2021 Treat Your Tacoma to Ethanol Free Gasoline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Burica, Jan 1, 2021.
  1. Jan 5, 2021 at 10:43 PM
    #61
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    A de-icer in your fuel tank? I guess if you like absorbing water in your fuel.
    Just as any county (or city) that has a population density rating of assholes-to-elbows is prohibited by law from selling pure gas (ethanol free).
    Burica[OP] likes this.
  2. Jan 6, 2021 at 6:35 AM
    #62
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Once upon a time ago.....fuel deicer was commonly sold. The product was HEET. IIRC, it was ethanol or some variant of alcohol.
  3. Jan 6, 2021 at 6:55 AM
    #63
    alexwlwsn
    alexwlwsn Active Member
    Alex
    Havre de Grace, MD
    2014 Tacoma SR5 4x4 DCSB
    Agreed, there's definitely some confusion surrounding the topic. I ran an E48 blend in my MazdaSpeed3 (along with many more things under the hood) and made right around 600 to the wheels. Ethanol might contain less energy than gasoline but it has a lot more fun properties as well - so long as your tune/fuel system can handle it!
  4. Jan 6, 2021 at 7:04 AM
    #64
    Shippe
    Shippe Well-Known Member
    Isaiah
    Idaho
    2020 MGM Tacoma TRD Off-Road / 2014 BW Corolla S
    So whats the conclusion? Run ethanol-free or just premium? There’s a lot of back and forth about it.
  5. Jan 6, 2021 at 7:06 AM
    #65
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Neither you nor your truck will notice a difference between ethanol free, premium or regular. Just do whatever makes you happy.
    Shippe[QUOTED] and alexwlwsn like this.
  6. Jan 6, 2021 at 7:06 AM
    #66
    alexwlwsn
    Alex
    Havre de Grace, MD
    If your manual recommends 87 octane, run just that in whatever configuration you enjoy. Ethanol in fuel can absorb water (very slowly at 10%) so if your truck is going to sit for like 6mos or more, it might be beneficial but at the end of the day, running higher octane than the vehicle is designed/tuned for is a waste of money.
  7. Jan 6, 2021 at 7:13 AM
    #67
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Right on. Ive been running E0 ever since the dealers fill was used.
  8. Jan 6, 2021 at 7:17 AM
    #68
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Manual states : "select octane rating 87 or higher".
  9. Jan 6, 2021 at 7:45 AM
    #69
    Knute
    Does anyone understand what the Octane rating means?
    or
    Does anyone know what Octane does?
    Octane is a rating to resist pre-detonation (pinging) in the cylinders. This is the purpose and what Octane does.
    A higher rating indicates greater resistance to pinging.
    Common mythconceptions surround Octane ratings
    Higher Octane DOES NOT provide more POWER.
    Yes, higher octane is often used in vehicles with high compression ratios, typically found in "Sport or High Performance" cars. These cars have engines designed with higher compression ratios that are prone to pinging. These trucks are not anywhere close to having a high performance engine. Although, many users will swear they have more power based on their butt dynamometer readings.
    Higher octane fuel is not "better", although it is more expensive. It is formulated to resist pre-detonation in high compression engines.
    If you are burning High Octane, then you are likely increasing your fuel costs without benefit.
    In years past, cars ran on simple ignition systems and carburetors. Pinging was a normal situation, so higher octane was needed. Pinging can destroy an engine in short order.
    Today's vehicles use a complex, intelligent ignition system with fuel injection. This system is able to detect and adjust timing and fuel mix to avoid pre-detonation.
    skanetic and alexwlwsn like this.
  10. Jan 6, 2021 at 7:55 AM
    #70
    willconltd
    willconltd Well-Known Member
    Orlando, Florida
    What? Fuel doesn't freeze until somewhere south of -40 degrees C or F. If you live in a place that cold then Ethanol isn't going to save you. Otherwise, are you spraying it on your windshield to de-ice it? I can't make any sense of your statement.
