2021 Tacoma TRD Sport Vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jpdlc, Nov 3, 2021.
  1. Apr 29, 2025 at 2:55 PM
    #41
    rdjohnsons
    rdjohnsons Active Member
    Robert
    2021 Army Green Tacoma TRD Sport
    Retrax Pro Tonneau Cover, Front End Wrapped
    yes. From day 1. Talked to service department today and now, they have opted against adjusting the angle of drive shaft and going to get a new driveshaft instead. Problem is, it is a back order item now and they aren’t sure when it will be available. Starting to sound to me like they are just kicking the can on down the road a piece. Starting to piss me off now…
  2. Apr 29, 2025 at 3:10 PM
    #42
    jericho777
    jericho777 Well-Known Member
    2023 TRD Off Road
    They could send it to a shop and they may be able to fix it. Probably needs to be rebalanced.
  3. Apr 30, 2025 at 4:31 AM
    #43
    rdjohnsons
    Robert
    Possibly. I have the truck back now until they can get a drive shaft. I'll update once they can find and replace.
    jericho777[QUOTED] likes this.
  4. Apr 30, 2025 at 2:29 PM
    #44
    Sabbathu
    Sabbathu Well-Known Member
    SoCal
    2019 Toyota Tacoma TRD Sport 4x4
    Dealership (SoCal) recently replaced my drive shaft assembly. They said it was back ordered 3-4 weeks, but it arrived within a week. Hope yours arrives quick!
  5. May 1, 2025 at 3:48 AM
    #45
    rdjohnsons
    Robert
    Why did you need yours replaced? Vibration too? Do you have an extended bed?
  6. May 1, 2025 at 4:37 AM
    #46
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I agree
    I bought 4 brand new Michelin LTX and left the tire shop to feel a vibration in my truck around 40 mph and then it would smooth at about 50 so took them back and they road tested and came to a conclusion that they would re-balance the tires.They gave me the truck back and sure enough again started to vibrate at the same speed. Took it back and they said that they would order new tires as these where some kind of defects on the belts or whatever.
    The new tires came in about 3 days later and bingo the truck drove like it should no vibrations nothing. So I do believe that new tires could have flaws too.
    Vmax540 and TacoTime55 like this.
  7. May 1, 2025 at 6:28 AM
    #47
    Sabbathu
    SoCal
    5’ bed.
    I have a rotational humming noise going on at low speeds. The dealership took a guess that it was the center bearing and replaced the whole rear assembly. That wasn’t it. I’m still chasing the cause of the hum.
  8. May 1, 2025 at 7:21 AM
    #48
    Sungod
    Sungod Well-Known Member
    St Augustine
    You all really need to be specific on the location, type, frequency of these vibrations. There are multiple sources of vibrations and you need to be as specific as possible to narrow it down. Saying that a vibration occurs at 40mph doesn't give enough information. What will cause your steering wheel to rock back and forth won't be the same cause as you feeling it in your seat. Not to mention the rocking in the steering wheel wouldn't have the same cause as it feeling like the vibration of someone hitting the steering wheel with a hammer. Basically, anything in your driveline that rotates can cause problems.
  9. May 21, 2025 at 4:42 AM
    #49
    rdjohnsons
    Robert
    Figured I would post again to say that, after 70,000 miles and 3 years of driving this truck and multiple visits to the service department at the dealership where I purchased the truck, I finally have zero vibration and it is as smooth as silk. They replaced my drive shaft and found that a u joint was 'siezing'. I have asked the service department every time I have gone in if this could be a problem with a u joint. Looks like they probably only had to replace a u joint and not the entire drive shaft, but they replaced it all and I have no problem now. Finally....
  10. May 22, 2025 at 5:00 AM
    #50
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Interesting, since this is from new, sounds like I need to drop my trucks driveshaft and work the u-joints. Non greaseable but, maybe the caps can be removed and a little grease added ?
  11. May 22, 2025 at 6:20 AM
    #51
    rdjohnsons
    Robert
    I have been complaining about this since I drove the truck off the lot. It finally took a service department advisor to practically 'write a book' about all they have done to try to fix this issue before they could justify to Toyota to replace the drive shaft. Funny thing is, after reading this string and talking to other mechanics I know, I suggested to the service department to look at the u joints and the driveshaft. Toyota originally said that the vibration was part of driving a truck which really pissed me off. So every time I went in, I had them put it on the service record so I would have a long record of the issue for down the road. Before I hit 25,000 miles on the truck, I even decided to purchase the extended warranty thinking that this was a cumulative issue that was going to lead to bigger problems down the road. Turns out that the owners here in this post and my mechanics were right on point with this issue. Yes - I would have your driveshaft and u joints checked out for sure!! Good luck with your issue and I hope you get it resolved. Took me 3 years of complaining!!!
    I'll have to strongly consider if I ever purchase another Toyota after this miserable journey with the company... Never had this problem with another automobile company in my 50 years of driving... Though I am happy with the truck now that it has a smooth ride finally...
    Canadian Caber likes this.
