2021 Tacoma VS Ford Bronco - Thoughts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by montypower, Dec 11, 2021.
  1. Dec 14, 2021 at 6:07 PM
    #121
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    I just wish they would have left the fenders plain with no lights. I loved my rubi with plain fenders.
  2. Dec 14, 2021 at 6:17 PM
    #122
    fresyota
    fresyota Well-Known Member
    2013 Tacoma Base Access Cab 4x4 2.7 A/T
    I could only afford a rag top sport at the time, but it took me everywhere I wanted to go just by slapping on 32's
    RatDaddy likes this.
  3. Dec 14, 2021 at 6:19 PM
    #123
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Garbage
  4. Dec 14, 2021 at 6:20 PM
    #124
    shotgunbilly420
    Taco sauce only please
  5. Dec 14, 2021 at 7:09 PM
    #125
    bzzr2
    bzzr2 Well-Known Member
    that old 4runner powertrain is still just as good as the new bronco’s fancy powertrains on fuel in stock form! A lot less to go wrong and doesn’t look like a drunk monkey assembled things under the hood!!
  6. Dec 14, 2021 at 7:14 PM
    #126
    MGMDesertTaco
  7. Dec 14, 2021 at 7:53 PM
    #127
    VLTHNTR77
    VLTHNTR77 Well-Known Member
    Andrew
    Everett, WA.
    2016 Inferno TRD off-road
    RCI skid and sliders, GoodYear Ultraterrains, HID's, SCS SR8s, lots of ME-SO goodies, Diamondback HD.
    I've seen the same type of outfits building restomod Scouts too. They put Scout bodies onto Wrangler frames and install LS V8's in them.
    Then they charge over 100k.
    The one I'm thinking of is newlegend4x4.com
    MGMDesertTaco[QUOTED] likes this.
  8. Dec 14, 2021 at 9:43 PM
    #128
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Broncos look tiny and weak.
  9. Dec 14, 2021 at 10:46 PM
    #129
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Roughly the same size as a Toyota 4-Runner.
  10. Dec 15, 2021 at 5:45 AM
    #130
    RatDaddy
    Roy
    None
    Yet the 4runner has considerably more cargo space. The hood/front on the Bronco must be longer than the 4runner
    shakerhood[QUOTED] likes this.
  11. Dec 15, 2021 at 6:13 AM
    #131
    bzzr2
    Welllll….. at least there is a version of the Bronco that doesn't look like it skipped leg day for the past decade!
  12. Dec 15, 2021 at 8:37 AM
    #132
    montypower
    montypower [OP] Well-Known Member
    Peter
    Scottsdale, AZ
    This video certainly doesn't apply to those of you abscessed with "appearance" or "looks". Surface deep stuff. I'm digging into the actual components and hardware these trucks have. Get educated. Then you'll know what truly makes the Tacoma or 4runner "best" rather than just saying so.
    The Jeep JL platform is not the best rock crawler. The "Step Child" has well over $100k in modifications at this point. Really it's a Jeep body and interior... nothing else.
    JL is fine for light duty trail use but realistically needs similar modifications as any other truck. For instance: limited factory gearing options (4.56 best factory ratio), aluminum steering knuckles, FAD (weak spot on axle and failure item), weak steering setup, electric PS pump, weak suspension link mounts on frame/axle and on it goes...
    Realistically, if you want a JL to handle 37s reliably you'd want... front axle housing, suspension links and mounts, regear, hydro assist (which is $3,500 for belt driven pump, box, lines, ram), suspension, armor, etc. Easy $20k+ doing much of the work yourself. And you'd still be stuck with 5 lug wheels. Next level is getting to 8 lug - HD axle set which is $20k.
    You can play in the entry 4x4 world but to not break with big tires it requires modifications. Street use is another story (do whatever you want). But I'm talking about a rig capable of the Fordyce Trail.
    I think the Bronco is interesting because... with the factory 4.77 gears, lockers, axles.. 37s are rather attainable at a cost effective level with durability. Much cheaper than Jeep! For instance, you can buy a 2DR Sasquatch Bronco for $38k. Retain the fairly legit factory coilovers, install 2" CO spacer, 37s will mount on factory wheels, minor trimming, RCV axles (warranty to 40" tires), soon to be released Ford Performance HD steering rack, skids, bumpers, winch. Less than $10k build. All in built for mid $40k range! And that would be a reliable setup. You can't even buy a stock Rubicon or TRD Pro for that money.
    It's hard to argue with the value of the Bronco and good capability for the money. Plus the roof and doors come off! And Turbo Manual transmission! Yes please.
    AZ_Tumbleweed and Thunder Fist like this.
  13. Dec 15, 2021 at 8:47 AM
    #133
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    Great analysis! Unfortunately it's still a FORD. (I have 2 Fords in the driveway, so I'm not Biased, just realistic). :thumbsup: :cheers:
  14. Dec 15, 2021 at 8:50 AM
    #134
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    what is that supposed to mean its still a ford?
    Junkhead likes this.
  15. Dec 15, 2021 at 8:53 AM
    #135
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    My 2007 ranger was the most reliable vehicle Ive had so far. 7 years and 165k miles.
    I’m sure my taco will be just as reliable but I only had it for 3.5 years and 30k miles, time will tell.
    shakerhood likes this.
  16. Dec 15, 2021 at 8:54 AM
    #136
    bzzr2
    LOL. Biased much?
  17. Dec 15, 2021 at 8:55 AM
    #137
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    Yes, this does appear to be a tough crowd, but you should find value in the responses. You can't force people to watch your video or like your content. It isn't actually free; the currency is people's time. If people are interested, they'll spend their time watching, and you'll get paid. In this case, there's not much interest, so if you want to attract the Tacoma crowd, you'll need to adjust your future content. All good!
    oconnor and Junkhead like this.
  18. Dec 15, 2021 at 8:55 AM
    #138
    ryanvar42
    None
    Exactly, I had a ford and it was a piece of shit but doesn't mean they all are. My dads last three trucks were ford and are all fine
    shakerhood and Junkhead[QUOTED] like this.
  19. Dec 15, 2021 at 8:57 AM
    #139
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yep. I’ve got numerous friends with fords and they are pretty happy with them.
    The older fords seem to be better from my experience.
  20. Dec 15, 2021 at 8:57 AM
    #140
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I have both in the driveway (2 door Bronco and DCSB Taco.) They're different vehicles with different missions.
    I'd say the Bronco is a full second (or more) quicker to 60 mph. Passing speeds are better too but don't have a way to measure. The Bronco IS a fun little tank as it's like a jacked up go-cart.. the 2 door's turning radius is on a dime but it is a SMALL suv. Perhaps people can compare the 4 door bronco to the 4runner but not the 2 door. One design decision that stinks is having to shut the rear glass BEFORE you can close the rear door. For those of you with truck shells.. think of having to open the tailgate just to pop open the rear glass (or having to close the rear glass before shutting the F'n tailgate. )
    Also at interstate speeds the Bronco has more interior road noise (which makes sense because the top/panels are removable.) This is saying something tho because when I first bought the Tacoma I thought IT was noisy inside (as I had been spoiled by the insulated silence of a Tahoe.)
    bzzr2 and Junkhead like this.
