2021 Tacoma Extensive Frame Rust All around on Welding Spots
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFranz, Aug 24, 2023.
  1. Aug 25, 2023 at 5:32 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    What do you want brand engagement to do? You have a rust perforation warranty on the truck...and it isn't perforated so there is nothing they can do. If you are severely concerned about it, take a wire wheel and clean up the welds. Spray some rustoleum black paint on it and then coat it with the metal protector of your choice. In a weekends time, you will have a beautiful frame and will be protected from your "frame rusting out from under you"
  2. Aug 25, 2023 at 5:36 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    that’s normal. The car wash is also only use recycle water to rinse the underside. They do nothing to break the bond between the road salts and the metal.
    The fix for this is to remove the rust, wire wheels work well. The bare area will need to be treated and painted. Then a corrosion barrier like wool wax or fluid film to protect the surface. You use wax on the surface of your paint to protect. It only makes sense to put wax on the surface of the frame to protect it.
  3. Aug 25, 2023 at 5:42 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Extensive rust? That looks pretty darn clean to me! If one wants to keep a frame looking 100% new they better never drive it...
    Kolohe07 and stealthmode like this.
  4. Aug 25, 2023 at 5:49 AM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    No way. I’ve never owned any other vehicle that I had to worry about rust and never did anything to them other than washing them occasionally. Now I own a Tacoma and a 4Runner and both have rusty frames. Also the biggest issues are the areas you can’t easily treat or see. It’s the areas where the frame is sandwiched together and where it is boxed in near the front.
  5. Aug 25, 2023 at 5:58 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's not hard. Take care of yourself and your property instead of depending others to do it. If that means fluid film then so be it.
    Kwikvette, jsinnard and TacoFranz[OP] like this.
  6. Aug 25, 2023 at 6:04 AM
    Turd Ferguson
    Taxachusetts
    FYI, Toyota wouldn’t have this extensive campaign to spray their goop on the frame and then eventually replace them if it wasn’t THEIR problem.
  7. Aug 25, 2023 at 6:47 AM
    TacoFranz
    TacoFranz [OP] Well-Known Member
    Thomas
    4x4 Tacoma SR5 Double Cab
    that's my impression here too, namely they don't know how to too. Not enough rust in Japan I guess. The frames come from the Japan factory. This particular one was shipped some time in 2020 - well maybe that has something to do with that. anyway, while some people here say "it's nothing - don't worry," heck, this is not normal. I have never seen a 2 1/2 year old truck with that kind of a rust on the frame. We will see. before I will do anything to it, I will end up taking it my closest local Toyo dealer - service center after Corp Brand Engagement had a chance to refer me there. You know, I hate to pay the dealership just so they can tell me the repair is not covered under warranty and I could use the $85 bucks, or should have used that $85 for my rust inhibiting solvents instead.
  8. Aug 25, 2023 at 6:53 AM
    TacoFranz
    Thomas
    Yes I get it, of course, I am firm believer of self-reliance - and will act upon it. But I am also a firm believer in STANDING UP FOR WHAT'S RIGHT AND AGAINST WHAT'S WRONG, and give Toyota the opportunity to do that for which I paid for. I keep hearing / reading here "take care of yourself", or "take responsibility"... of course, we do that, I am not asking for encouragement and reprimand, I am asking for advice. This is really not the same thing here what our younger generations do nowadays, namely 'nothing but expecting entitlement'. They act entitled from nothing, just from a birthright, they are born, alive, and expect being handed a car, room and board, and a bunch of candy and don't even fix their bed for it. I am talking about I paid good money for my truck and it comes with warranty and that contract entitles me. Thanks for your advice to take care of myself.
  9. Aug 25, 2023 at 6:55 AM
    EL DUDE
    EL DUDE Well-Known Member
    I think it’s fair. You should be aware that maintenance starts at home. a responsible owner will do the stuff on their own or pay for it to be done, a negligent owner will avoid doing anything at all.
    If a person buys a Tacoma and somehow doesn’t know their more sordid history of rust issues compared to other trucks on the market, then they didn’t do their due diligence in researching.
    The frame isn’t beyond keeping in good health, I’m glad op posted. it will let him know solutions to it before the problems are too big.
  10. Aug 25, 2023 at 6:56 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Dealer with laugh at you and refer you to the local Krown rustproofing service.
