2021 with bad wheel bearings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baumer22, Jan 26, 2023.
  1. Jan 27, 2023 at 10:32 AM
    #41
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    surprised no one has said, mileage and rough roads, pot holes damage hub and bearings fairly easily. some vehicles more than others. this is not a part failure, or worn out, this is driving, impact, use damage. our crosstrek has had 5 or 6 replaced in 145000 miles, our s10 blazer 5-6 in 150000, Impala somewhere around 10 in 225000. a sharp hit, bump, drop, pothole, bearing or race gets a flat spot, and the whining or howling starts. it is a maintenance issue. I am Surprised Toyota is covering it. good for you! Ski
  2. Jan 27, 2023 at 11:01 AM
    #42
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    SUPER annoying. VERY scary. 100%.
    THAT's what they TELL us. It's a good thing they don't TELL us what to THINK.
  3. Jan 27, 2023 at 12:11 PM
    #43
    baumer22
    baumer22 [OP] Member
    Green 2021 SR5 4x4
    None
    Hey, funny thing here:
    The service guy said my parts are only covered for the remainder of my warranty which is 1600 miles. The back of the work order I signed says a lot of things:
    Parts are good for 12 months regardless of miles or who purchases them (Toyota or me). - Easily provable
    If the problem is not alleviated, the warranty period is automatically extended. - Challenge but I think I would win.
    The Song-Beverly Act says they have to remedy the problem if its not resolved or I get a refund or replacement for the truck. - Hard challenge, probably involves a lawyer, but it also sounds like the dealer would have to back down and get Toyota involved.
  4. Jan 31, 2023 at 12:24 PM
    #44
    mountainmadness
    mountainmadness Member
    2021 Tacoma Off-Road 4x4 Green DCLB KDMax Pro Tune
    Just had my rear drivers side wheel bearing replaced on the 27th. Bad bearing at 27,000 miles. Dealership wouldn't budge on covering it under the powertrain warranty so I had to pay out of pocket. I take mine off roading often and I have aftermarket leaf springs, shocks, tires, and rims.
  5. Jan 31, 2023 at 12:31 PM
    #45
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Mine is in the shop now to get the backing plate replaced under warranty and to replace the backing plate, you have to press off the bearing. The tech said he won't press a used bearing back on the axle shaft so the bearing is being covered under warranty as well. MSRP of almost $500. Bad part is, over 200 bearings are backordered so none to be had. So I just wait and drive the loaner till it is fixed.
    AMMO461 likes this.
  6. Jan 31, 2023 at 12:54 PM
    #46
    AMMO461
    AMMO461 TACO/FJ/FJ
    SoCal Hi-Desert
    2021 TRD Off Road DCSB OD
    What went wrong with the original backing plate?
  7. Jan 31, 2023 at 1:54 PM
    #47
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Hate to say it but once you start modifying the warranties are dead.I mean any excuse for the dealer. You should of waited a few years before doing any mods. Just saying.
    zoo truck likes this.
  8. Jan 31, 2023 at 2:00 PM
    #48
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    So you believe the Mexico built trucks are of lesser quality? Does Toyota lack the skill to set up and support a robust Quality Process?
    Many Subaru models are still made in Japan and have had plenty of problems through the years.
  9. Jan 31, 2023 at 2:12 PM
    #49
    Nirango kid
    Gilles
    Ontario
    Yes, but Subaru have come a long ways with quality and durability and are as good as the Toyota. That is why Toyota bought some shares in Subaru if you did not know that.
  10. Jan 31, 2023 at 2:47 PM
    #50
    airforceb2cc
    Don
    KCMO
    Defect from the factory. Rivet that the shoes rest against bent, causing the shoes to bend into the axle and lock up the wheel.
    AMMO461[QUOTED] likes this.
  11. Jan 31, 2023 at 3:00 PM
    #51
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m a bit surprised both your rear wheel bearings failed at 58k miles. Did you ask how they diagnosed the proposed root cause? Have you seen the failed bearings?
    If they really did fail, the root cause could be some other problem that shortened the life of the bearings. If that’s the case, the new bearings might fail prematurely as well unless the real problem is addressed
    zoo truck and Chew like this.
  12. Feb 2, 2023 at 2:56 PM
    #52
    Pappy_Pud
    Pappy_Pud New Member
    2018 Tacoma SR5
    Replying to say I'm dealing with something very similar on my 2018. I started to notice a funky groaning/creaking from my rear axle so I brought it in and they diagnosed it as a bad bearing. Unlike you, I've got 72,000 miles so it's out of pocket for me :(
    NLMOOmar likes this.
  13. Feb 2, 2023 at 3:08 PM
    #53
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    another reason to replace the rear differential/axle fluid early
  14. Feb 2, 2023 at 7:39 PM
    #54
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Warranty is always from the date of purchase, having a part replaced under that warranty doesn't typically reset that warranty.
    I know in Canada, Toyota has or had a minimum warranty time, so if you replace a part under warranty on the last day of warranty, it was (from memory) 6 months or the remainder of your warranty, whichever is longer. I took a quick look through the Toyota USA warranty policy and procedures manual and don't see something similar, but I did however find the following on Toyota USA's website:
    So, there you go.
    Jeff
    Canadian Caber and RustyGreen like this.
  15. Jul 5, 2023 at 7:05 PM
    #55
    Jayjaydee
    Jayjaydee New Member
    Jeremy
    2023 tacoma
  16. Jul 5, 2023 at 7:08 PM
    #56
    Jayjaydee
    Jeremy
    2023 tacoma
    I just bought a 2023 Tacoma 2 weeks ago. I barley put 100 miles on it and all the dash lights turned on while I was driving. Took it to the dealer, they had it for 4 days now and finally told me that the right rear wheel bearing is defective.
    Dealer, texted me today saying the wheel bearing assembly is back ordered (350 units) for about a month. Guess I'll keep the loaner for now.
  17. Jul 5, 2023 at 7:13 PM
    #57
    Bishop84
    Bishop84 Well-Known Member
    Anything can fail, but this truly feels like the tech wanted to make money and only one bearing had to be replaced.
    Some dealers are restricted by warranty work, and Toyota will microscope why they called two bearings instead of one.
    Canadian Caber likes this.
  18. Jul 6, 2023 at 7:36 AM
    #58
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Not on our axles. We have sealed wheel bearing assemblies that are lubed internally and pressed onto the axle shaft. The rear diff fluid does no wheel bearing lubrication duty.
  19. Apr 2, 2024 at 1:51 AM
    #59
    Retired Taco
    Retired Taco New Member
    Took my 2021 Tacoma in for scheduled maintenance dealer says both rear wheel bearings are leaking . The truck has only 17000km. On it and has never been off road.Sure warranty covers it now but how long before it happens again when warranty is gone.Bought this truck thinking it was bullet proof.Man it might be a expensive mistake.
  20. Apr 2, 2024 at 4:51 AM
    #60
    BLtheP
    Plano, TX
    The bearings themselves don’t get any oil. There are seals in the axle tubes to keep gear oil from reaching the wheel bearings. If you blew both seals, then you could be experiencing what you are. Only way I can think of both seals being blown would be if the axle breather is clogged.
    Where are they seeing the leaking oil?
    Jeff Lange, Canadian Caber and Chew like this.
