2021s fuel pump recall?
Discussion in 'Performance and Tuning' started by Jbencher, Mar 27, 2021.
  1. Mar 27, 2021 at 7:39 PM
    Jbencher
    Jbencher [OP] New Member
    Jayce
    2021 tacoma
    Just got a new taco last week. Traded in 2019 that had the new fuel pump put in it (drove like brand new) no lag when I put gas to her. New taco has lag.
  2. Mar 28, 2021 at 4:14 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The 2021s should have the correct FP in it. If you had the TSB tune done on the 2019 (TSB-0092-20), it should be identical to the 2021. Pre-TSB 2019s should definitely have felt worse. I am assuming that any mods in the engine and driveline out to the wheels and tires are the same?
    The only things that I can say are to:
    -- Drive it for a while until it fully adapts to you. Up to about 1,000mi or so.
    -- Have the DTCs and Engine and Transmission Learned Values reset. It will clear everything and start the adaptation from a clean slate.
    -- Get someone to flash the vF Tune for you. I've done a couple 2021s. Those folks have been over the moon about the difference.​
  3. Mar 28, 2021 at 6:06 PM
    Jbencher
    Jayce
    2021 tacoma
    Thanks. I'll try that.
  4. Mar 28, 2021 at 6:56 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