    You sound like an entitled baby. Why are you wasting your time and energy on something that A) you knew already about...Tacos prone to frame rust and B) There is a solution for....undercoating.
    Why are you stil ranting on about god knows what? Nobody owes you anything, Toyota doesn't owe you anything and the world doesn't owe you anything.
    Can be lock this retarded thread?
    jsinnard, TX BAJA1, Delta09 and 2 others like this.
  11. Aug 25, 2023 at 6:57 AM
    TacoFranz
    Thomas
    I read about the "TACOMA RUST" years, Toyota's repair events, replacements, and compensations (buy-backs). But I thought they must have learned from that and therefore there is nothing to worry about. The Toyota warranty covers rust for 6 years regardless of miles. We just have to make sure it's done, and done right. I am not that worried, but want to make sure I will have my TACO for 17 more years, plus. Good luck and congrats to your new Tacoma.
    Bocephous[QUOTED] likes this.
  12. Aug 25, 2023 at 6:58 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd wire wheel the rust away best as possible , hit it some rustoleum rust converter, then cover it with a good black chassis paint. After all that, time for a rust inhibitor of choice.
    Kwikvette and TacoFranz[OP] like this.
  13. Aug 25, 2023 at 7:04 AM
    zoo truck
    None
    When I bought my gen 3, I asked the dealer if toyota has gotten their past rust issues resolved. The sales manager just came out, and said....toyota has done their share, but it's still up to you to take care of the truck when it comes to long term rust.
  14. Aug 25, 2023 at 7:06 AM
    TacoFranz
    Thomas
    thank you for defending the "principle matter" here. I am going like "come on guys, why the heck do they attack me with 'take care yourself... bla bla bla'? Fair is not the issue here. Like you said, what are the options, ideas, any suggestions, and then move on, get something done. I am working on it. And Toyota Corp is hearing the brunt - sent an email with pictures already, and that before I head to the always-miserable-dealership service departments, you know, all of them are just miserable cheap bastards who can't or won't answer any questions unless you pay them $85 bucks. "Let's take a look at that, $85 bucks please". The last time I went was with break problems and an AC leak. I had to fix it myself and did, because I refuse to pay $85 bucks just to find out if it is covered under warranty. They decline it anyway, but not without my fight.
  15. Aug 25, 2023 at 7:09 AM
    #35
    TacoFranz
    Thomas
    Total true, of course. Still, it's supposedly under warranty. And that is my number 1 way forward, and if not that, I want to know from Toyota what to do, and in the meantime, I am turning to my awesome community, and there are awesome suggestions already flying my way. I just need to find a way to get the car up on lift somewhere - you know, the old 'back' on the hard floor.
  16. Aug 25, 2023 at 7:09 AM
    #36
    zoo truck
    None
    The tacoma frames do not come from Japan. They're made here in the u.s. by dana out of recycled steel, and whatever else thrown in.
    Canadian Caber likes this.
  17. Aug 25, 2023 at 7:12 AM
    #37
    TacoFranz
    Thomas
    Bless you! Thank you!
  18. Aug 25, 2023 at 7:12 AM
    #38
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    *laughs in rust belt*
    But in all seriousness, it appears to be surface rust. Yes it is somewhat normal. You can knock it down with a wire brush and come in behind with some rust reformer spray paint. Then consider some undercoating. I recommend lanolin based such as Fluid Film or Woolwax. Avoid any sort of rubberized undercoating though.
    TX BAJA1 and zoo truck like this.
  19. Aug 25, 2023 at 7:13 AM
    #39
    Turd Ferguson
    Taxachusetts
    It’s a cost saving measure. They could coat these frames better if they wanted to. Notice no one’s body panels are rusting. When you bring your truck in Toyota will add some plastic plugs to your frame and fill it with some goop and extend your frame warranty out to 12 years. Then have them inspect it every few years. I suspect that what they are spraying in the frame is just a band aid to get the frame beyond the 12 year mark and them off the hook.
    zoo truck likes this.
  20. Aug 25, 2023 at 7:14 AM
    #40
    zoo truck
    None
    I learned long ago not to rely on toyota for their rust issues. They must be so bad, the vehicle becomes unsafe to operate on our roads. I've dealt with surface rust issues, and how to prevent them getting worse....what I mentioned above has worked very well
    TacoFranz[QUOTED][OP] likes this.
