2022 at 7:01 PM
    #87
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I did my lift by myself in my driveway. Swapped out my UCAs with the ICON billet UCAs. Knowing ahead of time that I would be needing to bend the inner fender well outward, I took caution doing so.
    I cut a few fingers off a pair of old welding gloves and slipped them over the channel lock jaws. This worked beautifully. I also added a 3" x 1" x 1/8" strip of aluminum in between the channel lock and the fender to spread the load out. I slipped the aluminum into a chunk of bicycle inner tube to add additional padding.
    This made the entire process of swapping the UCA bolts a breeze with zero damage.
    As for the rear shackle bolt, the bolt head goes on the inside, the nut to the outside. Just a little forethought of taking note of this before removal goes a LONG way.
    I visited that Landcruiser shop back when I was looking for an ARB fridge and ARB awning to look at and take some measurements from.
    While chatting with a few of their mechanics in the shop, I watched them do some wrenching on an old FJ40. Was not impressed with their "finesse" on a customer's rig. One of the mechanics went at a few dry old rusty nuts like they were brand new full send with an air impact. Sheared the bolt right at the nut on one, and rounded the other nut right off so no tool will work. Followed by several minutes of under the breath swearing, and finished with taking a bolt from a parts bin and hammer to pound out the stuck bolts. Clearly these bolts were seized due to many many years of corrosion, but geezus, not even an attempt to do it right.
    A little preheat followed by some good quality penetrating oil, a few mins to let things soak, a bit more heat, a bit more penetrating oils, and then some light tap tap with the impact forward and backward. This would have most likely saved both bolts, or at least made life a lot easier on the "mechanic".
  8. Jan 27, 2022 at 7:58 PM
    #88
    BudFriendguy
    BudFriendguy [OP] TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Goddamn dude, I wish you had worked on my truck.
    INSAYN[QUOTED] likes this.
