2021 tacoma differential gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kyle_, Sep 15, 2021.
  1. Sep 15, 2021 at 8:00 PM
    Kyle_
    Kyle_ [OP] A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Do/ should I change my differential gear fluid on my 2021 tacoma trd off road 4x4? I am almost at the 1000 mile mark.
    i looked on the forums but cannot find any answers.
    thanks all!
    josh2015 likes this.
  2. Sep 15, 2021 at 8:45 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    What does the maintenance section of your manual recommend?
    Seem way too early to me.
    Skydvrr, Chew and davidstacoma like this.
  3. Sep 15, 2021 at 8:49 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    You should change it every 500 miles.
    Skydvrr and philth like this.
  4. Sep 15, 2021 at 10:21 PM
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    davidstacoma likes this.
  5. Sep 15, 2021 at 10:27 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    lol nope.
    Chew likes this.
  6. Sep 15, 2021 at 10:29 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The factory gears are forged rather than cut/machined, so don’t have the same initial break-in as aftermarket gears, where you gotta change the diff oil after 500 miles. No need to change factory fluid fill with factory gears so soon in the trucks life. Just follow what’s in the manual.
  7. Oct 6, 2021 at 9:05 AM
    josh2015
    josh2015 Well-Known Member
    Josh
    2021 Tacoma MGM TRD OR 6MT
    I just hit 1,000 miles in my 2021, it is a TRD Off-Road 6MT. I am going to be doing a road trip soon and I did a lot of hills, dirt roads, and used four-wheel drive during the break in, so I thought I'd go ahead and change all the fluids. I did this on my 2016 at about 5,000 miles. It was a mess and took way longer than anticipated, but I am really glad I did this, my notes are: engine oil had a fair amount of metal shavings and light brown tint; front differential fluid was clearly contaminated with a milky brown color and strong odor, substantial metal shavings on drain plug and in fluid; rear differential fluid was slightly contaminated with dark brown milky color, substantial metal shavings on plug and in fluid; transfer case fluid had medium brown tint and noticeable metal shavings; manual transmission fluid had a light brown tint and noticeable metal shavings. I am quite concerned about the way the front and rear differential fluid looked and how it was contaminated after only 1,000 miles. In comparison, my 2016 had no contamination but similar condition to the above. I replaced with the following: Pennzoil Ultra Platinum Full Synthetic 0W-20 and WIX 57047XP; Redline 75W85 GL-5 Gear Oil; Redline MT-LV GL-4 Gear Oil; Redline MT-90 75W90 GL-4 Manual Transmission and Transaxle Lubricant. Checkout this thread: https://www.tacomaworld.com/threads...6mt-fluid-change.481719/page-28#post-26334726