  11. Jan 6, 2021 at 7:56 AM
    #71
    willconltd
    Orlando, Florida
    Nonsense. Ardbeg or go home.
  12. Jan 6, 2021 at 8:14 AM
    #72
    alexwlwsn
    Alex
    Havre de Grace, MD
    You can always run higher and not hurt anything, it's the lower that'll affect the engine. If you detect a lot of engine knock get a higher octane. If not, run the minimum recommended.
    Junkhead[QUOTED] and Knute like this.
  13. Jan 6, 2021 at 9:17 AM
    #73
    willconltd
    Orlando, Florida
    This isn't entirely true. If your ECU can advance the timing, then yes you can get improved mileage and power out of the engine, but if the engine is not tuned to take advantage of the higher octane then you are just wasting money. I don't know if Toyota's ECU does that to be honest, so that is the question you should be asking.
    Even if it does advance timing, it will take several tanks before you see the improvement as advancing is very slow, but one tank of low grade will retard the timing very quickly as more knocking is detected.
  14. Jan 10, 2021 at 12:02 AM
    #74
    Burica
    Burica [OP] Raptor Deracinator
    Texas
    Since I started this mess I’ll give my conclusion. I run ethanol free gas from time to time for fun. Truck is more responsive and I like that about the performance.
    But it’s expensive.
    So I run Shell V-Power Nitro+
    But that’s expensive too. So I run the cheap stuff too... 87 Octane.
    I rotate. In my opinion... The good stuff is better but hard on the pocketbook.
    Greene368 likes this.
  15. Jan 10, 2021 at 5:24 AM
    #75
    willconltd
    Orlando, Florida
    You should run 87 as that's what the factory tune calls for. You will get no benefits from higher octane without a tune.
    Ethanol free is a godsend for fuel systems that ARENT DESIGNED FOR IT. They have different materials. Cornwater gas in my NSX eats the seals to shit and clogs the fuel filter. Its highly corrosive to the existing system. However, the taco has seals and lines that are DESIGNED for cornwater so it really doesn't hurt anything.
    Same goes for your mower, cornwater eats up the carb seals and it runs like shit. Ethanol attracts water, water is very bad. If you are going to burn the tank of gas in the next month, then cornwater gas is just fine in your car/truck. If you are going to let it sit for 5 months then you want to use ethanol free and/or a stabilizer.
  16. Jan 10, 2021 at 7:07 AM
    #76
    Knute
    Interesting claims.
    I have run a '63 and a '71 Buick on "cornwater" for many years......never a fuel related issue.
    All my yard equipment (snowblower, lawnmower, weedeater, chainsaw) have only been fed "cornwater". Yes, I use fuel stabilizer. None have had fuel related issues.
    My '81 Honda motorcycle has been on a diet of "cornwater", stored for months with fuel stabilizer, never fuel related issues.
    All the cars and trucks I have owned have lived on "cornwater", multiple models and brands, not 1 fuel related issue.
    I believe your NSX has fuel problems. I'm not sure if the "cornwater" is the source, although I believe the fuel is an easy blame. I would believe the NSX has been designed and built within the last 15-20 years or so. It should be built to handle "cornwater". This fuel blend has been common since the early '80s. Have you done any performance mods to the NSX? These could be a source of contaminants fouling your fuel system.
    Yes, ethanol is hygrophobic. It will combine with water. It will carry the water into the engine to be burned. The 10% blend won't "attract" gallons or quarts or ounces of water into the fuel tank. More in the weight level of grams or less. This bit of water can only enter the tank by the humidity in the air from the venting system or from the fill neck. Gross amounts of water are generally from the fill neck.
    Ethanol by itself is not corrosive. Look into the chemistry.
    Anytime a fuel is stored for more the 6-8 weeks, it needs a fuel stabilizer. Don't matter if 0%, 10%, 15% ethanol.
    There are countries, Brazil for instance, which run a much higher %age of ethanol than the USA. Care to guess what companies sell cars and trucks in these countries? Engines have been built for years with the correct materials to operate with ethanol.
