2021 Tacoma Sport warped brake rotors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by davbri59, Aug 3, 2023.
  1. Aug 3, 2023 at 6:35 PM
    davbri59
    davbri59 [OP] Member
    David
    2021 Tacoma TRD Sport
    Ok some background. Truck bought new and rotors and brakes worked well. At 55,000 mile changed the pad and replaced the rotors with Ray-asbestos rotors. I normally would have the rotors turned but chose to replace them and new pads. 3,000 mile later the new rotors warped. I sent them back, then had my factory rotors turned and re-installed. Now 4,000 miles later it is just like it was, warped again. I do not brake hard, ride the brakes, however I do use the Dynamic Cruise Control and it loves to brake very often with highway traffic.
    So here are my questions:
    Can new pads that maybe are cheap damage new or turned Toyota oem rotors?
    Is the cruise control that will pace the vehicle in front actually overheat the rotors?
    Until I figure this out I have bought a matching set of RC Concepts drilled and slotted rotors and matching pair of ceramic pads. I am hoping buying these will reduce heat and as a set stop the warping.
    Any thoughts?
  2. Aug 3, 2023 at 6:41 PM
    Bishop84
    Bishop84 Well-Known Member
    So what causes pulsation is runout, this can be called warp, but often is just a variance of thickness in the rotor.
    Often it's caused by low grade pads imbedding into the rotor after a hot drive, or sitting and rusting.
    Or it's heat spots, cracking or material issues with the rotors. Cheaper the rotor, the more likely it gets variation issues. They also tend to rust faster.
    Machining rotors with thickness variation usually is a bandaid that doesn't last. The core issue is deep and only the surface is corrected.
    I think heat isnt the issue, its product quality this time.
  3. Aug 3, 2023 at 6:51 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I don’t have any specific help other than to say that I have been driving since the 1980’s and have never replaced a brake rotor. I think you might be unlucky or more sensitive to vibrations/sounds. Out of curiosity, did you get the rotors mic’ed/inspected to be sure they were “warped”?
  4. Aug 3, 2023 at 6:55 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    If the rotor mounting surface is beginning to rust that can effect things, I clean it very well and use anti-sieze. Over or under torque on lugs can contribute.
    Have you ever heard of a on car brake lathe?
    It is a driver adapter bolted in place of the wheel, and spins the rotors in place on the truck. It cuts them to true to the plane of rotation.
    Since we have fixed calipers any runout, or variation in thickness, or uneven pad transfer layer to the rotors is felt much more.
    I hope this helps.
  5. Aug 3, 2023 at 7:01 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a vibration with my OEM brakes so I put PowerStop on. I have 15k miles on them and very happy. I hope your RC Concepts fixes your issue.
    https://www.amazon.com/dp/B005FKS28C?ie=UTF8
    ernscott likes this.
  6. Aug 3, 2023 at 7:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I doubt the dynamic cruise is causing heating issues, since you are at speed. That said, if you adjust the sensitivity down, change lanes before it brakes, and don't use it in heavy traffic,,,, your experience with it will be a lot more enjoyable.
    Did you reuse the newish pads?
  7. Aug 3, 2023 at 7:07 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Seems like you might have a mechanical problem... I've used Raybestos rotors and pads a bunch of times and never had that short of life. Same with turned rotors...
    Jack truck up.
    Start it up and press brake hard.
    Get out and spin wheel.
    If it's not free to spin, then you have a caliper piston that is seizing up. That's my bet.
    MastaZ9, ndoldman59 and Uparmorjoe like this.
  8. Aug 4, 2023 at 10:35 PM
    terryjm1
    terryjm1 Well-Known Member
    Terry
    2023 Tacoma
    I never turn rotors. If they are already warped they are probably beyond tolerance. Newer vehicles have next to no allowance. It does sound like to me there is something not right, like a caliper dragging a bit. Rotors going bad that fast is really odd. Also, Raybestos has different quality rotors. I have been told it’s about the quality of the steel. The “better” ones are not much more expensive.
  9. Feb 23, 2024 at 3:52 PM
    manfred twd
    manfred twd Active Member
    mike
    2021 trd takoma
    Mine also have the same problem, replaced pads with oem toyota pads at 60,000. Always torqued the lug nuts at 83 ft pounds
    I noticed the warped rotors at about 65,000
  10. Feb 23, 2024 at 4:21 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Another vote for the PowerStop kit. After a normal drive - get out and feel the lug nuts on each wheel. If one is much hotter than others - there is the problem wheel.
  11. Feb 23, 2024 at 4:22 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    are rear brakes functioning properly?
