2021 Tacoma Stalls
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jjs862, Feb 13, 2021.
  1. Feb 13, 2021 at 7:09 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Ok, I’m gonna say it...
    should have got a manual! :laughing:
    KBOX, Dirk Diggler and shakerhood like this.
  2. Feb 13, 2021 at 7:19 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Mine does. If it rolls back the brakes apply automatically.
    shakerhood and 2016Tacoman like this.
  3. Feb 13, 2021 at 7:28 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The engine should not be shutting off. The automatic transmission knows when the truck is moving backwards and engages the ABS system to keep it from moving.
    Ask to bring the lead mechanic with you and video the situation in the same spot.
    Chew likes this.
  4. Feb 13, 2021 at 7:29 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    2016 automatic, same here.
    Junkhead and shakerhood like this.
  5. Feb 13, 2021 at 7:30 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Off Road and Pro Manuals do not have it, the Automatics do.
    Chew, eurowner[QUOTED] and Junkhead like this.
  6. Feb 13, 2021 at 7:35 PM
    eurowner
    eurowner Duke Sky
    Scoty
    But, does your engine shut off?
  7. Feb 13, 2021 at 7:36 PM
    slowtacotruck
    17 offroad
    stuff
    Nope
  8. Feb 13, 2021 at 7:37 PM
    eurowner
    eurowner Duke Sky
    Scoty
    If that is what Toyota calls the ABS holding the truck from rolling backwards, I need to reread the owners manual. :hattip: I have a TRDOR automatic.
    shakerhood[QUOTED] likes this.
  9. Feb 13, 2021 at 7:39 PM
    shakerhood
    Southern Ohio
    Yeah that's it, Manual Sports also have HSA.
    Junkhead likes this.
  10. Feb 13, 2021 at 7:40 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Is that the same as the clutch override switch in the older Gens?
  11. Feb 13, 2021 at 7:42 PM
    shakerhood
    Southern Ohio
    No, the HSA on the Sport just holds the brakes for a few seconds so the truck doesnt roll backwards. The Clutch Start Cancel switch lets you start the truck in gear to get you moving out of a tough situation.
    Junkhead and eurowner[QUOTED] like this.
  12. Feb 13, 2021 at 7:55 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    You have two ways to prevent this. Use the brake pedal or hand brake.
    I don’t think the engine should stall, but you have other methods to control backward movement. Skills you must learn if using a manual in hilly conditions.
  13. Feb 13, 2021 at 9:09 PM
    Jjs862
    Jjs862 [OP] Member
    Jim
    2021 Tacoma
    Thanks for your input, I'll be heading back to the dealer.
    The hammer and shakerhood like this.
  14. Feb 14, 2021 at 8:18 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    The HSA works beautifully on hills. Not that I need it, but it does save the clutch a bit, neat feature.
  15. Feb 14, 2021 at 8:51 AM
    #35
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    fuel pump?!
